Old 12-19-2019, 10:49 AM #1
Victory 4x4's Avatar
Victory 4x4 Victory 4x4 is offline
Official Vendor
Real Name: Cam
Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of Victory 4x4 has much to be proud of
Official Vendor
Real Name: Cam
Aluminum Full Front Bumper in Stock!! Will work with 2020
If you are looking for a full front bumper and want it quick, we have one aluminum Front Strike Bumper in stock! It currently has no tube work and is bare, but we can add tube work and powder coat no problem!
No tube work option will not interfere with 2020 TSS.
Weighs about 60lbs
Strike 4Runner Front Winch Bumper | 5th Gen (2014+)
When you need extra tire clearance, maximum protection, plus recovery options for your 4Runner; our Strike Series front bumper is a perfect choice. This made in the USA bumper features an integrated 20" lightbar mount, 3/4" recovery tabs, plus provisions for many industry-standard winches. The bumper is available in a 2 stage satin textured black powder coat over durable zinc primer finish, or in bare metal.
  • CNC cut and formed from .188" steel or .250" aluminum.
  • Compatible with most 8-10k non-integrated solenoid or removable selenoid winches.
  • Built-in provisions for cube lights.
  • Built-in provisions for a 20" light bar (22" max mounting width.)
  • Requires cutting part of the factory plastic bumper cover.
  • Hardware Included.
  • Will work with the TRD skid plate.
  • Will not work with Limited models.
  • Proudly designed and made in the USA.
4Runner Front Winch Bumper | Strike | 5th Gen (14+) - Victory 4x4
4Runner Front Winch Bumper | Strike w/ Tube | 5th Gen (14+) - Victory 4x4
Aluminum Full Front Bumper in Stock!! Will work with 2020-v4r5fs-0_3-jpg  Aluminum Full Front Bumper in Stock!! Will work with 2020-v4r5fs-0_4-jpg  Aluminum Full Front Bumper in Stock!! Will work with 2020-v4r5fs-t_3-jpg  Aluminum Full Front Bumper in Stock!! Will work with 2020-v4r5fs-t_1-jpg  Aluminum Full Front Bumper in Stock!! Will work with 2020-v4r5fs-t_2-jpg  Aluminum Full Front Bumper in Stock!! Will work with 2020-76a11863-90a0-485b-9582-f457bb7a73de-jpg
17 SR5 - BDS | Falken | Mamba | Free Spirit | Warn | Factor 55
Offering quality steel and aluminum goods for Toyotas | Victory 4x4
@victoryrunner
Victory 4x4 is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 05:20 PM #2
4R4Trout's Avatar
4R4Trout 4R4Trout is offline
4R4Trout will become famous soon enough
4R4Trout's Avatar
Any chance of making one with full hoops for the 2010-2013 pre-facelift 4Runners, aluminum or metal?
2012 TE~Shoreline Blue~KDSS~Nav
ARB Diff Breather, Dobinson 302/700, 327/701, Yokohama Geolandar MT G003 255/75R17, ARB CKMA12 onboard air, IndeFlate, Arclight LED, Victory 4x4 Strike rear bumper, Kenwood TM D710GA Ham Radio, Engel MT-45, Method 701 (Black) UpTop Overland Bravo, 38” Extreme LED lightbar, Dobinson UCA
4R4Trout is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 08:58 PM #3
jrandom's Avatar
jrandom jrandom is offline
jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all jrandom is a name known to all
jrandom's Avatar
Like the design, I too would be curious to see what this looks like on a pre14.
That washer relocated? or covered, if covered... dope work
2013 TE w/ KDSS Nav
=-> Get yer Custom "Trail" Edition Emblem/Badge 3d Print here! or maybe you just want to go "Pro"
jrandom is offline   Reply With QuoteReply With Quote
Old 12-20-2019, 12:11 AM #4
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Honestly, with the height of the hoop, I’d be surprised if it interfered with the TSS sensor array as that sits below the “Toyota” text in the lower grille.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 12-20-2019, 12:06 PM #5
Official Vendor
Real Name: Cam
Official Vendor
Real Name: Cam
We may get there! I'll talk to engineering. The washer bottle gets covered.
@victoryrunner
Old 12-20-2019, 04:37 PM #6
JA50N JA50N is offline
JA50N is on a distinguished road
Not a fan of the angled mount for the winch fairlead. it looks like when the cable/rope comes off the winch on a straight horizontal pull it will be rubbing on both the top and bottom of that hause fairlead. With this design, if the nose of the truck is up and you are pulling at a slight downward angle like when you cresting a hill the cable/rope has a chance of rubbing the sharp 90 degree edge of the back side of the fairlead. Not good for synthetic line or cable.
Is there a reason that it was chosen to mount this way instead of vertical?
JA50N is offline   Reply With QuoteReply With Quote
Old 12-20-2019, 06:15 PM #7
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
It’s a great looking bumper, but it still requires cutting the plastic front. Need more no cut options.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 01-30-2022, 10:27 AM #8
Mah824runner Mah824runner is offline
Real Name: Sean
Mah824runner is on a distinguished road
Real Name: Sean
Pre 14 front bumper winch mount
I like the look of my 2012 front end. I just wish I could find a bumper/ winch mount that looks similar to the stock and won’t change the front looks.
Surely there has to be one out there somewhere?
Mah824runner is offline   Reply With QuoteReply With Quote
Old 01-30-2022, 01:11 PM #9
jrandom's Avatar
jrandom's Avatar
OG 5th gen FTW
bud built has a pre-ugly hidden winch mount, I have one, it gets the job done.
Hidden Winch Mount | 10-13 4Runner | BudBuilt
2013 TE w/ KDSS Nav
bumper , front , provisions , tube , work
Southern Style slimline front bumper on 2020 (with TSS)? TexasEagle 5th gen T4Rs 6 06-23-2021 11:30 AM
Aluminum Front Integrated Winch Bumper | TWO IN STOCK! Victory 4x4 5th gen T4Rs 84 04-18-2020 04:58 PM
Stock 4Runner with the addition of an aluminum front bumper MrGainzz 5th gen T4Rs 0 02-15-2019 02:13 AM
5th gen, stock aluminum front bumper, Phx, AZ FREE +$shipping YOLO Free 1 01-07-2018 05:12 PM
Will the aluminum look piece on rear bumper of 03-05 work on 06-09? 8086bruce 4th Gen T4Rs 2 06-19-2010 10:23 AM
