12-17-2019, 08:18 PM
When is a lift too much?
My next upgrade is a Dobinsons 2-2.5” lift. One of the options is long-travel struts/shocks that provides a 3” lift. It’s an $80 upgrade for the entire system, front and rear, to go with this system. Any downsides you can suggest to the extra inch of elevation?
CoG is the first thing that comes to mind with vehicle lifts, but happy to hear what else may be a consideration in your mind.
~Chris
2019 MGM TRD ORP
BFG KO2 265/70-17
Dobinsons C509-302/GS59-700, C59-505/GS59-705, UCAs
Victory 4x4 Blitz Bumper w/Zeak 12000
12-17-2019, 08:29 PM
~Chris
"When is a lift too much?"
When your CV angles are too much
When you lost all your downward travel (droop)
When you lift on the stock geometry, you don't gain more travel, you just move the center-line of the stroke.
While the additional height is nice, and you have more room for compression over bumps, don’t discount the importance of downward travel (droop) as it is also important to suspension performance.
As an example, If you drive over a pothole and don’t have enough droop, that is the difference between the truck falling into the pothole, vs just the tire.
That said, I don’t think a 2-2.5” lift is too much, I think that is a good place to be if you off-road. If you don't 1.75 to 2" would be my max. That shock won’t provide you with more travel… I think the “long travel” naming is more marketing. The shock is just setup for a different ride height / change in center-line from the lift. You will give up droop for compression. You have a fixed length of travel unless you are changing arms and the suspension geometry.
12-17-2019, 08:36 PM
When the CV angles go south (more wear) and lose of downtravel ( I think stock is around 4 inches). Also, if you get the rear long travel shocks (I think its 28.75 inches extended), I believe you'll need new lower/upper links.
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
12-17-2019, 10:12 PM
You be fine.
2018 TRD OFF ROAD
My Build
12-17-2019, 11:05 PM
to clarify, that only applies to coilover/ coilover spacer lifts, which seem to be the most popular 4runner lifts. there are body lifts that do not affect the suspension geometry, however they leave the middle of your under body guts with the same ground clearance until you add larger tires.
then there are the "cross member lifts" (pretty sure I have the name right) where you essentially put a spacer one the mounting point of your lower control arms and add a longer coil over. the LCA's sty close to the ground, but add clearance to the rest of the under body as well as larger tire options.
If you want to go huge with out losing travel, combine all 3 types and you fit right in on Hawaiian islands. those guys love 6+ lifts.
Troner envy... the struggle is real!
12-18-2019, 09:11 AM
Appreciate the feedback. For least heartache, I suspect a 2” lift is probably going to be more than enough. Minimizes the need for significant geometry countermeasures. I’ve seen a couple of taller ones that look pretty darn amazing. But watching a variety of 4Runners on YouTube, they do great things with minimal modification. Reckon I’ll start small and see where life takes me.
2019 MGM TRD ORP
BFG KO2 265/70-17
12-18-2019, 12:13 PM
Appreciate the feedback. For least heartache, I suspect a 2” lift is probably going to be more than enough. I’ve seen a couple of taller ones that look pretty darn amazing. But watching a variety of 4Runners on YouTube, they do great things with minimal modification. Reckon I’ll start small and see where life takes me.
Seriously there’s no where in Wisconsin you can’t go now. Lived in Packerand for 21 years. We had a stock Jeep Wrangler that handled anything terrain wise. Mud is the only hazard we got stuck in at all. Higher also means poorer MPG on road.
BTW: While the lifted look is appealing, your balls wont hang any lower, but I’d go for it anyway. . “Image is everything” as the old Cannon commercial used to say.
Have fun with the project and post a pic when done.
12-18-2019, 12:54 PM
I'd highly recommend going with the Eibach lift adjustable shocks up front and the matching rears if you want to stay around 2" or a little less. Love mine. The ride is great, they can go up to 2.5" and they reuse you're stock springs. If you want to go 2.5" or up, I'd just buy the whole kit with their springs.
12-18-2019, 02:17 PM
ahahahha this is hilarious. when i was in hawaii a few months ago i took these two pictures because they were so ridiculous
12-18-2019, 03:11 PM
Last time I talked to a Dobinson's seller they didnt have a "true 3in" lift option...
2012 Salsa Red Trail with KDSS
5100's with lift,285/70/17 Duratracs,some extra wattage and speakers in the stereo system.
2003 Chevy Tahoe 4x4 - 20in Rep's, lowered and loud 4x4
2002 Ford Crown Vic Sport - new project
12-18-2019, 03:24 PM
Will echo what everyone else mentioned about CV angles, in my personal opinion anything nearing the true 3" of lift mark is a bit too much. 2"-2.5" is IMO a great lift for these to hold onto whatever you can of "factoryish" ride and handling characteristics.
| - 2016 Turd Bro - |
SSO Slimline / x20 | Dobinsons 314/327 - Airlift 1000 | Gobi Stealth Rack W/ Ladder | Dobinsons Snorkel | All Pro Sliders | Shrockworks Rear Bumper | 285 BFG KO2
12-18-2019, 03:44 PM
Hilarious! Like street machines with knobbies...
Pair of '17 Runners:
TRD Pro Cement -- MetalTech OPOR Sliders | Frontrunner 3/4 Slimline II | GTR Carbide LED Headlights | Morimoto 4Banger HXB fogs
SR5 Super White -- C4 LoPro, C4 Rear Single Swing | Superwinch EXP | Extreme LED X6S and X6 | MetalTech OPOR Sliders | Frontrunner full length | MetalTech Lower Links and guards | ICON Stage 4 w/ overland springs | AFE intake | Falken Wildpeak A/T3W 34x11.5x17 | GTR Carbide LED Headlights | Morimoto 4Banger HXB fogs
Real Name: Reinout
Real Name: Reinout
Ugh: WHY!!!!!!!!!!!!!!!!!!!!!!!!!?
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
12-18-2019, 03:58 PM
at 3 inches, the 4runner starts to ride like shit, but it look oooh so good.
12-18-2019, 06:16 PM
I decided not to use those exact words in my post, but I was thinking it when I wrote it.
Once you get to that height you really need to step into a mild +2 LT kit if you want to maintain performance. Fact of the matter is most people don’t want to pay that much to do it right, so they end up with a crap ride and just live with it.
Not saying there is a right or wrong way, but there comes a point where you make significant sacrifice to get that height.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
