Old 12-12-2019, 01:55 PM #1
robdubbleu robdubbleu is offline
robdubbleu is on a distinguished road
Climate control blows air when 'off'
I picked up a 2016 TEP in August and I'm loving it so far. Got a great deal, too: $30,800 out the door from a Toyota dealer for a Certified example with 53k miles and an aftermarket remote start system (which was not advertised). No mods yet...
Anyway, since I got it in August I'd used the AC every day but now that it's cooled off I'm using heat or have it turned off completely. However, when the fan is set to 'off,' it still blows quite a bit of air. If the temp knob is set to anything higher than a click or two past the mid-point, the warm air that comes out will actually make the car VERY warm. Is this normal operation for the 5th gen? Also worth noting that when the climate control fan is on, it makes a noticeable whine that's audible even over the radio unless the volume is turned up to like 20 (on satellite radio).
Thanks!
'16 Trail Premium | KDSS ✅ | Barcelona
robdubbleu is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 02:11 PM #2
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
Thanks!
if its set to FRESH AIR, and you are moving down the road, yes air will come inside. then depending on where you have the controls, will determine the temp of air coming in.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 02:26 PM #3
Overrunner Overrunner is offline
Real Name: Anthony
Overrunner is on a distinguished road
Real Name: Anthony
I second what Nevada said. The whine in the blower motor is another issue. Pull the cabin air filter for a quick check, and check the motor and fan. I haven't done this on a fifth gen myself, but if its a common squirrel cage type fan, they can become dirty and clog the motor shaft with hair, dust, etc. This usually doesn't happen for many more miles than you have, but may be a quick fix.
Otherwise I have use WD40 dry lube to much success on blower motors in the past when they start to whine. Make sure you disconnect the motor, just in case.
Overrunner is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 03:39 PM #4
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
i remember back in the days, my bmw had a similar issue. turns out it had a bad fan motor resistor. so when it was off, it acted like like it was in a higher speed setting.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 04:33 PM #5
dktxt4r's Avatar
dktxt4r dktxt4r is offline
dktxt4r will become famous soon enough dktxt4r will become famous soon enough
dktxt4r's Avatar
Turn on air recirculation.
Climate control blows air when 'off'-recirc-jpg
dktxt4r is offline   Reply With QuoteReply With Quote
Old 12-12-2019, 05:16 PM #6
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
Thanks!
I get the same thing. I even asked the dealership to check it shortly after I got the truck. They said the blower was turned off when the system was off. I have to assume it is just air being forced into the system while moving down the road. And it definitely heated/cooled based on whatever temp setting the knob is turned to.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 03:05 PM #7
Thanks guys. Confirmed that turning on 'recirculate' stopped the air movement. It's surprising how much air comes through when it's off.
Now I just need to investigate the blower motor and filter.
Thanks!
Old 12-13-2019, 03:29 PM #8
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
My 5th gen blower motor and filter occasionally gets wet at the car wash. This can cause a rusty squeaky blower motor. I changed a blower motor on a 3th gen. It was easy. Only trick was to remove the plastic door threshold when removing the trim cover to access the motor. Motor itself is just three screws and a electrical clip/connector.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 03:30 PM #9
Ripper238's Avatar
Ripper238's Avatar
Anyway, since I got it in August I'd used the AC every day but now that it's cooled off I'm using heat or have it turned off completely. However, when the fan is set to 'off,' it still blows quite a bit of air. If the temp knob is set to anything higher than a click or two past the mid-point, the warm air that comes out will actually make the car VERY warm. Is this normal operation for the 5th gen? Thanks!
My 2019 does the same exact thing. Normal.
Yup, when the blower is off its off. But if the heat is on and blower is off the heat has to go somewhere if its not recirculating air.
But boy does the 4R give off some heat, like my feet feel like they are on fire if i have the heat up just a bit and the blower is on.
Old 12-13-2019, 03:59 PM #10
Thanks!
Try turning the air temp control knob to blue/cold. I believe this will prevent the outside air from being heated when it comes in.
1999 4runner
Old 12-13-2019, 04:23 PM #11
1jzgte 1jzgte is offline
1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice 1jzgte is just really nice
Our vehicles also has the tendency to disable recirculation automatically based on interior humidity to relieve fogging within the vehicle... quite annoying when u dont wanna smell the nasty shit from other vehicles
hold the recirculation for 5 seconds and it'll lock ON
1jzgte is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 04:30 PM #12
nevada's Avatar
nevada's Avatar
my 06 does that too. so annoying!
Old 12-13-2019, 11:34 PM #13
TurkEclipse TurkEclipse is offline
TurkEclipse is on a distinguished road
I need to test this in my 4runner but I dont drive much. In my Lexus it does as you describe. Its weird because it will be "Off" and if its slightly chilly out it will actually heat up the air!. Pushing the recyle/inside air but turned it off. You may want to try that.
TurkEclipse is offline   Reply With QuoteReply With Quote
air , control , fan , radio , turned
Auto climate control on 2001 only blows really hot or really cold sledandski 3rd gen T4Rs 19 10-11-2017 03:17 PM
Hilux Surf climate control = 4runner climate control? CDNsurf 3rd gen T4Rs 4 02-27-2015 08:27 PM
new climate control, will this give me dual climate control? 4Runner8 4th Gen T4Rs 4 10-20-2010 11:33 PM
Auto Climate Control vs. Manual Climate Control JME476 3rd gen T4Rs 2 04-07-2008 01:04 AM
'02 Upgrade standard climate control to auto climate control unit? bradym239 Engines / Suspension / Wheels / Tires / Audio / Accessories 4 06-10-2004 01:37 PM
