Old 12-15-2019, 12:59 AM #1
DigitalRJH DigitalRJH is offline
DigitalRJH will become famous soon enough
19 ORP W KDSS, what size spacer to level?
Hi guys, I want to level my OR with KDSS. Was going to do a cornfed 1/2” spacer in the front to lift it 1” but I recently saw in another thread that the rake on KDSS vehicles is anywhere from 2-2.5”. Why would KDSS affect rake? I thought it just affected body roll. If that is the case should I go with a 3/4 or even a 1” spacer? Kind of hesitant to lift the front 2” with the stock shocks though. Thoughts?
Thanks
DigitalRJH is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 10:53 AM #2
osideplayer osideplayer is offline
osideplayer will become famous soon enough osideplayer will become famous soon enough
Thanks
Hey I saw that thread too. Best case scenario is to measure your own car. I measured 2 inches of rake on my 2016 KDSS. Make sure you set tire pressure the same on all four tires and park on a flat surface.
Personally, I want atleast .75 inches of rake, so it doesn't look like I'm squatting when I load up.
osideplayer is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 12:00 PM #3
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Personal I want atleast .75 inches of rake, so it doesn't look like I'm squatting when I load up.
So where is everyone measuring to, the top of each fender opening?
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 12:28 PM #4
Take two different measurements. One from the lower part of your rim to fender and another from the ground. Let me know what you get.
Old 12-15-2019, 01:17 PM #5
TEujunga's Avatar
TEujunga TEujunga is offline
TEujunga has a spectacular aura about TEujunga has a spectacular aura about
TEujunga's Avatar
It's been said before anytime one of these "leveling" threads shows up, but it's worth repeating: the rear wheel well openings are about an inch taller than the fronts. If you "level" so that the fender openings measure equally, your frame will have a reverse rake.
Also, the accepted standard for measurement is from the hub center to the top of the wheel well opening.
2016 Trail Edition w/KDSS - Super White - Toytec - Eibach/Bilstein - Kumho 275/70-17
TEujunga is offline   Reply With QuoteReply With Quote
Old 12-15-2019, 04:22 PM #6
I'm glad you brought this up.... As others were saying KDSS vehicles have 2.5inches of rake and I'm only measuring a 2inch difference from the fenders.
With that said, I probably do have 2.5 rake? Or are you saying I have even less rake. I'm kind of confused.
Old 12-15-2019, 05:25 PM #7
Alright, so I went back to the drawing board. I tapped up my center hub and got a measuring tape. My measurements actually came out different this time.
Front Driver/Pass: 19.5
Rear Driver/Pass: 21.85
Old 12-15-2019, 05:42 PM #8
TEujunga's Avatar
TEujunga's Avatar
"Level" is in the eye of the beholder. It's not an exact science -- for one thing, the amount of time you spend staring at your vehicle when it is sitting at rest on an exactly level surface is brief. Or should be, at least. Lifting the front anywhere between 1" and 2" more than the rear results in what most people consider an attractive stance. I feel like any more than 2" lift in front compared to the rear can result in a negative rake look, especially when the rear of the vehicle is loaded with stuff, but others may disagree.
Old 12-15-2019, 05:45 PM #9
So I stumbled across this thread and saw what you were talking about
"center of hub to top of fender measurements"
Old 12-15-2019, 08:48 PM #10
So my question is what does KDSS have to do with affecting rake? Has anyone compared to a non KDSS OR or TE? I swear looking at an SR5 the front looks like it has a bit more lift than my KDSS OR. I really like the stance of the Pros so that’s why I want to do the 1” in the front but wondering if the 1” on my KDSS will not look the same as the Pro. On an aside has anyone had a dealer install spacers?
kdss , level , lift , rake , spacer
2018 TRD ORP w/KDSS Level/Lift Options ripntear 5th gen T4Rs 26 08-13-2020 02:31 AM
Spacer to level the rear spoonmectr 5th gen T4Rs 3 07-09-2018 03:34 PM
All I want to do is get the front level. What would be the best spacer to use? Jeff T 4th Gen T4Rs 49 08-30-2016 11:52 PM
spacer on top of coilovers to level out rake a little? adam99sr5 3rd gen T4Rs 37 12-10-2012 12:55 AM
Spacer and level question! VBfur-runner Engines / Suspension / Wheels / Tires / Audio / Accessories 16 09-13-2010 03:07 PM
