Old 12-23-2019, 07:48 PM #1
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Idler pulley replaced at 65,000
First part failure so far, except battery died a bit prematurely.
Not the bottom idler, but the one closer to the steering pump. Noticed an intermittent whirring sound.
O'Reilly showed all 3 parts being the same replacement part. Only one came with the required bushing, and the bottom pulley was different.
Just an FYI.
delloro is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 10:47 PM #2
BaddaBing BaddaBing is offline
Real Name: Brian
BaddaBing will become famous soon enough
Real Name: Brian
I had 2 pulleys and idler arm replaced under Toyota Platinum Warranty at about 70K. Good luck if you are repairing yourself.
BaddaBing is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 03:08 AM #3
EddieV4runnin's Avatar
EddieV4runnin EddieV4runnin is offline
EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough EddieV4runnin is a jewel in the rough
Why??? What’s so hard about changing a pulley?
Mods are loading.......
EddieV4runnin is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 03:35 AM #4
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
Thanks for the update on the O'Reilly parts, helpful info.
For what it's worth, I had to replace the idler pulley on my JK around 30k miles hah.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 07:52 AM #5
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Nothing is. Except if one is reverse threaded. I don't recall any of the ones on my 2012 being reverse thread. I changed all of them, there are 3 total, right? Or am I remembering wrong?
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:08 PM #6
delloro's Avatar
delloro's Avatar
Removing the bolt on the lower (#1) idler was a PITA. It was very tight, and clearance for the wrench is an issue.
Old 12-24-2019, 02:11 PM #7
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Yes. I believe the below info is correct.
2 - number 2's 16604-0P011
1 - Number 1. 16603-0P030
And the Toyota Parts link: WATER PUMP. Toyota | Toyota
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:14 PM #8
Yes that's what I remember. 2 identical top ones and a slightly different bottom one.
Old 12-24-2019, 06:06 PM #9
Real Name: Brian
Real Name: Brian
I wouldn’t know, I don’t work on autos. Just wishing him good luck if he does it himself.
bottom , idler , part , pulley , sound
2006 V8 Idler Pulley? Jasonredwood 4th Gen T4Rs 8 02-05-2019 11:53 AM
Tensioner Pulley Assembly - Can the pulley itself be just replaced? Lyric_Kayden 4th Gen T4Rs 4 10-24-2014 11:26 AM
idler pulley question aceseverywhere Classic T4Rs 3 10-03-2011 12:12 AM
Idler pulley 4runner_kid Engines / Suspension / Wheels / Tires / Audio / Accessories 0 04-17-2011 09:24 PM
5VZ 3.4L AC idler pulley raydouble 3rd gen T4Rs 0 01-03-2010 06:59 PM
