05-04-2014, 07:52 PM
Transmission Whine
My 4R just rolled 50k miles and I decided it was time to change out the transmission fluid. At that time I figured it best to install a transmission cooler.
As a little background I purchased it at 44k and the transmission always had a slight whine to it. I was never concerned over it so I just drove it.
This weekend I did the pump two out, pump two in method to exchange out 14 quarts of fluid with Amsoil's OE Fuel Efficient ATF. It is rated for WS and after some extensive reading no one reports any issues with running it for extended periods. GREAT! Also read that some people on here that quite a few people have installed the B&M 70264 cooler. Another GREAT.
Did all that this weekend and took it for a test drive. The whine has gotten much louder. To the point where I'm now concerned. I removed the cooler but the whine is still persistent, although not quite as loud but still cause for concern. I'm going to be calling the dealer to book it in to see what they have to say but does anyone have any suggestions as to what is going on? At this point all I can guess is the pump is going out on it and I've just accelerated it. I knew I should have gotten a 6MT Tacoma
Here's the video, it sounds pretty much just like a supercharger.
https://www.youtube.com/watch?v=1hndmSfNFeY
2015 VW Jetta TDI SEL 6MT
2001 Jeep Cherokee
2011 4Runner SR5 SOLD
05-05-2014, 06:10 AM
If you are positive that the whine is louder after the work, than I would take to a dealer or trusted shop. I would just offer this up, sometimes we hear things a little different if we think there is an issue, I have done this numerous times.
Do you think you could be hearing some normal gear/drivetrain noise? I could not hear any whine in the video, but my hearing is not that sharp.
Keep us posted on what happens.
2010 SR5
05-05-2014, 08:43 AM
Real Name: Mushmouth
Originally Posted by IAmTodd
I knew I should have gotten a 6MT Tacoma :
You would just have to deal with bad throw out bearings then. I was going through TOB's every 30K miles. And it cost $1200 to replace. This was on a new FJ that was babied and never taken off road. Once warranty was up, cya.
I will never own another manual Toyota transmission.
'14 SR5
'08 FJ Trail Teams 6MT, '03 4Runner Sport V8, '02 4Runner Sport, '80 SR5 Pickup 5MT, all of them 4WD.
05-05-2014, 08:46 AM
I did book it into the dealer for tomorrow. I really think it does sound different but like you said, if we're expecting something then maybe we make the sound be there. I don't think it's a normal sound as I've never heard a passing 5th gen 4Runner make this noise.
@ joneseyyy
had an issue with the timing setup. He listed to my video and said it sounded similar. I'm hoping it's not that bad but doesn't give me the warm and fuzzies. I'll report back tomorrow when I find out more.
2001 Jeep Cherokee
05-05-2014, 08:47 AM
Dang, I guess I should have stuck with my '94 Explorer. The manual in that thing was rattly as all hell but at least it was solid.
2001 Jeep Cherokee
05-05-2014, 09:09 AM
HA! Funny you say that. I was about to offer up that the only whine I've ever heard was in my '93 Explorer manual that had a transmission fluid leak. It was fine when you had enough fluid in it, but started to sound like an Indy car when it started to get low. Sucked...only way to put more fluid in was a side plug on the transmission itself.
2019 Limited
05-05-2014, 09:15 AM
Yea, those 3 plugs at the top of the shift plate like to leak if you leave the rubber caps in them. I replaced with metal plugs and no more leaks. I did find it much easier to remove the shifter and fill through that hole. I always feared spilling ATF in the interior though.
2001 Jeep Cherokee
05-05-2014, 09:45 AM
Real Name: Stephen
Real Name: Stephen
Just out of curiosity, did you leave the clutch pedal depressed while in gear at stop lights and such?
05-05-2014, 11:06 AM
No, clutch was only depressed to change gears. Left in neutral at lights, idle.
SET replaced the entire transmission no questions asked at 63K miles, outside of warranty. So they are aware of the garbage they are producing. Check the FJ and Tacoma forums, this is common and happens year after year with no improvement from Toyota. Best manual trannies I have ever owned were Honda and VW. Ford didn't have TOB issues, but it was clanky.
I fully intended to keep the FJ and pass it to my 6yr. old son, but the return of the TOB whine forced me to sell it while it was quiet. I would have gone ballistic if I had to pay such an expense to sell it.
Sorry, thread jack......back to OP
'14 SR5
05-06-2014, 07:01 PM
As I figured they say it's a normal noise. They had a 2012 in the shop with 16k miles on it that had a very slight whine and they said it was the same. It's all documented and I have another 9k miles or so on my warranty so I'll just leave it go and take it back near the end of the warranty. We'll see if chunks fly between now and then!
Thanks guys.
2001 Jeep Cherokee
05-06-2014, 09:49 PM
Just an fyi, my 2010 sounds the same way.
05-06-2014, 10:01 PM
Real Name: Steven
Real Name: Steven
Mine has the same sound too. Coming from a v6 Tundra that didn't make this noise I am also mildly concerned but so far have been assuming that its normal.
2013 T4R Trail Edition - MetalTech OPOR Sliders coated with Bullet Liner - Reese Vehicle Recovery Ring (trailer hitch) - K&N Air Filter - LED Interior Lights - Husky Floor Mats and Trunk Liner - Budbuilt Hidden Winch Mount - Smittybilt XRC-9.5K Waterproof Winch Gen2 - Rigid Dually D2 Lights - Plasmaglow LED Headlight Bulbs - Sonoran Steel Lift (set at 3.5" Front + 2" back) - 285x70x17 Cooper S/T MAXX tires - 4500LM VLED High Beams - Rcimetalworks skids (all but the gas tank) - 3d printed "trail" emblem - eezi awn k9-2-2-meter-roof-rack-system-for-toyota - tepui kukenam XL ruggedized roof top tent - 18000LM 48" light bar - (2) 4gal rotopackspacks and pack mounts -
05-07-2014, 07:20 AM
I guess that's good to hear, maybe??
I thought maybe a new exhaust would cover up the noise, found this video of one and it's got the same whine as well so I guess we shall just rock on.
https://www.youtube.com/watch?v=3ORqElBEcTQ
2001 Jeep Cherokee
05-07-2014, 11:00 AM
I heard the "whine" in this video at the very first part when they were revving at a stop with the stock exhaust. The whine is coming from the engine and not the transmission.
In your video, you are accelerating the whole time, to produce the whine, which also may be coming from the engine and not the transmission. Do you ever hear the whine when you are coasting in gear or in N? Can you hear the whine when you rev it when stopped? Is this maybe just a normal engine noise?
05-07-2014, 12:52 PM
The whine seems solely dependent on the engine RPM. It will whine in park, reverse or any forward gear. Accelerating or coasting. I figured it's either the engine or the transmission pump as I believe that spins at the same speed as the engine.
2001 Jeep Cherokee
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
