Old 12-19-2019, 07:20 PM #1
Horsethief Horsethief is offline
Horsethief will become famous soon enough
Has anyone had the 4.0 engine noise turn out to be an actual problem?
2013 Trail, currently at 97k miles.
I've spent hours reading all the threads on the 4.0 noises, but I just have a hard time mentally accepting that it's "normal" for a engine to sound like it has a rod knock.
I see some people say it does it sometimes, or all the time, or only until it warms up.
Mine always does it, regardless of the temperature or whether it's warmed up or not. The thing can be running for hours and sound the same as right after a 20* cold start.
I swear it didn't do it when I bought it with 79k in Feb, I probably would have ran, not walked away from it had I heard that.
Don't know what it had in it for oil when I bought it, I changed it with M1 0W20, and it made no difference. I just changed it again, this time with Valvoline full syn 0W20, and it sounds the same. 10k OCI.
Anyone have it actually turn out to be some issue?
Horsethief is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 07:29 PM #2
drewsro's Avatar
drewsro drewsro is offline
drewsro will become famous soon enough drewsro will become famous soon enough
MY GARAGE
drewsro's Avatar
MY GARAGE
Do you have a video of the sound?
2012 Shoreline Blue TE
drewsro is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 08:18 PM #3
Yeah, on my phone. I'll try to post it later on.
Someone in one of the other threads posted a link to his YT vid that sounds just like mine.
Old 12-19-2019, 09:09 PM #4
pDubs's Avatar
pDubs pDubs is offline
pDubs is a jewel in the rough pDubs is a jewel in the rough pDubs is a jewel in the rough pDubs is a jewel in the rough
pDubs's Avatar
106k miles here. Same sounds you are describing
2014 SR5 Premium
Cornfed 1" front level - TRD Pro wheels - Prinsu Full Length Rack - 265/70 Falken Wildpeak AT3W - 1.25" wheel spacers - Full RCI skids - RSG sliders - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 12-20-2019, 12:04 AM #5
zonzin's Avatar
zonzin zonzin is offline
zonzin will become famous soon enough zonzin will become famous soon enough
zonzin's Avatar
See this thread:
Engine noise sounds like diesel at idle
zonzin is offline   Reply With QuoteReply With Quote
Old 12-20-2019, 12:28 AM #6
Originally Posted by zonzin View Post
Yeah, I was looking at that earlier, and other similar threads.
Mine sounds just like the one in that video.
Old 12-20-2019, 12:26 PM #7
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough Jivewalker is a jewel in the rough
Jivewalker's Avatar
Ive been driving mine since new, at 187,000 miles now. I can say without a doubt that the noise in mine gets louder the longer it is since the last oil change. I started doing 5k changes based on that. I'm sure some will disagree with the 5k OCI, but like I said, without a doubt, I hear it get noticeably louder around the 5k mark. I've used all of the mainstream oils and landed on the TGMO when I was able to get the dealer to give it to me for around $6/qt.
2012 TE w/ KDSS, Black, 265/70R17 C KO2's, 192,000 miles
Inside Fishing Rod Holder Mod
"How can you shoot a poor innocent 3-legged cat?"
"Easy, you just don't lead him as much..."
Jivewalker is offline   Reply With QuoteReply With Quote
Old 12-20-2019, 02:41 PM #8
michalik.piotr6837's Avatar
michalik.piotr6837 michalik.piotr6837 is offline
michalik.piotr6837 will become famous soon enough
As long as its on warranty, I donít care. Hope it granades right before warranty is up.
michalik.piotr6837 is offline   Reply With QuoteReply With Quote
Old 12-20-2019, 02:47 PM #9
pDubs's Avatar
pDubs's Avatar
Do you check the oil level? Your truck may be burning oil, and the full amount you put it when changing is what is making it more quiet.
2014 SR5 Premium
Old 12-20-2019, 05:10 PM #10
Jivewalker's Avatar
Jivewalker's Avatar
Doesn't use oil at all, good thought though. I have no concerns with it at this point after driving almost 200,000 miles, it's normal. There was a mechanic or engine guru on here once that said it's just the nature of the engine, something to do with tappets and roller lifters or something. He described why it makes noise and it made sense.
Old 12-31-2019, 06:20 PM #11
Ok, haha, I guess I'll just have to learn to live with it.
I changed the oil a few hundred miles ago, Valvoline full syn 0W20. No change, makes the same noises.
I saved some of the old oil for analysis, I'm going to send it to Blackstone soon.
I may bite the bullet next time and spend the $$ on the Toyota branded oil to see how that does.
Old 12-31-2019, 06:33 PM #12
Hammer0313's Avatar
Hammer0313 Hammer0313 is offline
Real Name: Buck
Hammer0313 is on a distinguished road
Hammer0313's Avatar
Real Name: Buck
In my other engines using a thicker oil always helped with engine noise, try using a 0w30 or 5w30 next oil change and see how it goes. Itís only 1 only change, worth a shot.
2019 TRD Bone Stock
Summer: Amsoil 0w30 - QSUD 5w30
Winter: Amsoil 0w20 - QSUD 0w20 - Toyota 0w20
Diffs: Amsoil Severe Gear
Hammer0313 is offline   Reply With QuoteReply With Quote
bought , engine , sound , time , turn
Replacing the actual check engine light Padre 3rd gen T4Rs 4 06-22-2019 03:11 PM
VSC TRAC/VSC OFF/CHECK ENGINE. Would like some actual answers Rancho5 3rd gen T4Rs 13 05-08-2018 06:50 PM
Engine noise problem...need help Thai General Discussions 4 02-18-2018 04:41 PM
Problem with unusual noise from engine compartment rutledj 3rd gen T4Rs 5 07-23-2012 03:54 PM
Squealing noise when I turn on the ac samdajellybeenie14 3rd gen T4Rs 11 03-28-2012 09:53 PM
Copyright © 2019
