Old 12-24-2019, 01:46 PM #1
blackie2's Avatar
blackie2 blackie2 is offline
blackie2 is on a distinguished road
blackie2's Avatar
Loosening oil drain cap, not assembly
Anyone have any tips to help me figure out how to loosen the oil filter cap drain where you insert the plastic drain before removing the housing? Mine makes an awful mess changing the oil and I'm at a loss to how to get it off without breaking the plastic housing. Any help would be appreciated. Thanks
2021 SR5 Premium 4x4 stock, Nitto Terra Grapplers
blackie2 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 01:59 PM #2
1000MPH's Avatar
1000MPH 1000MPH is offline
1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all 1000MPH is a name known to all
1000MPH's Avatar
Best to do this on the vehicle where you've got some leverage. A smack on the end of a breaker bar with the heel of the hand is usually enough to shock it free...but might be a good idea to get a backup first so you're not screwed if you crack it.
1000MPH is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:20 PM #3
spartacus's Avatar
spartacus's Avatar
it is tough to feel how much force to use because of the plastic housing and many have cracked it. Get the metal housing so it doesn't break that easily. part #15620-31060 and the motivx oil wrench kit comes with a hose and wrench MX2320.
Old 12-24-2019, 02:24 PM #4
BobsTrail's Avatar
BobsTrail BobsTrail is offline
Real Name: BobH
BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all BobsTrail is a name known to all
BobsTrail's Avatar
Real Name: BobH
Mine has been OK to remove if I follow the torque setting for the plug and cap. If you overtighten the plug, then you get to do it the hard way, taking the whole mess down, then remove the plug. You could try holding the body with a strap wrench if there is room.
Torque is 18 and 9 ft/lbs
BobsTrail is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:40 PM #5
Whippersnapper02's Avatar
I've noticed that the whole cover spins when I try to use a ratchet so I pop on a low torque impact driver to break it loose. Yes I am only using a ratchet when tightening the bolt after draining.
Old 12-24-2019, 02:56 PM #6
flatspin flatspin is offline
flatspin is on a distinguished road
This is the answer. I changed mine several times with the plastic housing until I finally gave up. I put the metal housing on it and the last time I changed my oil, it worked fine taking off the cap, draining the oil from the filter, then taking off the housing.
And yes, I used a torque wrench to put them both on when I had the plastic housing. It just sucks.
This is what I used:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2014 Grey Limited 4Runner 4x4
Installed: XenonDepot HID (Philips 4300k) LB & LED Pro HB, Weathertech mats, Shrockworks Sliders, SCS Stealth 6 Wheel, 275/70/17 BFG KO2 Tires, Daystar 2.5/1.5 lift, Demello 1 hoop Aluminum front bumper, and full OEM tank skid.
flatspin is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 03:04 PM #7
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
You’ve got some good advice here. Get the metal oil filter housing, swap the internal perforated tube, get a Motivx filter wrench and their screw-in drain tool.
If you have a bigass channel lock pliers you can hold the housing (while still installed on the truck) while removing the filter drain plug. The metal housing does not come with the drain plug, re-use your original one. Use the proper torque for plug and housing.
Loosening oil drain cap, not assembly-04768bf4-eeb2-4131-92bc-54c41b607dcc-jpeg
Old 12-24-2019, 03:09 PM #8
blackie2's Avatar
blackie2's Avatar
Thanks guys. I ordered a metal assembly off Amazon today and a spare drain cap. I'll experiment with trying to break it loose and see how it goes next week when I get the replacement parts. That way if I screw it up I've got a backup.
Old 12-27-2019, 07:01 PM #9
blackie2's Avatar
blackie2's Avatar
I got my parts from Amazon today and swapped out the filter element tube on the metal replacement. Everything worked just fine. Thank you again for all your help.
cap , drain , housing , oil , plastic
Gobi Rack - Issue with mounting brackets and loosening bolts? t-rex grrr 4th Gen T4Rs 11 02-18-2016 01:14 AM
Won't shift to 4Lo, does loosening the actuator help? bytemaster0 4th Gen T4Rs 18 03-16-2015 03:16 AM
Any tricks to loosening rear LCA Bolts? DaveK22 4th Gen T4Rs 13 10-02-2013 07:19 PM
Lowering Lower Control Arm WITHOUT loosening body bolts? DaveK22 4th Gen T4Rs 4 09-30-2013 10:57 AM
What's your trick to loosening rear diff fill plug? 4RunnerFan 4th Gen T4Rs 19 04-27-2011 03:56 PM
