Old 12-11-2019, 05:39 PM #1
Signess Signess is offline
Signess is on a distinguished road
5100s best for stock ride height?
I'm looking to stiffen up the 4runner a bit and reduce the notorious nose dive, while maintaining the stock ride height. Are B's 5100 the best option for me? How about the 4600s?
Signess is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 05:47 PM #2
sicnarfone's Avatar
sicnarfone sicnarfone is offline
sicnarfone will become famous soon enough
sicnarfone's Avatar
Not sure about the 4600s or what your budget is but if you are looking to upgrade your suspension at a low cost to eliminate the nose drive and improve on-road driving, I recommend checking these two articles out:
1. Bilstein 6112 Front Coilover & 5100 Rear Shock Install on 5th Gen 4Runner
2. Bilstein 5160 & 6112 Complete Guide - Everything you need to know!
Personally, I am going to go with the latter setup. I very much prefer the reservoir set up since I plan on driving fast off-road. The friction created from the shocks going up and down require additional oil to keep it from overheating. And I believe both 6112/5160s have an adjustable lift and can be set at stock height or to your liking.
sicnarfone is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 06:36 PM #3
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
Fox 2.0 performance has a similar option to Bilsteins. Its called the snap ring coil over. Its not really a coil over. Its just the shock that reuses the factory spring.
2.0 Snap Ring Coil-over IFP | Truck Shocks | FOX
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 07:08 PM #4
Daikon's Avatar
Daikon Daikon is offline
Daikon has a spectacular aura about Daikon has a spectacular aura about
Daikon's Avatar
But you don't think having a strut with a front reservoir would be just as important for your style of driving? I'd go with a better set up like king/icon/ fox w/ resi's if that's how you think you'd be driving.
Daikon is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 07:23 PM #5
yota1976's Avatar
yota1976 yota1976 is offline
yota1976 is on a distinguished road
yota1976's Avatar
Does adding lift to the 4runner throw the alignment off any? I've thought about adding 1 inch to the front to level out my TRD OR.
yota1976 is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 08:10 PM #6
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
If you use the bottom clip setting the Eibach shocks they will not lift it. Also, they'll ride great and eliminate the nose dive.
Ryan
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 08:15 PM #7
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
I added Bilstein 5100s front and rear with front set to 0.85. Helped the nose dive, a little firmer on road and way better feel of control offroad.
BobsTrail is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 08:25 PM #8
thedvsmonkey's Avatar
thedvsmonkey thedvsmonkey is offline
thedvsmonkey is on a distinguished road
I'm having a lift installed this Friday . . . they're putting on front and rear Bilstein 5100s and a rear Bilstein coil. I believe the rear is coming up an inch to level things out.
Who Must Do The Hard Things? He Who Can.
2019 SR5 Premium
Magnetic Gray
thedvsmonkey is offline   Reply With QuoteReply With Quote
Old 12-11-2019, 09:01 PM #9
Anything wrong with installing 5100s and setting them to 0.0? Are they the best option for zero lift firmness?
Old 12-11-2019, 09:06 PM #10
Daikon's Avatar
Daikon's Avatar
It isn't about the lift height itself, its because you're disconnecting and removing suspension parts that may cause alignment to be out of spec. It is good practice to always get an alignment post install.
Old 12-11-2019, 09:34 PM #11
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
If you're going fast, why not get a coilover with resi for the front too? (not sure how fast youre planning on going or for how long lol). I tend to average 30-40mph on washboard roads at death valley for 45mins+ and haven't had shocks overheat/fade.
With that experience, I assume you'll have to go much faster on rougher roads for resis to help.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
5100s , height , maintaining , ride , stock
Stock ride height difference spoonmectr 5th gen T4Rs 4 06-22-2018 06:39 PM
Stock ride height Damrunner 4th Gen T4Rs 5 05-24-2017 12:03 AM
stock ride height? newmexrunner 3rd gen T4Rs 2 10-24-2012 03:32 PM
Maintain close to stock ride height with FJ coils/5100s... Chad T 4th Gen T4Rs 21 07-08-2012 04:10 PM
1st Gen - Stock Ride Height illzoni Classic T4Rs 10 10-04-2010 04:14 PM
