12-08-2019, 11:55 PM
Opinions about high miles on a 2017 SR5
1st post in this section, I currently have a 3rd gen that I've been considering getting rid of and updating to a 5th Gen 4runner or a 4th gen Taco. A local Toyota stealership has a 2017 SR5 for a great price, around $20K. The catch - the rig has 115K on it! It was sold and serviced at the same dealership and it has a clean carfax, and if you didn't see the odometer you'd never guess it has racked up that many miles in 2 years. It looks clean and drives perfectly.
My concerns- given that it took 20 years to rack up 230K on my '99 Limited, this rig is only 2 years old with half of that mileage. There's no type of meaningful aftermarket warranty for the 2 year old rig with 115K, I'm not sure how many miles to expect from a much newer 4runner. I don't want to be 2 years into car loan loan and have a catastrophic mechanical failure. What types of mileage are you guys ( and gals) seeing on your 5th gens without any big mechanical repairs?
Any thoughts would be appreciated concerning how smart of a purchase this might be.
'99 Limited, 225K miles, 3.4/automatic, multi-mode, e-locker, broken sunroof, no DRL's. 265-75-16 Hankook Dynapro ATM. New Moog rear springs, KYB Monomax F&R.
12-09-2019, 12:49 AM
Holy cow! I thought we put a lot of miles on vehicles!
Was it a rental? If so, I would pass.
If it was owned by a person(not a company) and there are detailed service records I wouldn't worry about it too much.
And remember, just because it's a 2017 doesn't mean it was sold in 2017. And we're almost in 2020. So if was sold in 2016 it could be 3 years old. Still a TON of miles in a short period of time.
12-09-2019, 12:59 AM
Did you drive it? You do know a clean carfax and similar places like vin check and auto check are not all that accurate and often disagree with each other - right? I'd pass without more info, test drive and a look underneath.
12-09-2019, 01:01 AM
I see you did drive it - my bad!
12-09-2019, 10:06 AM
Screen name checks out.
2018 ORP Barcelona Red
Dobinsons 2.5”/1.5” lift with springs and shocks.
Diff. Drop.
Pro Comp UCAs.
RSG angled sliders.
12-09-2019, 10:30 AM
Personally, i'd look hard at something a little older but with less miles if I was set on a specific budget. You have a lot of options when it comes to 5th gens considering they've been around now for a decade.
2020 Midnight Black Metallic 4runner Offroad premium
12-09-2019, 11:39 AM
You’d be money and peace of mind ahead to save like crazy until you can put together a good deal for you! There’s a reason it’s priced where it is. Put your “wants” aside while saving with a goal and get a new one or low mileage late model with a warranty. BTW used car dealers have earned a widespread reputation for “fictional truth telling” when it comes to a vehicle’s history.
12-09-2019, 12:03 PM
Real Name: Reinout
Real Name: Reinout
That high of mileage in a short period most likely means highway miles which isn't a bad thing.
Everyone should install a Hour Meter from mile zero for a more accurate reading on what sort of miles.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
12-09-2019, 12:08 PM
If it was a one owner, and not a rental or fleet then I would consider it. Lets say you can get it for 20k OTD, and normally a lower mileage would be 29K OTD...
That means you have $9,000 in 'warranty' so to speak. Also, if it does have a major issue, I bet you could trade it in or sell it and not lose a ton. I doubt it would throw an engine, trans, ECU...
Then again I got a 2019 new with a 125k warranty because I didn't want to worry... I did pay 38,500 for a SR5 Premium with the 125k warranty and 3rd row seats...
IG 4runner.gunner
12-09-2019, 12:11 PM
I believe my 2017 has an hour meter... one of the screens on the display shows "hours"....
12-09-2019, 12:24 PM
That can be reset and does not track engine hours. That's more for tracking how much you drive.
2017 MGM TRD Off Road Premium
12-09-2019, 12:44 PM
Real Name: John
Real Name: John
If it checks out like what others have mentioned above, maybe give them an aggressive low offer and see what happens? Tell them $18,500 out the door taxes/ tags/ dealership fee and all.
You never know.
Maybe ask to take it on an extended test drive, reset the MPG computer and get it on the highway at 75mph and see how it does, should be in the 22mpg range highway, reset it again for some around town driving, should be around 18 city. If I reset mine and keep it to 65 with a light load I'm in the 23mpg range highway.
Has it had a trans drain/ fill (not flush)?
Crawl all around under it looking for rust, make sure it wasn't a rental or some sort of fleet owned deal...
I've got 120K on my 2011 and I'll probably take it to 200K before I even think of upgrading. I did see a SWEET 2013 Shoreline Blue Trail a while back, before I could get up the energy to go look/ consider the financial side of it all it sold, 2013 pre-facelift shoreline blue trail.... Wow!
This is not the one I looked at, just an example of a Shoreline Blue early Trail, just for kicks.
JTEBU5JR6B5062169 | 2011 Toyota 4Runner Trail for sale in Easton, PA
12-09-2019, 12:55 PM
I'd have to double check but I am pretty sure my OBD2 scanner (used to pull codes, clear CELs, etc.) has a live monitoring section where I can see Coolant Temp, Trans Temp, etc. and there's a section for engine hours, and definitely a section that shows how many times the vehicle was started and then reached operating temp.
Could be good info to have when buying this vehicle.
This is the one I got: Amazon.com: ANCEL AD310 Classic Enhanced Universal OBD II Scanner Car Engine Fault Code Reader CAN Diagnostic Scan Tool-Black: Automotive
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
12-09-2019, 01:00 PM
Have a mechanic hook up an expensive code reader tool (that they should have if they are worth their salt) and have him analyze the results (should have logs of any issues) and also have him visually inspect the vehicle. Also definitely user AutoCheck as well as CarFax.
Otherwise it might be a good deal, I bought a 1992 Toyota truck (probably about 4 or 5 years later, maybe 1997) with 163,000 miles on it and sold it 10 years later still running with 410,000 miles on it.
Change all the oils and grease all the joints and you should be good. If it is not a 4x4, have them drop the price. Make sure they didn't put sheety tires on it too.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
12-09-2019, 01:02 PM
Real Name: John
Real Name: John
PS to the novel I wrote above, is it 4x4??
If not keep that in mind for future resale, you'll have a much smaller buying audience and the price will suffer some compared to 4x4.
Is it Super White? If so there can be some chalky/ uneven paint issues. Pearl white (what I have) is also questionable I hear although mine is holding up fine.
Age of battery, conditon of tires, last brake job?, any fluids changed- trans/ diffs/ transfer case/ radiator/ power steering/ brake fluid? $$$$ If not some of that stuff is on the horizon. Just thinking out loud here, I over analyze bad so take it all for what it's worth- $0.02 if that.
