Old 12-27-2019, 10:26 PM #1
CentcomPete CentcomPete is offline
CentcomPete is on a distinguished road
Roof rack install issue
While installing an after market roof rack, the bolt holes that anchor one of the four corners have lost the bracket underneath the holes that holds the sleeves that allow a bolt to tighten through the hole.
There is a part number for this roof rack bracket but I know the piece has just fallen down into a "pocket" under that area. I cannot access it from above so my only option is to try and access it from below, through the headliner. No one at 2 dealerships had ever heard of accessing this area.
Has anyone accessed the area under the base of the roof rack? I need to see if I can reattach the bracket from underneath and determine what is involved in accessing this area. I'm definitely not great at dismantling headliners and trim pieces so just looking for any previous experience. If I can access the fallen bracket and hold it back under the bolt holes I might be able to attach the bolts from above and secure my roof rack.
This has to be a super random question so I'm sure my odds are long.
Thanks, Pete
2023 TRD ORP 4WD Lunar Rock
2013 SR5 4WD Mag Grey (Totaled in 2022)
CentcomPete is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 10:52 PM #2
papadop88 papadop88 is offline
papadop88 is a jewel in the rough papadop88 is a jewel in the rough papadop88 is a jewel in the rough
I can't help, but I'm pretty sure niadh0 can help you...
He started this thread...
2019 Pro Basket Rack - Deleted
papadop88 is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 10:56 PM #3
GRDPro GRDPro is offline
GRDPro is on a distinguished road
Thanks, Pete
Well, you're in luck,
I did the same thing when installing my rack. I even munged the bracket spinning it with the last bolt. The good news is its recoverable! You will need to take apart some trim and headliner. The bracket I recovered was the rear passenger side. I did enough trim to access the front passenger side as well.
When you get the headliner slightly detached, you should be to reach in and grab the bracket and also the metal clip that holds the bracket to a metal piece connected to the frame. Just re-attach the bracket with the clip so you can get the bolts back in.
I left the trim and headliner off for a few days to verify that my seals were watertight.
Good luck!
Greg
GRDPro is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 03:13 PM #4
Good luck!
Greg
Thanks Man, I really appreciate that! I will tackle that project next weekend.
Pete
Old 07-26-2023, 09:34 PM #5
punchrunner punchrunner is offline
punchrunner is on a distinguished road
Good luck!
Greg
Had the same issue - Thanks for posting the solution!
punchrunner is offline   Reply With QuoteReply With Quote
area , bracket , holes , rack , roof
Front Runner full length roof rack. First production run rack install. Apex Overland 5th gen T4Rs 61 04-29-2023 01:46 PM
Known issue with roof rack (stock) leaking? GrantK 5th gen T4Rs 12 03-04-2020 11:33 AM
Roof rack install issue CentcomPete 5th gen T4Rs 3 11-24-2019 08:08 PM
Roof rack issue C.wian 4th Gen T4Rs 3 09-02-2013 01:54 PM
Yakima Roof Rack install - but no tracks on roof! icdawg Engines / Suspension / Wheels / Tires / Audio / Accessories 2 01-20-2011 04:56 AM
