Old 12-06-2019, 11:48 PM #1
chrissurfr chrissurfr is offline
Real Name: Chris
chrissurfr is on a distinguished road
Real Name: Chris
Help - Rear end hum - replaced carrier - still humming
4Runner family,
I’ve had a humming sound coming from the rear of my truck for a while now - at least 10miles. I’m now at 19k miles. The truck is still under warranty and has been taken to the dealer to fix multiple times but they can’t figure it out.
I live in Houston so the truck has been through high water (bottom of doors) a couple times.
Characteristics of the metallic hum:
1. Happens around 30mph upon coasting or deceleration
2. If coasting, the sound remains constant but seems to get louder when slowing down to about 25mph - below or above that speed there is no noise
3. Seems louder in the cold
4. The sound only happens if under load and not with wheels in the air
What has been checked/changed attempting to fix:
1. Dealer checked and said it’s not wheel bearings
2. Rear dif carrier was just replaced under warranty - humming remains
3. I installed a clamshell bushing to get rid of needle bearing - that didn’t fix it
I’m out of ideas at this point and the dealer really isn’t much help.
what else could it be?
1. axles?
2. Some other bearings not in the carrier?
Thank you!
2017 Cement Grey TRD Pro
C4 Fab sliders
Prinsu 7/8 roof rack
King Shocks with adjusters
SCS 17x9 f5 with 285 Nitto Ridge Grapplers
chrissurfr is offline   Reply With QuoteReply With Quote
Old 12-07-2019, 12:24 AM #2
Teamoatmealpie's Avatar
Teamoatmealpie Teamoatmealpie is offline
Teamoatmealpie has a spectacular aura about Teamoatmealpie has a spectacular aura about
usually its the diff needle bearing, which you have already replaced with the bushing.
Mine was on the front, most noticeable coasting under 40.
Teamoatmealpie is offline   Reply With QuoteReply With Quote
Old 12-08-2019, 08:04 PM #3
Real Name: Chris
Real Name: Chris
Bump...anyone?
C4 Fab sliders
Old 12-09-2019, 12:03 AM #4
tristero's Avatar
tristero tristero is offline
Real Name: Justin
tristero will become famous soon enough tristero will become famous soon enough
tristero's Avatar
Real Name: Justin
If you replaced the diff, I would look at the driveshaft, joints, and rear axle.
2010 4Runner SR5 Magnetic Gray: Radflo / Icon + Metaltech / Total Chaos / Dirt King / SCS Stealth 6 / BAMF Sliders + Pelfreybilt Bumper / PRINSU / Indel B / 2014+ IS 350 Retrofit
2012 GX460 Premium Black Onyx: Stock af
tristero is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 10:15 AM #5
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Tire noise possibly? Dust shield on brakes rubbing? Dry U joint? One of the pully's under the hood? Brake shoe dragging? Just some thoughts. Mine has a hum also that I can't figure out. I've given up and just accepted and listened to it for the last 40k, nothing broke yet. I'm at 186k though.
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 01:17 PM #6
Real Name: Chris
Real Name: Chris
Ok - some progress.
I lowered the truck about 1/2-3/4 of an inch and the vibration is much less.
Now knowing this, I think it is driveline angle related.
I'm probably lifted about 2.5-2.75 inches up front.
Do I need to get a diff drop to possibly fix this or do I need to reset the pinion angle?
C4 Fab sliders
Old 12-11-2019, 01:58 PM #7
DigitalRJH DigitalRJH is offline
DigitalRJH will become famous soon enough
That's interesting. I know with lifted Cherokees, the originals, not these new ones, that lifting them too high caused all kinds of vibrations and drive line angle issues that were not good.
DigitalRJH is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 02:11 PM #8
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Do you know for sure or are you just guessing? I would try to get some measurement and compare them with other peoples lifts. I'm at 2.5" up front and it's pretty mild of a change TBH.
Diff drops are almost worthless on these trucks. Won't achieve much.
If I had to guess you where sitting at a 3-4" of lift and you are straining the driveshaft.
Figure out how much lift you actually have.
Mutant138 is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 02:16 PM #9
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
You may have a CV that's got a bad bearing inside it or something related to the CV. You didn't mention if it went away in 4x4 or not.
Possible bearings could be anything from wheel bearings to any of the bearings in the transmission or transfer case or drive shafts. Usually you can run it on a lift and use a mechanic's stethoscope to isolate noises and find which bearing it is.
Old 12-11-2019, 04:36 PM #10
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Could you have mild resonating from exhaust onto a close part or hanger and it acts as a music generator.
Grug556 is offline   Reply With QuoteReply With Quote
dealer , fix , rear , sound , truck
WTB: Gen 4 Roof Rack, Rear Bumper with Carrier or hitch mounted tire carrier yotanoob Want to Buy/Trade 0 11-23-2016 01:15 AM
Humming from rear at a stop Sifrk 5th gen T4Rs 3 11-22-2016 02:57 PM
Rear End Humming Noise Socalrunner29 3rd gen T4Rs 7 09-18-2014 06:46 PM
04 SR5 humming from rear schulgr 4th Gen T4Rs 0 02-11-2014 12:54 PM
'Humming' noise from rear end Kung 3rd gen T4Rs 13 11-10-2013 11:50 AM
