Old 12-12-2019, 02:00 PM #16
laqualo laqualo is offline
laqualo is on a distinguished road
Originally Posted by jplinks View Post
i appreciate all the responses, thank you!
nobody has yet to respond to this though - IF i did end up thinking Pro was right for me, should the exhaust be a deterrent? in other words if i ended up not liking it would it be an easy fix?
not at all . Im jealous the 20 has it and my 19 doesn't . Get the pro my man . You will not regret it .
laqualo is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 02:15 PM #17
Jetboy's Avatar
Jetboy Jetboy is online now
Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of
Jetboy's Avatar
Exhaust is a bolt on part. IIRC you could buy a regular exhaust setup for probably around $500 new. It's a non-issue. I doubt you could ever hear the difference from inside, or probably outside.
Jetboy is online now   Reply With QuoteReply With Quote
Old 12-12-2019, 02:41 PM #18
Mountain4Runners Mountain4Runners is offline
Mountain4Runners is on a distinguished road
I was in the same boat as you and decided to go to AG TRDP.
I was also worried about the exhaust but it’s not a hard thing to swap out if you can’t stand it. Most likely, you’ll get used to it and it’ll be a non-issue or like me you may actually grow to prefer it.
As far as the suspension, I test drove an ORP without KDSS, with KDSS, and the pro. Honestly I didn’t notice a huge difference. Although very rare there is potential of KDSS maintenance issues and issues with it leaning in the long run and since there wasn’t a big noticeable difference I came to the conclusion it wasn’t something I needed.
In terms of strictly pro vs orp.. I think the first few years the pro came out there were little differences other than paint and aesthetics, but now there’s a number of other differences like remote connect, dual climate control, JBL audio (the audio in an ORP sucks), LED fog lights, auto headlights, tires, skid plate, and suspension. I figured if you mod up an ORP you’re pretty close to the price of a pro but the resell value of the pro would still be stronger. That being said, I was very close to getting an ORP and it’ll still get you to all the same places the pro will with the same reliability and safety features so you can’t go wrong either way.
Mountain4Runners is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 02:44 PM #19
jplinks jplinks is offline
jplinks is on a distinguished road
I was also worried about the exhaust but itís not a hard thing to swap out if you canít stand it. Most likely, youíll get used to it and itíll be a non-issue or like me you may actually grow to prefer it.
As far as the suspension, I test drove an ORP without KDSS, with KDSS, and the pro. Honestly I didnít notice a huge difference. Although very rare there is potential of KDSS maintenance issues and issues with it leaning in the long run and since there wasnít a big noticeable difference I came to the conclusion it wasnít something I needed.
In terms of strictly pro vs orp.. I think the first few years the pro came out there were little differences other than paint and aesthetics, but now thereís a number of other differences like remote connect, dual climate control, JBL audio (the audio in an ORP sucks), LED fog lights, auto headlights, tires, skid plate, and suspension. I figured if you mod up an ORP youíre pretty close to the price of a pro but the resell value of the pro would still be stronger. That being said, I was very close to getting an ORP and itíll still get you to all the same places the pro will with the same reliability and safety features so you canít go wrong either way.
extremely solid & helpful post..thanks so much
jplinks is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 02:52 PM #20
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
Good to know... those are features I didn't think about. Sounds like the Pro has some features from the Limited trim as well. Those are welcome additions.
Old 12-12-2019, 03:20 PM #21
mteolus's Avatar
mteolus mteolus is offline
mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all
mteolus's Avatar
Edit: BOTH the TRD Pro and the TRDORP do not have dual zone climate control. The JBL audio system is NOT an option on the TRDORP but there is an option for a "premium" sound system, I guess better than stock but not as good as the JBL.
All differences can be see here in this brochure near the bottom in the "Features" pages. Not sure its entirely accurate as it says the Pro will have 15 speakers.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 BFG KO2 C load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, wind fairing, and Hi-lift jack mounts, Goat Armor.
Old 12-12-2019, 05:21 PM #22
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 has a spectacular aura about baldrik78 has a spectacular aura about baldrik78 has a spectacular aura about
baldrik78's Avatar
If you aren't chasing the AG color and you have any thoughts of upgrading the suspension or lifting (it's a serious bug if you are into and you won't be able to stop yourself) - then the ORP is the way to go.
Also I really like the KDSS on my truck. It is super noticeable in long curves at speed, compared to the traditional sway-bar. I'd only skip the option if I was planning to do Long-Travel suspension.
