Old 12-19-2019, 03:20 PM #1
hbrogers hbrogers is offline
hbrogers is on a distinguished road
2020 TRD ORP - Suspension Upgrade Options
I'm considering upgrading suspension on my 2020 TRD ORP and have a few different setups in mind but want opinions on what would be appropriate given the other items I'll have loaded and other accessories I'll have on it. Goal is to keep as close to stock appearance and add least amount of added weight possible. My plan is to add the following: Slee sliders, hidden winch mount, Warn Zeon 10S platinum, small flat rack (Front Runner, Rhino, Yakima, LFD, etc...), 1up 2 bike rack, aluminum skids (wondering if this is overkill).
Any info (good and bad) you have on possible suspensions setups I list would be greatly appreciated. I'm considering the following:
- Bilstein 5100s on all four corners
-set at .85"F/stock R
-set at 1.75"F/1"R spring
- Bilstein 6112F/5100R
-set at 1.75"F/1"R
- Dobinson's
-no clue what to get that would be equivalent to Bilstein setups
What I'm wondering is what's the best for my intended purposes of riding trails like GA Traverse or the southeast sections of the Trans America Trail. This will also be a daily driver. Lastly I'd like to not have to invest in UCAs, diff drop, extended break lines, etc...
And yes, I know there is a search function and I have looked at a lot of threads/posts, but want specifics about the products I listed and for my intended purposes as well as other possible products that would give same or similar results.
2020 TRD ORP - Silver / TRD Pro Wheels - Black / Continental TerrainContact A/T - 265/70R17 / ARB Diff Breather / XenonDepot XTR HID Philips XV2 48K - Low Beams / XenonDepot Xtreme LED Pro - High Beams
hbrogers is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 03:33 PM #2
snowpeak snowpeak is offline
snowpeak has a spectacular aura about snowpeak has a spectacular aura about
I'm interested to hear the wisdom of the forum on this question. I have similar plans in mind, and considering the 5100s or 6112s but I also want to make sure with the added weight of my mods that I'm purchasing the right suspension components. Daily driver as well!
Can I tack on one question? MUST I replace the rear spring if rear adjustable shocks are set to 1"?
2020 TRD ORP — MGM, KDSS, Billstein 6112 (2”) front, Billstein 5160 + 1” rear, C4 sliders, 275 WildPeaks, Rago rear window panels, GOBI stealth rack, HID low and LED high beams, SS3 sport yellow fogs, ARB single compressor, rock lights
snowpeak is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 04:04 PM #3
Given my limited knowledge and from what I've read, I believe the rear shocks aren't adjustable. You'd just need specific spring to give you desired lift you're looking for.
Old 12-19-2019, 04:46 PM #4
aznxpsyko aznxpsyko is offline
aznxpsyko is on a distinguished road
That is correct. The fronts can be adjusted by the shock, but it's a PITA for the Bilsteins as you'd need to remove the assembly to adjust the snap rings. To add height to the rears, you need to upgrade the springs or add spacers.
I'm running a 6112/5100 set up and it's pretty good so far
aznxpsyko is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 04:56 PM #5
Danthefitman Danthefitman is offline
Danthefitman is on a distinguished road
Same here. I have Kings, and the only adjustments I can make to the rears are the dampening on the resi's. Luckily rear springs are not all that expensive.
2020 SW ORP - King 2.5" suspension w/ adjusters | JBA Uca | Dobinsons C59-677v | Alpharex Pro Headlights w/ HID Lows | Baja Designs Squadron Sport Ditch lights & Fogs | SCS F5 17x8.5 -10 | Nitto Ridge Grapplers 285/70/17 | Victory 4x4 full length rack | C4 Hatch Ladder | C4 Fab Low Pro w/ High Clearance | Rigd Ultraswing | RSG Sliders | Custom Drawers | MXT275
Danthefitman is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 05:10 PM #6
sicnarfone's Avatar
sicnarfone sicnarfone is offline
sicnarfone will become famous soon enough
sicnarfone's Avatar
I am curious to know your guys' take on 5160 vs 5100. I've read into it and understand that 5160's come with reservoir for additional oil to the shocks but at what point is it beneficial to go to 5160s from 5100. Mine is also a daily driver but do mild off-roading about twice a month.
sicnarfone is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 05:53 PM #7
Someone told me that the 5100s wouldn't handle all the accessories with the added weight I was planning on adding. Any opinions on that?
