Old 11-17-2020, 03:44 PM #106
NW.OH.T4R NW.OH.T4R is offline
Real Name: Jason
NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough NW.OH.T4R is a jewel in the rough
Real Name: Jason
Originally Posted by Jetboy View Post
Driving while it's snowing. Particularly in the very heavy snowfall periods when it's also kinda warm out. We see that fairly frequently in Utah. Somewhere further north it might be -5* and snowing - the snow won't stick to the headlights. But when it's 28* and snowing heavily - it gets pretty bad pretty fast sometimes between the snow buildup on the lights causing the light to scatter and the brighter and more reflective light from the HIDs.
Got it. We see a fair amount of lake effect snow, so I should be able to get an assessment of this assuming it snows sometime this year unlike last year.
NW.OH.T4R is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 02:11 AM #107
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Just noticed that there is a new version of the Morimoto 2Stroke LED - v 3.0.
Morimoto 2Stroke 3.0 LED Light Review and Test - Nothing Else Like It - YouTube
Couple of interesting things.
1) The LEDs now come far closer to approximating the width of the filament in a halogen bulb. The distance between emitters is 2.0 mm thick, which is ~1 mm thinner than previous best-in-class, and getting pretty close to the ~1.5 mm that filaments are in halogens.
That will go a long way to addressing the complaints about beam pattern that have been brought up in this thread on other LED bulbs. Need a test to see how much.
2) The cooling uses the air in the housing, not behind the light, to manage temperature, so you will now get the benefit of the heat from the light helping to melt snow etc. on the light in the same way as a halogen.
3) There's some interesting design around adjusting the light at install time too.
Cool engineering. Hoping to see some tests on how it does at addressing beam patter.
rageandlove is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 03:02 AM #108
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Yep this one will be interesting to see. The new Osram black chips allow for a very thin blade between emitter faces. I'm a little wary of them saying they will able to warm headlight housings with any significance- convection will require a lot more heat than radiant infrared light from incandescent bulbs to accomplish the same snow melting capabilities.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 12:43 PM #109
Yeah, I had the same thought about the warming in that it might be a 'marketing story' more than reality.
Also, I can't tell if they would actually be a solution for high beams, even if you bought one of those DLR setups that deals with the signal.
Old 11-26-2020, 02:16 PM #110
I think I saw that these will only perform DRL duty with reduced voltage input. Our trucks use PWM (pulse width modulation) so it probably won't work.
-Tory
Old 11-27-2020, 11:16 PM #111
supratt's Avatar
supratt supratt is offline
supratt will become famous soon enough
supratt's Avatar
Amazing work OP! I commend all your work to put this together. Give this guy some bonus points!
2014 Limited
supratt is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 08:02 AM #112
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
Headlight comparison stock vs others
Lightwerkz ig page already did comparison test between halogen, 2stroke 3.0, 2stroke 2.0, GTR Ultra 2, and Supernova V4 on reflectors, Taco projectors and 4R projectors - the 3.0 performed best on the reflectors and taco projectors. For the 4R projectors the GTR Ultra 2 performed best follow by the SV4 then the 3.0. They concluded the performance of the 3.0 is due to the way the taco have traditional rear bulb projectors whereas the 4R are sideway projectors.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 10:17 AM #113
Dang, you'd think that a company who sells LED bulbs could get better testing equipment than an incandescent lux meter, measured from ten feet away.
The fact that LED bulbs perform differently depending on the housing they're in is a red flag. Halogen bulbs are held to a much higher standard of conformity.
-Tory
Old 11-29-2020, 11:32 AM #114
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
25-30 feet away...I've been to that shop many times
Old 11-29-2020, 12:28 PM #115
OK, I'm going to double-down on finding someone to make a harness to fit the 2021 TRD Pro LED light setup ... the Tacoma guys have been putting those in with good results.
Old 11-29-2020, 09:35 PM #116
????? ????? is offline
????? will become famous soon enough
Major point of contention is whether or not the gentleman at LIGHTWERKZ is using the LED measuring device. I recently discovered through a man in the trade that the readings will not be accurate if using a HALOGEN model.
????? is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 08:44 AM #117
you could ask lightwerkz through their ig page instead of pondering here on a forum.
Old 11-30-2020, 03:22 PM #118
I did at the same time after I posted here. I'll keep you guys posted if I get a reply
Old 12-01-2020, 05:37 AM #119
Looks to be an Extech LT300. I don't think this one accurately measures the spectrum that LEDs operate in. I understand it's a comparitive measurement in this case but shifting from halogen to LED will not have a proper control subject. From what I understand they actually under-represent true output from LED. Still, a measurement of maximum intensity does not tell the whole story.
Better, but still not ideal. Drop-in LED bulbs can be brighter than halogen, but it's well known that their dimensional limitations contribute to lack of focus and a downward shift in hotspot placement. This is what causes nearly every hack LED bulb to have reduced distance projection.
Thirty feet at 65 miles an hour is covered in about a third of a second. This is why correct distribution and distance projection for your headlights is critical. You need your headlights to reach hundreds of feet out.
-Tory
Old 12-01-2020, 05:51 AM #120
Correct.
Still awaiting on a response from Lightwerkz and Crashburn80 showed me what the different module for LED measuring is recently so I'm hoping they reply accordingly.
before/after , compare , fogs , foot , headlight
Where is the COMPARISONS subforum? Thai General Discussions 6 08-05-2013 04:29 PM
LED Light Comparisons Btm02144 5th gen T4Rs 5 01-07-2013 11:52 AM
Why all the Explorer/4Runner comparisons? dekeman 5th gen T4Rs 34 08-02-2010 08:11 PM
HP and Torque Comparisons between T4Rs t65k3 Comparisons & Reviews 2 01-22-2007 09:42 AM
04 and 06 Comparisons coolpop 4th Gen T4Rs 7 04-19-2006 11:46 PM
