10-04-2015, 07:51 PM
Bilstein 5100 install guide
Sorry guys. I didn't really want to ask. I been googling and searched through 10+ pages to find an install guide but failed miserably. I'm sure it's somewhere super obvious but I can't find it. Would someone send me a link of an install guide for the 5100s and a rear spacer please. -mike
2015 black 4Runner TEP
-blk trd pro rims -trdpro skidplate -nFab steps -oem crossbars -trd pro grill -trd pro garnish -bilstein 5100s set at 2.5" -1.5" rear cornfed spacer -1.25" spydertrax spacers -all weather mats -cargo cover -AVS aeroskin hood protector -AVS streamless visor -BFG ko2 275/70/17
10-04-2015, 10:08 PM
No install guides that I've seen here, not many DIY for all that matters. Really straight forward install. Any green shade garage mechanic can do it.
Front:
-Lift, put on jack stands, remove wheels.
-disconnect ABS lines so you dont break them during install.
-remove endlinks and sway bar.
-remove LCA bolt, remove UCA bolt, pull shock assembly out. Helps to have an extra person.
-put on spring compressors, remove springs and transfer over to 5100s at set height. Reinstall spring, hats, bolt, etc. make sure all lines up correctly.
-Install the shock assembly. Takes some wiggling. Connect ABS sensor.
-Torque to factory specs.
Rear:
-Wheels removed and SUV on stands.
-Place jack on one side of rear axle and jack up so its easier to remove endlink bolt, remove shock. Coil will fall out.
-Install new 5100 shock, put spacer on top of coil and reinstall endlink.
-Repeat on other side.
Shouldn't take more than 90mins-2hours. Then take it in for an alignment.
10-04-2015, 10:20 PM
2014 Black SR5 4x4 - 285/70/17 Falken M/T, C4Fab Gas Tank Skid, RCI Steel Engine/Trans Skid, Shrockworks Sliders
https://www.youtube.com/user/Locked32114
10-04-2015, 10:42 PM
On the struts. Is there 3 settings for the height? .85, 1.75, and 2.5?
10-04-2015, 10:55 PM
+1 for the no spring compressor route. I have done both ways and the no spring compressor instructions posted here was way easier.
-Travis
2014 4Runner TE: 285/70/17 M/T ATZP3, 5100's 2.5" front/1.5" DS rear, Spidertrax spacers, RCI Sliders, FrontRunner Slimline II, Gobi Ladder, TRD Intake, Borla Catback, Pedal Commander, TRD Pro: Wheels, Skid, Grille
2018 Audi S5 Sportback, 2017 Toyota 86
10-04-2015, 11:27 PM
Real Name: CJ
Real Name: CJ
4. The bottom one is for 0 lift. And remember the spring cups face DOWN (narrow side up) when reinstalling the springs. A couple have managed to put them in upside down. This will automatically gain you a couple inches of lift you don't want.
2014 Trail Edition -
Build Thread
2015 Epic in my own mind trip
10-05-2015, 02:08 AM
Take a look at the 4th gen threads for cornfed install. Some super helpful walkthroughs that I used to install a lift on my 4th gen years ago, and again for the 5100s a few months ago.
I used spring compressors that I rented from autozone. Never had an issue and I must have used them a dozen times over the years working on different setups for my 2004.
Air 4rceRunner One, 04 Sr5
10-05-2015, 04:01 AM
seach you tube for installs on Tacoma's. there are quite a few and its pretty much the same.
01-08-2018, 06:51 PM
Front:
Rear:
Thanks for the info.
Where can I get all the torque specs required for this job? Also some tuts. mention using "tie rod puller", is that necessary?
01-08-2018, 07:34 PM
You can find the torque values on google if you search the specs for the 5th gen.
You also don't need to remove the tie-rod. You get more wiggle room if you do but not necessary at all.
01-08-2018, 07:51 PM
Another recommendation for the no spring compressor method. Could not have been easier.
01-08-2018, 09:02 PM
12-14-2019, 09:31 PM
Real Name: Walt
Real Name: Walt
Shock rotates even after being tightened
After installing my shock and tightening it down as much as it would go I noticed that I could still hand rotate the entire shock. When I tightened it I had a vice grip on the shock and was using a standard wrench on the nut End it will not tighten anymore. But the entire shock body will rotate. Is this normal?
