Old 12-10-2019, 11:54 AM #1
Brage Brage is offline
Brage is on a distinguished road
Roof Rail Track in Gutters
I did a little searching for this and didnít see much on it. My apologies if I overlook anything.
Has anyone installed a roof rack/rail track in the gutters? It seems like this would give a ton of flexibility. I would drill two new holes near the front, likely at the frontrunner rack distance from front for two reasons... I believe frontrunner has done some research around strength points in the roof structure and if I use the same spacing between the holes as the rear points, I could use the same Ďfillerí plate bracket for a roof rack delete if I ever wanted to remove it.
So, anyone have a track that they could recommend? Any issues with the roof curvature? Remove or keep the rubber gutter trim? Any general thoughts?
Thanks in advance.
Brage is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 02:56 PM #2
pDubs's Avatar
pDubs pDubs is offline
pDubs is a jewel in the rough pDubs is a jewel in the rough pDubs is a jewel in the rough pDubs is a jewel in the rough
pDubs's Avatar
The OEM roof rack is a rail that's in the gutters that has a track built into the side?
2014 SR5 Premium
5100s w/Dobinsons 302/505 springs - TRD Pro wheels - Prinsu Full Length Rack - 265/70 Falken Wildpeak AT3W - Full RCI skids - RSG sliders - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 04:36 PM #3
No, Iím referring to something more along the lines of this: https://www.toyota-4runner.org/2303168-post66.html
He took off the factory rails and added a track in the gutter. Why donít more people do this?
Old 12-10-2019, 04:41 PM #4
Dillusion Dillusion is offline
Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice
Not sure if you can just get the rails separately.
and what would you use for cross bars?
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 04:48 PM #5
There are literally hundreds of options. Here is an example: Universal Load Bar System — Sherpa Equipment Company
Old 12-10-2019, 04:50 PM #6
Maybe it isnít clear.. when I say track, I mean something like this. Universal Track Non Drilled / 1800mm(L) - by Front Runner
Old 12-10-2019, 06:24 PM #7
deadbeat son deadbeat son is offline
deadbeat son is on a distinguished road
Rhino Rack makes tracks that specifically fit the 4Runner. I have been meaning to research to see if I can trim the length to reflect that of the factory rack thereby avoiding drilling the necessary mounting points for the front of the tracks.
deadbeat son is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 06:54 PM #8
Guess if you needed the adjustability would work nicely.
But sticks out like a sore thumb to me and I don't need to adjust mine. Only thing that goes on my roof is my fishing poles.
2018 TRD OFF ROAD
My Build
Old 12-10-2019, 06:57 PM #9
I guess my intent would be that it wouldnít look much different than the black rubber trim when nothing is mounted to it. Maybe stick up .5-1 inch.
Old 12-10-2019, 07:04 PM #10
Sorry I was more referring to the cross bars. I like how the factory ones hide behind the rails.
I'm guessing most adjust their load to the rails rather than adjust the rails to their load.
Or buy a complete roof rack.
2018 TRD OFF ROAD
My Build
Old 12-10-2019, 07:12 PM #11
The rhino rack version looks fantastic. Looks like it sits flush in the channel. It could allow for a much lower installation of a rhino rack or frontrunner than the vehicle specific side rails. Thanks!
Old 12-10-2019, 07:20 PM #12
Reinout's Avatar
Reinout Reinout is offline
Real Name: Reinout
Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
@Brage I used to work for a rack/hitch installer and we had done some "track fill" style installs by Rhino Rack. This removes the stuff in the "gutter" and puts in a track that sits relatively flush with the roof-line so when/if you take the towers off you don't see tehm.
I can't find the custom tracks on their website unfortunately.
http://www.rhinorack.com/en-us/products/roof/roof-racks
They have a number listed so call them: 877 744 6622
1997 4Runner SR5- ~370k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 142k Miles - Automatic - Brake Controller.
2011 VW JSW TDI- 104k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is offline   Reply With QuoteReply With Quote
Old 12-10-2019, 07:55 PM #13
Roof Racks | Rhino-Rack
Thanks.. do you know if these are Ďuniversalí? In other words, could I use a rhino track and frontrunner towers?
Old 12-10-2019, 08:36 PM #14
pDubs's Avatar
pDubs's Avatar
YouTube
2014 SR5 Premium
Old 12-10-2019, 09:20 PM #15
Reinout's Avatar
Real Name: Reinout
Reinout's Avatar
Real Name: Reinout
Looking at the install for Frontrunner website I can honestly not tell.
I DO know that the RhinoRack tracks will work with Inno, Thule and Yakima however.
front , frontrunner , holes , roof , track
FS: 3rd gen roof rail (NC) - $50 zcruiser For Sale: T4R Items 3 07-31-2017 09:10 PM
FS: 3rd gen roof rail - $50 zcruiser For Sale: Non-T4R Items 0 07-19-2017 02:27 PM
Where can I get this roof rail end cap? robertbird 4th Gen T4Rs 13 03-08-2017 07:16 PM
Full length factory roof rail/Aluminum Roof Rack FreshSeabass 3rd gen T4Rs 2 09-06-2016 10:07 PM
Roof rail system vs roof basket? Donovan1 5th gen T4Rs 19 07-01-2016 01:25 PM
