Old 12-18-2019, 12:40 AM #16
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
Originally Posted by mteolus View Post
Not so far. Just a note on installing the tracbar, just make sure when you are lifting the diff that you don't lift it too high so as to lift the vehicle off of the jackstands which will be on both sides since both wheels will be off. The jackstands need to be very strong too. Also make sure it is a very robust hydrolic jack you use to lift the diff that won't easily roll. Put chocks in front of both front wheels as well. Be careful, it's not like changing a tire, if the vehicle falls off of the jackstands it will hit the ground. I can tell you these things from experience. :-)
I had no issues installing my Trac bar with the truck on the ground and the wheels on. Am I misunderstanding something about your install? I don't have a spare tire underneath maybe that helped?
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 01:14 AM #17
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
Originally Posted by Globetrotter78 View Post
Ok, so next consideration is the need for gussets on the OEM spindles? Is that something any of you have done or seen a failure of due to hard offroading. I'm in VA so no baja level craziness btw.
I believe in the spindle gussets after my incident, I have a set welded to be installed but needs to be powdercoated first. I got jammed going around a steep declining corner ravine wall and it was not a hard impact at all but just enough pressure to bend my spindle. Yeah I should of trusted the line from the guy in front of me, my poor decision. Luckily I was able to drive home with some serious negative camber but I had to road hazard my tires as well. Total Choas gussets and cam tabs would be a good choice to go with after you Skid row it. PM me if you are serious about gussets, there are a few Tacomaworld guys that can do the welding but they will need your stock ones as cores.
All great suggestions on this thread!
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 10:29 AM #18
Globetrotter78's Avatar
Globetrotter78 Globetrotter78 is offline
Globetrotter78 has a spectacular aura about Globetrotter78 has a spectacular aura about
Thanks gang! I guess front armor will be the priority and work my way back. I already have the sliders. I may grab some gussets as well since I have a buddy that has an auto fab shop and can weld them properly. Where I live, most of the trails and such are several hours drive so better to address potential weaknesses BEFORE they make me limp home.
*2018 White SR5 4x4, Icon 2.5 Exten Travel w/ res, JBA High Caster UCAs, 1.25 Spidertraxx, SSO Sliders and Bumper (on route), Icon Rebounds and 285/70 Falken Wildpeak A/Ts
*2013 Maserati GranTurismo Sport
*2013 Fiat 500 Abarth- the rocket powered go-kart!
Globetrotter78 is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 09:44 PM #19
Kaleo Kaleo is offline
Kaleo is on a distinguished road
Cam tab gussies
If going with cam gussies Take a look at the new Marlin crawler cam tab gussets. They look beef and a better design.
Kaleo is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 12:32 AM #20
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
Pictures???
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 09:08 AM #21
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
I'm looking for some rear shock guards. I hit mine pretty good on rock (no damage) but want to beef up that area.
Seeing a couple examples online:
BPF 4runner 04-19 /FJ 07-14 Shock Guards
RCI Off Road | 10-Current Toyota 4Runner Rear Shock Mount Skid Plates-SDHQ
ICON 07-Up FJ Cruiser / 03-Up 4Runner Stainless Steel Lower Shock Shin Guard | POLY PERFORMANCE
Shock Skids for King Shocks |
2010-2019 5th Gen Toyota 4Runner - Lower Shock Guard - Pair – Rago Fabrication
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 01:39 AM #22
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold SpeedyKevin is a splendid one to behold
Originally Posted by EddieV4runnin View Post
Pictures???
Much thanks to Kaleo! Couldn't resist after seeing them. Just got them installed today. Super beefy!
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
SpeedyKevin is offline   Reply With QuoteReply With Quote
armor , build , novice , rear , trail
Oil based paint on softex ellroy2 5th gen T4Rs 3 09-04-2019 04:32 PM
FS : Custom Decals , based in VA. HMGT4R For Sale: Non-T4R Items 20 05-25-2017 10:57 AM
Lexus Based on 4runner jwatson General Discussions 24 10-03-2016 11:12 PM
What's the best lift around-based on value and performance AZrunner11 5th gen T4Rs 3 08-03-2013 01:31 AM
