Old 12-05-2019, 02:12 PM #1
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
patkelly4370 maintained and mod thread
Being new to actually off roading, I think I am zeroing in on my mods.
A little background. I was parts manager at a Jeep shop (many years ago). Sold many many lift kits, tires, shocks, our shop did some wild builds. But I never went off roading.
Now I'm living in NW Arizona and there are many trails, mild to wild. I think I'll be mild(ish) fo a while.
The 4runner has 285's on it and enough lift that nothing is rubbing.
Currently has Nfab step bars, will be replaced with proper sliders.
Ultraswing hitch tire carrier will get the spare out from underneath and the proper size tire will be mounted.
Out front, Victory 4x4 "Blitz" bumper/winch mount and winch.
After that I'll start upgrading the skid plates.
All is subject to change, lol.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 04:00 PM #2
spartacus's Avatar
spartacus spartacus is online now
spartacus's Avatar
Good plan. Post some pics.
spartacus is online now   Reply With QuoteReply With Quote
Old 12-09-2019, 05:38 AM #3
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
I say do the skids first!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 06:48 AM #4
I do like this suggestion.
I already have a receiver recovery point for the back.
Maybe start with some recovery points in front, then armor-up the underside starting in front and working back.
I really want to get that spare tire out from underneath.
Considering where I live (NW Arizona desert) there's not much to connect a winch to. Not many trees around.
More suggestions welcomed.
Old 12-09-2019, 11:06 PM #5
5thToy 5thToy is offline
5thToy is just really nice 5thToy is just really nice 5thToy is just really nice 5thToy is just really nice
I concur. Tires and armor are first priority.
5thToy is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 12:22 AM #6
Toyo Open Country A/T, 285/70R17 on Mickey Thompson "Deegan 38" wheels.
It came already lifted and I don't see any tire rub.
Skids and moving the spare tire from underneath.
Having no trees here in the desert, a winch may not see as much use as recovery straps.
Old 02-06-2020, 10:19 PM #7
Been doing little things so far.
Been buying recovery & tow straps. Tree protectors. Shackles.
Today ordered BBG front recovery brackets
A-pillar grab handle.
Photosensor for dash lights (doesn't work, yet)
Black wrap on roof rack bars. Black end caps arrived today. Will install Monday.
Glovebox divider.
Made a hose assembly to air up/down all 4 tires simultaneously and to exactly the same psi, quickly.
More to come.
Old 02-07-2020, 08:28 PM #8
xyzzy xyzzy is offline
xyzzy will become famous soon enough
Google 'deadman winch anchor' to see how to use a winch when there are no trees around.
Deadman Offroad (no affiliation) makes a really versatile product that's lightweight.
Here's an example of its use
xyzzy is offline   Reply With QuoteReply With Quote
Old 02-08-2020, 03:43 PM #9
That's also on my radar. But to use it where I live I'll have to add a pick axe.
Maybe dynamite too, lol.
Old 03-07-2020, 11:02 AM #10
Moved and renamed to keep from starting and/or juggling other threads.
Starting to gather tools and ingredients for MY first service of the truck. It's not going to the dealer for the "free" oil change.
I bought it from the dealer with 20,000ish miles. At 25k, probably May, I'll replace engine, transfer case, & differential(s) fluids. Then again at 30k to assess under my particular driving. 65% highway, 20% city, 10% dirt roads, 5% trails.
Is it recommended to replace the plastic oil filter housing with the metal one?
Also living drive shafts & suspension, rotate tires, check brakes & all suspension components & bolts.
Not as easy to work on as my 68 F100, but easier than our Dodge Magnum.
Old 03-07-2020, 11:18 AM #11
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
25K is a bit early for the xfer case and diffs, but doing it again in 5k is really unnecessary.
Have you priced the xfer case fluid? Yikes.
Yes I installed a metal filter housing.
You in the AZ Strip?
delloro is offline   Reply With QuoteReply With Quote
Old 03-07-2020, 11:42 AM #12
I'm doing it early mileage because the truck is new to me. A known starting point.
I'm not going to use Toyota TC juice. Either Royal Purple Syncromax (RP guarantees comparability) or 75w90 like the diffs. Just replaced more often. When I service the diffs.
I'm in Golden Valley, "work" in Bullhead.
Old 03-07-2020, 11:53 AM #13
I won't be doing diffs and transfer 'every' 5,000 miles, just that initial 5k.
Then 15,000 or annually thereafter.
Old 03-07-2020, 03:17 PM #14
delloro's Avatar
delloro's Avatar
That's what I thought. Why do it at 5k after the 25k change? I cannot see any benefit. If it was OK at 25k, it will still be at 30k.
Old 03-07-2020, 03:53 PM #15
Evaluating the condition under my driving conditions/habits. I think it was a babied lease trade in. Those days are over.
Wife wanted a 4 seat CanAm to explore off the beaten path, I bought the 4runner. I'm ok with her getting a CanAm too patkelly4370 maintained and mod thread.
I could just drain a sample. Guess I'm still conditioned from changing oil between runs/heats.
lift , proper , shop , tire , wild
Intended aiming of aftermarket lights patkelly4370 General Discussions 5 12-10-2019 11:04 AM
2016 - when? Any additions at all? Katiebee4 5th gen T4Rs 21 08-18-2015 04:42 PM
Toyota additions... Pensacola33 New Members 1 12-26-2011 06:47 PM
Some New Additions! RevengEngine 3rd gen T4Rs 8 08-20-2008 08:34 AM
