***Update***
So it's been a couple weeks since I switched to the King setup. Loving every aspect of it with the exception of the rear stock springs. Now that everything is settling, the rear has settled further than the fronts and no longer have the small rake up front (which is what I want). I don't want to lower the front anymore as I like that height. I am 32" (fender to bottom of wheel) in the front and 32" in the rear (fender to bottom of wheel). Also, the rear stock springs are feeling too soft for me the more I drive it. When I fill the gas tank up full, I also have the dreaded driver's side lean in the rear. Therefore I'm ordering the 1" Eibachs from Ryan @ Eibach to swap out the coils. Should add around 0.6" to 1" of lift in the rear Maybe after settling it'll have the exact rake I'm looking for without lowering the front. As for the lean, I'm going to be adding a rear trim spacer (Dobinsons), either 10mm or 15mm to balance the rear out a bit. |
I told myself I wouldn't get wheels for this truck because I really like the Pro wheels, but I also told myself I wouldn't swap suspension from the Pro's Fox suspension. So here I am...Hi, I'm Papa and I'm a modaholic.
Been eyeing the SCS wheels and I wanted to go the blue on white truck route...since I went with Kings. So here are my new BR6 wheels in Stealth Blue. Hoping to mount them sometime this weekend or next week. 17x8.5 -10 (4.3" BS) https://i.imgur.com/VfnYR42.jpg https://i.imgur.com/hZi8BW1.jpg https://i.imgur.com/OvOxdBQ.jpg https://i.imgur.com/dbNObJu.jpg |
Beautiful build
Crazy cool build, thanks for sharing the play-by-play! I wish I had your buying power. :lmao: Los Angeles.....are you in "The Industry"? :snacker:
But if I could leave this freakin crappy state, I would in a heartbeat. Not much buying power left for us folks thanks to our state policies. It all goes to the 'man' or to the handouts. |
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite) -
