Old 12-09-2019, 03:42 PM #1
Xtremluck's Avatar
Xtremluck Xtremluck is offline
Xtremluck will become famous soon enough Xtremluck will become famous soon enough
Xtremluck's Avatar
Stress fracture (Inner side fender)
Hi Friends,
Wanted to get some thoughts on a new issue I discovered over the weekend while working on the rig. After just about 4 years and thousands of miles off road (Many on rough corrugated tracks). I've developed a pretty nasty stress fracture on my passenger side inner fender sheetmetal. I've been using a 4x4labs compressor mount that attaches with three bolts (Two on the fender and one on the bottom right above the wheel well).
The weight of the compressor seems to have been a bit much. I temporarily stop drilled the tip of the crack to prevent it from spreading but I'm sure it will get worse. I know a lot of folks mount compressors and batteries in the same place and I'm sure have had similar experiences. Have you all found a remedy for our paper thin sheetmetal?
'12 Silver 4Runner SR5: 14+ facelift, Pelfreybilt front, CBI Rear, Warn M-8000S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, Icon CDCV suspension w/UCAs, OME 899, Nitto RG 285s, Full RCI Skids, Metaltech Sliders, Gobi Rack, ARB Awning, Rotopax,1up Hitch Rack
Xtremluck's 2012 SR5 Build Thread
Instagram - @Aperture20
Xtremluck is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 04:30 PM #2
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a jewel in the rough T4R2014 is a jewel in the rough T4R2014 is a jewel in the rough T4R2014 is a jewel in the rough
T4R2014's Avatar
That's kind of the nature of aftermarket parts. You'd need to weld in reinforcement from the back before welding it back up.
Old 12-09-2019, 04:40 PM #3
Inv4drZm's Avatar
Inv4drZm Inv4drZm is online now
Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold Inv4drZm is a splendid one to behold
MY GARAGE
Inv4drZm's Avatar
MY GARAGE
Early FJ Cruisers had a similar issue, they called it fender bulging and even stock FJ's developed the bulge. I guess Toyota fixed the issue down the line.
2005 4R Sport 4WD "The last of the V8s!" - Custom TIG'd SS Dual Exhaust - Icon 2.5 Resi's. - 1.5" BL - SCS SR8's - 35's - Dana 60 - Build Thread
2005 Tundra 2WD RCSB V8
Inv4drZm is online now   Reply With QuoteReply With Quote
Old 12-09-2019, 04:55 PM #4
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
Originally Posted by Xtremluck View Post
Have you all found a remedy for our paper thin sheetmetal?k
easy. mount it to something better/more solid.
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 05:00 PM #5
nb rob's Avatar
nb rob nb rob is offline
nb rob is a jewel in the rough nb rob is a jewel in the rough nb rob is a jewel in the rough nb rob is a jewel in the rough
nb rob's Avatar
Frame/chassis problem- crack in fender well
this came up a few years ago. I've avoided a heavier battery recently, keeping that thread in mind.
It's the other side, but the problem is similar
_______________________
2015 trail edition premium w/ KDSS
OPOR sliders ● 255/75/17 firestone destination AT ●
King coilovers and shocks w/ compression adjust ● Dirtking UCAs ● Icon 2" rear springs
nb rob is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 09:32 PM #6
Xtremluck's Avatar
Xtremluck's Avatar
Yup, I started thinking about that. Just welding it back together will only give temporary reprieve until it inevitably fails again. If I repair it I will definitely reinforce it somehow.
Old 12-09-2019, 09:33 PM #7
Xtremluck's Avatar
Xtremluck's Avatar
Hah, yeah that is probably going to be the ultimate solve eventually.
Old 12-09-2019, 09:34 PM #8
Xtremluck's Avatar
Xtremluck's Avatar
Yup, I remember seeing that way back when. It's the reason I went with a pretty small second battery. Luckily mine hasn't cracked there yet!
Old 12-09-2019, 09:38 PM #9
rochmpr's Avatar
rochmpr rochmpr is offline
Real Name: Krister
rochmpr is just really nice rochmpr is just really nice rochmpr is just really nice rochmpr is just really nice rochmpr is just really nice
rochmpr's Avatar
Real Name: Krister
Hi Friends,
What mount is that? I had the same issue with my twin ARB mount due to the design. I ended up having to add additional supports and another mounting point to stabilize the mount. Details are in my build thread somewhere.
Sent from my SM-G965U using Tapatalk
2014 TE w/ KDSS - Icon Stage 5 ET w/ Icon Delta UCA & Metal Tech Lower Links, 4X4 Lab's Armor, BudBuilt Full Skids, SCS Stealth 6 w/ 315/70R17's & 4.56's with ARB Front - Build Thread
KK6IOS - General
rochmpr is offline   Reply With QuoteReply With Quote
Old 12-09-2019, 11:12 PM #10
rochmpr's Avatar
Real Name: Krister
rochmpr's Avatar
Real Name: Krister
Here's the link
Hope this helps.
KK6IOS - General
compressor , fender , mount , sheetmetal , stress
Roof rails side stress skt4271 5th gen T4Rs 4 11-30-2019 10:48 AM
WTB: 3rd Gen Passenger Side Fender, Fender Liner, and Corner Light Navy98SR5 Want to Buy/Trade 3 11-29-2014 04:00 PM
WTB: 4th gen driver side fender and fender flare jacob_wood Want to Buy/Trade 0 09-05-2011 05:41 AM
wtb: Drivers side white fender 96+ fender CaliCal Want to Buy/Trade 0 11-11-2009 01:35 AM
Stress on 4runner parts? JLRSR5 3rd gen T4Rs 4 05-31-2009 04:22 PM
Copyright © 2019
