08-01-2018, 02:43 PM
Finding/Removing GPS tracker
When I bought my 4Runner from the dealer, they had already added a GPS tracking system from APEX Protect. It came with a year of tracking for free, but I never used it and I'd like to remove it from my car. I'm dealing with a battery trickle when my car is powered off and I'm hoping this helps to narrow it down.
APEX Protect refuses to answer emails and won't offer any removal instructions over the phone (even when I offered to prove ownership). The dealer hasn't been responsive either.
Finding the device is tricky since it only draws power to send a beacon every once in a while. I've tried hunting around with a DC clamp meter but that hasn't helped much. The device has a source of constant power, can receive GPS signals, but it doesn't seem to be connected to any OBD ports.
Does anyone have suggestions on how to locate the device?
2016 4Runner Trail Edition Premium: Icon Stage 2, BF Goodrich A/T KO2, Morimoto XB LED headlights, Gobi Stealth Rack w/no-rise and ladder, Shrockworks rock sliders + skid plates
08-01-2018, 03:16 PM
The following areas would be good places for a GPS to have a sky view which it needs.
Dash near windshield.
Sharkfin - not sure if they could fit it there.
Rearview mirror near windshield. -- not much room there.
Inside the cargo window wiper cover.
All of those places have sky view but only two are fairly clear.
I would think it would be under the dash just for the sake of wiring / view / ease of access / not likely to interfere with other objects.
ETA: I just thought, what if they use the Toyota GPS and simply sample it's signal as needed, then make a cell call. If that's the case, the location may have many more options.
08-01-2018, 03:56 PM
Real Name: steve
Real Name: steve
you may have battery drain because the internal battery in the unit is dead or dying a slow death. lo jack works like this and has its own battery pack. you might be able to find the circuit its on by disconnecting your battery and testing each fuse for 12 volts...ive never done it but it seems logical to me...
" GET THERE FAST BUT ARRIVE ALIVE "
08-01-2018, 04:01 PM
Have any lawyer friends? Have them send a quick note to the dealer on letterhead and they'll respond.
08-01-2018, 04:56 PM
https://www.popularmechanics.com/car...attery-drains/
08-01-2018, 05:22 PM
I messed around under the dash and found this: http://imgur.com/gallery/3gRs1SV
It looks a little unusual and has a green paper with eyelets punched out wrapped around it. It has "5 AMP" written on the black rectangle. It looks unusual but I'll keep hunting.
08-01-2018, 05:23 PM
Originally Posted by Icantdrive55
Sounds like Don McGill screwed you too...
If you remove the panel to the left of the steering wheel, below the AC vent, its right there.
Oh wow. Thanks for that. Got any tips on how to remove the panel? Just clips or are there screws to remove?
08-01-2018, 07:04 PM
Success: https://imgur.com/gallery/qUgulz2
Thanks for the removal tips. That was fairly easy to remove. There was some awfully sticky Velcro there that held it to a panel behind the push button for the AC inverter. I'm glad to have this thing off the car.
The battery is also bulging and feels a bit squishy to the touch. That's a bit concerning as well.
08-01-2018, 07:12 PM
Real Name: Chris
Real Name: Chris
Destroy it with fire. No not really, those lithium batteries are pretty nasty when they burn. I wouldn't want that junk in my truck either BUT do keep in mind that your truck can be located via the in dash GPS system as well. Your cell phone has plenty of tracking crap also. Woman in my office has her IPhone SIRI go off at random and start answering questions when people are talking in the office. If they want to find you, they will find you.
08-01-2018, 08:29 PM
I'd consider telling the dealer. Does the dealer know they are installing fire hazards? Does Toyota corporate?
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
08-02-2018, 10:34 AM
GPS tracker???
That is the same device I have for remote start with the cellphone. Mine has no battery, it is powered from the start module.
-moneypit
2015 Blizzard Pearl Limited
Black leather interior
08-02-2018, 01:35 PM
Banned
Real Name: Mark
Banned
Real Name: Mark
Good job locating this Big Brother device!
Can you share how you actually removed the access panel?
Thanks.
08-02-2018, 01:42 PM
Real Name: BobH
Real Name: BobH
I had a similar device provided by AAA, no battery and if I let the T4 sit for about 2 weeks it would drain the battery enough to cause a no start. If I had left it at an airport for a long trip it would have caused a problem when I returned. Found out when I got home. This happened on two vehicles for us.
08-02-2018, 01:48 PM
Real Name: BobH
Real Name: BobH
How does the panel come off? Screws or push clips?
I'm going to add a Redarc brake controller in a blank switch panel.
08-02-2018, 02:00 PM
If you want to pull back the panel, put your hand in next to the steering wheel and pull back on it. The panel underneath the mirror and lighting controls will pop down far enough to make quick adjustments.
If you need to remove it entirely, remove the bolt on the left side of the panel towards the bottom (near door jamb).