Old 12-24-2019, 02:12 PM #8
SKT_07 SKT_07 is offline
SKT_07 will become famous soon enough
Subscribed, as I'm going for the 'OEM-plus look' and would like to mitigate the excessive factory rake.
Does a level/lift impact the Toyota Safety Sense (TSS) or Active Cruise Control (ACC) on the '20 4Runners?
I've heard that lifted Tacoma's are having issues...
SKT_07 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:25 PM #9
tacoyota tacoyota is offline
tacoyota is on a distinguished road
You are adding quite a bit of equipment up front. I recommend going with a 2.5 inch shock up front to control and dampening. Icon/King/Fox 2.5 up front with dobinson or eibach springs front and 2.0 shocks with custom lift/rate dobinson in rear. The eibach pro kit just came out so you might want to check that out for a step up from 5100s as well. I think they are still $700 right now. The 5160's tend to leak. If you are going to fork over cash, its better to skip the upper tier bilstein and use top tier name brand shocks. As for the lift height, most people seem to be fine lifting the front 2.5 inches on stock UCA's. You may want to just lift 2 inches to be safe if you want to keep a good caster degree to prevent squirrely driving if it is your DD. Hope this helps!
2017 TRDORP White | 275 KO2 on Stock Rims | Stock Stereo with JBL GX302/GTO638/938, Kenwood KSC-SW11 | DDM 35W HID Ultra | Shrockworks Step Sliders | FR 5100s @1.75 RR Daystar 1.5 | Victory 4x4 Rack
tacoyota is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:37 PM #10
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
Eibach is soon to release rear adjustable hieght springs. That's what I'm waiting on to get rid of the stupid drivers side lean. My 19 was off 1/2" and the 2020 leans 3/4" in the rear
ForRun is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:39 PM #11
FoCo-4Runner's Avatar
FoCo-4Runner FoCo-4Runner is offline
FoCo-4Runner is on a distinguished road
Tundra’s were having the same issues. It’s was what ultimately made me decide to buy another 4Runner and pull the trigger on a 19 vs 20. I didn’t want to risk having similar problems knowing I was going to immediately lift it.
Doesn’t sound like really any issues of not though in regard to TSS. The new head unit is another story though.
2023 TRD Pro Solar Octane:
2019 TRD ORP Mag Grey (sold), 2014 SR5 Mag Grey (sold), 2010 SR5 Pearl White (sold)…if you can’t tell I love 5th Gens.
FoCo-4Runner is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:41 PM #12
ForRun's Avatar
ForRun's Avatar
Eibach just posted yesterday. It's still in R&D. Just had his donor vehicle in his shop
Old 12-24-2019, 03:17 PM #13
Oh the old original version must be the ones on sale. Yes I am totally waiting on the rear adjustable solution!
Old 01-04-2020, 09:39 AM #14
@hbrogers Any updates?
Curious on which route you are going?
Old 01-06-2020, 07:23 PM #15
Thanks for the input. I've been looking at doing the Fox 2.5 up front and 2.0 in the rear but would I be able to do just 2 inches up front? I'd really like to not have to spend more money on UCA but understand if that is a necessity. I definitely will need good caster since it's DD.
add , bilstein , products , set , setups
PRO Fox suspension install on 2020 TRD-Off-Road /w KDSS niadh0 5th gen T4Rs 94 11-23-2022 12:28 AM
2019 / 2020 Fox shock SPRING replacement options? jamoc 5th gen T4Rs 11 02-24-2021 01:33 PM
2019 TRD Pro Fox Suspension on 2020 TRD-Off-Road niadh0 5th gen T4Rs 11 09-12-2019 05:41 PM
high mileage suspension upgrade- practical options madcanvis 3rd gen T4Rs 5 02-19-2015 08:29 PM
