01-23-2020, 04:14 PM
Aftermarket Locker + ATRAC
Been starting to really think seriously about purchasing and installing a rear EATON E-Locker (They are now available for 5th gens). Curious to hear about real world experiences of folks who are running an aftermarket rear locker and if they are able to use ATRAC effectively with the front wheels? Does it work? Or does ATRAC interfere with the rear wheels when the locker is engaged?
Ideally the aftermarket locker would give 50-50 in the rear and ATRAC wouldnt detect a variance in the wheel speeds and instead focus on the front wheels in low traction situations.
'12 Silver 4Runner SR5: 14+ facelift, CBI front, CBI Rear, Warn EVO 10-S, ARB Snorkel, Baja Designs 30" S8, Squadron Sports, S2 Rack Lights, King 2.5 Suspension, OME 899, 33" Cooper ST Maxx, Full CBI Skids, Metaltech Sliders, GFC Tent, ARB Awning
Xtremluck's 2012 SR5 Build Thread
01-23-2020, 04:32 PM
I have the factory E-Locker. Not going to say Atrac replaces it but when I turn it on on some obstacles (w the rear locker), it just walks over the obstacle no issues. Not as smooth with Atrac off so yea it does still work on the front axle.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
01-23-2020, 04:41 PM
ATRAC is very simple. The computer senses if there is a difference in wheel speed between two apposing wheels, and if there is, it brakes the wheel spinning the fastest.
With a locker engaged, both wheels spin simultaneously so therefore ATRAC won't even kick in on the rear. For the front it will still do its thing.
01-23-2020, 04:56 PM
I hope to have an answer for you in the next 3 or so weeks. I have a Harrop 11114 sitting in my garage.
01-24-2020, 09:10 AM
Real Name: Dave
Real Name: Dave
Don't know how the Eaton system works but with a ARB Air Locker both work. They simply don't know the other exists.
Them Be Me Mods - 2011 Black Limited / Trail Mutt
01-24-2020, 10:38 AM
Awesome that is what I was looking for. It works very similar to the ARB but it's electrically actuated instead of air. Thanks for confirming
01-24-2020, 10:52 AM
It is a selectable locker like the ARB but they actually work a little differently.
The elocker takes a couple feet to engage vs the ARB is instantaneous.
When swapping between forward/reverse the elocker unlocks for a couple feet before reengaging.
And your not supposed to thrash on it when the elocker is trying to engage for those couple feet or you could wear/ break it apparently.
But you don't need to buy a compressor (although one is handy to have for tires) and don't need to worry about seals blowing out (though if you regulate the input pressure it seems to lessen that problem).
