Old 12-24-2019, 05:15 PM #1
Zed Dredd Zed Dredd is offline
Zed Dredd is on a distinguished road
Can't Shift out of Park
Had an odd experience today and wondering if others have gone through the same or any insight/recommendations.
Got into my truck, turned over fine but saw that the ABS, battery, Traction Control and Terrain Select lights were all on after it started. I then went to put the truck into drive but it wouldn't move out of park. My son and I checked out some of the other functions of the truck (lights, horn, etc...) thinking that it may have been an issue with a fuse and learned that the brake lights aren't turning on.
Checked the fuse for the brake lights and it seems fine.
I can get the truck out of park if I engage the shift lock, but otherwise something very weird is going on.
Any insight would be helpful.
Can't Shift out of Park-20191224_195921028_ios-jpg
Zed Dredd is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 05:31 PM #2
Whippersnapper02's Avatar
Check all other fuses. I believe one of the ECU fuses will go out and cause all kinds of lights.
Old 12-25-2019, 02:28 AM #3
Samer327 Samer327 is offline
Samer327 is on a distinguished road
Could also be low voltage/bad alternator. Check your battery voltage.
Samer327 is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 04:00 AM #4
spartacus's Avatar
spartacus's Avatar
A while back there was a thread with similar issue and in one case it was a brake sensor and in another it was a blown brake fuse causing the shifter to lockup.
Old 12-25-2019, 09:06 AM #5
Mutant138 Mutant138 is offline
Banned
Real Name: Tobias Fünke
Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future Mutant138 has a brilliant future
Banned
Bump
Mutant138 is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 12:25 PM #6
Shadytype Shadytype is offline
Shadytype is on a distinguished road
Not sure how old the truck is, but mileage indicates you are under warranty. Call the dealer and have them tow it to their shop and sort it out. Have them come deop off a loaner for you.
My local dealer will Lyft you to and from your house if needed.
Shadytype is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 12:43 PM #7
WNY PAT WNY PAT is offline
WNY PAT is on a distinguished road
Double post
2018 4R SR5 Premium Package Faux Pro Clone (Stolen By The Kids)
2013 Lexus LX570 (Wife’s New Mall Crawler)
2017 Tundra Crewmax Limited TRD (Mine)
WNY PAT is offline   Reply With QuoteReply With Quote
Old 12-25-2019, 12:45 PM #8
I know it sounds strange but if you have the tools and a pretty new battery there, Id swap it in and see what happens. Battery problems make these trucks do funny things.
Old 12-26-2019, 09:36 AM #9
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
This is what I would try if you don’t take it in for a warranty repair. I remember hearing about someone had some weird issue going on in a Tundra. Turns out it was a bad cell in a battery.
mcat707 is offline   Reply With QuoteReply With Quote
Old 12-26-2019, 11:01 AM #10
I appreciate the recommendations.
Checked the ECU fuses, no luck. Swapped the battery with my buddies Tacoma, no luck.
I ran it down to the dealer this morning and the tech thought it may be what Spartacus mentioned, a bad brake sensor. They're going to check it out but hoping it's nothing major.
I installed the TRD Pro grill and raptor lights a few weeks ago and I'm wondering if I messed something up when I was poking around in the fuse box.
Old 12-26-2019, 11:25 AM #11
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
This piece of info stands out to me. I would say these are directly correlated and the truck doesn't know you have the brake pedal pushed.
Looks like folks have had similar problems:
Brake-Shift Interlock - Toyota 120 Platforms Forum
"1) Depress tab on blue plug and pull out.
2) Twist switch counter clockwise and pull down
3) Push new switch up and twist clockwise (I didn't replace the brown nut)
4) Put blue plug back in."
Looks like the part # is 84340-59635, but might want to double check.
84340-59635 - Toyota Parts Deal,
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 10:47 AM #12
I got my truck back from the dealer and learned that it was in fact a bad brake sensor. It was covered under warranty and dealer had me up and running later in the morning. Thanks all for the help.
brake , checked , lights , park , truck
Can't shift out of park kdlawrex 3rd gen T4Rs 6 04-02-2024 07:18 PM
Gear shift stuck in park tcbonline 3rd gen T4Rs 6 12-07-2019 03:11 PM
Will not shift into Reverse or Park!! crdean1 3rd gen T4Rs 13 02-14-2014 10:16 PM
Rough shift out of park to Reverse MpJustice 5th gen T4Rs 4 10-17-2012 01:50 PM
91 4R will not shift from Park, will not start dlegresley Problems & Warranty Issues 0 03-25-2008 05:24 AM