2017 TRD ORP KDSS
Bilstein 5100s - Dobinsons Coils - JBA UCAs - Cooper Discoverer AT3 XLT
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k
baldrik78 is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 05:59 PM #23
DigitalRJH DigitalRJH is offline
DigitalRJH will become famous soon enough
I debated going Pro or ORP last year. The color choices for the 19 pros were lackluster in my opinion so I went with an MGM ORP with KDSS. Iíve made exterior cosmetic mods to it with a couple more needed. I changed the wheels and tires, installed an aftermarket grille, and still need to blackout the bumper valances and do a front end spacer lift to lift the front 1 inch. When those last two items are done Iíll be just under 2K for the total cost of the mods with selling the original wheels, tires, and running boards. Will look identical to a pro for about 8-9K less than the pro would have cost.
DigitalRJH is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 06:21 PM #24
Steel28 Steel28 is offline
Steel28 is on a distinguished road
I have 2020 TRDP which has dual climate controls.
For OP, canít go wrong with any choice but Mountain4R nailed it. 2020 Pro features are huge welcome addition. I also enjoy TRD (made by Borla btw) exhaust roar which is not super loud (I came from driving M and R cars with performance exhausts though ).
2017 Super White TRD Pro - SOLD
2020 Army Green TRD Pro
Steel28 is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 06:39 PM #25
gSwift's Avatar
gSwift gSwift is offline
gSwift has a spectacular aura about gSwift has a spectacular aura about gSwift has a spectacular aura about
gSwift's Avatar
I have the AG Pro, and if it wasn't for wanting the color then I wouldn't have got the Pro.
I mean i've already ditched the wheels, the rack will be gone in a couple of weeks, and as soon as I find a good enough deal on Icon, the stock suspension will be gone too. I get that I probably threw a lot of money out the window, but I wanted the AG and some of the other features that the 2020 had.
And don't let the exhaust deter you since its such a easy fix. I swapped mine out in 30 minutes. Super easy
gSwift is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 07:01 PM #26
Bumbo's Avatar
Bumbo's Avatar
I’m having a hard time wrapping my head around why you would do that? Legitimately curious… are the Fox shocks are a watered down OEM variant or something?
Do you have the Bilstein 6112 or Fox suspension?
Old 12-12-2019, 07:07 PM #27
Dillusion Dillusion is offline
Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice
Originally Posted by Bumbo View Post
Iím having a hard time wrapping my head around why you would do that? Legitimately curiousÖ are the Fox shocks are a watered down OEM variant or something?
Prolly wants the extra lift. (We all know they look better lifted)
He already admitted he just got it for the color which I can see.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 07:08 PM #28
gSwift's Avatar
gSwift's Avatar
Iím having a hard time wrapping my head around why you would do that? Legitimately curiousÖ are the Fox shocks are a watered down OEM variant or something.
I have the Fox and they are fine on the street, can't really give much of an opinion on them off-road since i've only been on some light trails
I mainly want more lift/clearance and going with a long travel setup.
Old 12-12-2019, 07:37 PM #29
Bumbo's Avatar
Bumbo's Avatar
You must be talking about ICONs extended travel shocks which work within the stock geometry, I believe it just recovers a little bit of droop when using their upper control arms. Real long travel is something that completely changes the factory suspension geometry, replacing both upper and lower control arms, shocks, and front axles using a kit from Total Chaos or similar. Itís a significant cost and commitment for off-road use.
Seems like a awful lot of trouble for a little bit of lift, but I get it. You wonít see much of any travel difference between the two either with the ICON system. This goes for pretty much everything until you get into a proper +2 or +3.5 LT setup.
Let me know how much you want for the Fox shocks... ill buy the entire setup from you and throw them on my Limited.
Old 12-12-2019, 10:05 PM #30
gSwift's Avatar
gSwift's Avatar
You got it. Not sure when i'm gonna make the switch but i'll definitely let you know
approx , orp , pro , time , w/kdss
PRO Fox suspension install on 2020 TRD-Off-Road /w KDSS niadh0 5th gen T4Rs 66 04-18-2020 02:26 AM
2020 TRD Premium with KDSS and sliding cargo deck 4xColt 5th gen T4Rs 11 02-20-2020 07:16 PM
2020 anyone put a Pro skid plate on a non-Pro 4R w/KDSS? Phyzman 5th gen T4Rs 21 01-05-2020 08:54 PM
2020 ORP KDSS not listed on Monroney but dealer says itís there Phyzman 5th gen T4Rs 11 11-10-2019 02:08 PM
Will the 2020 off-road have the camers like the 2020 Tacoma? jmichael99 5th gen T4Rs 15 08-13-2019 03:42 PM
