Old 12-04-2019, 11:39 AM #1
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
Parking brake issue
So I recently had the rear brake lines swapped out for stainless lines but now when it gets cold, the brake indicator light randomly comes on. No issues with the brake itself just the light popping up that it’s on. Lasts 5-10 seconds each time and only when it’s cold.
Anyone else had a similar issue or am I just lucky
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 04:11 AM #2
Sindri Sindri is offline
Sindri is on a distinguished road
Check the fluid level in the master cylinder reservoir. That light is usually associated with a low brake fluid level. If you're right on the borderline, it might be low when cold and immediately expanding a bit after you pump the pedal.
If you're consistently losing fluid, check connections at the lines you replaced.
Also keep an eye out for a sinking pedal, you should be able to stand on the pedal without it sinking. If it sinks, the cups in the master cylinder got scratched up during the bleed (if you bled by just pumping the brakes).
Sindri is offline   Reply With QuoteReply With Quote
brake , cold , it’s , light , lines
Parking brake noise issue autoxr37 4th Gen T4Rs 14 10-12-2020 07:00 PM
Parking brake issue after axle swap thezentree 3rd gen T4Rs 4 08-19-2019 08:58 PM
Parking E brake Issue DannyLlama 5th gen T4Rs 4 08-05-2014 10:54 AM
Parking Brake Issue JP4RNR 4th Gen T4Rs 12 10-17-2006 04:34 PM
