Old 12-28-2019, 12:38 PM #1
dcjeeper dcjeeper is offline
dcjeeper is on a distinguished road
Radio/GPS area illumination lights
My wife's 2016 SR5's radio/GPS area control buttons are dark at night without backlight when the exterior lights are on, although the radio screen is working fine. The Radio, APPS,Navigation, Seek, FF, FW etc buttons works but no light at night. I don't remember if they were lit when it's new. Anyone knows if there's a problem for the lights or not? The backlights for speedometer area work fine.
dcjeeper is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 01:21 PM #2
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Have you checked the fuses?
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 05:24 PM #3
Not yet. Need to figure out which fuse is for that. Is there a map for the fuses?
Old 12-28-2019, 06:30 PM #4
So I located a burnt 7.5 fuse at the driver side panel fuse box. Replaced it twice and burnt again. Where might the short circuit happen?
Old 12-28-2019, 06:53 PM #5
MossJenks's Avatar
MossJenks MossJenks is offline
Real Name: KE0OIC
MossJenks has a spectacular aura about MossJenks has a spectacular aura about MossJenks has a spectacular aura about
MossJenks's Avatar
Real Name: KE0OIC
Replacement owners manuals are available at your local dealership as well as online at toyota.com.
2011 4Runner SR5 Premium
Past:
1988 4Runner 22re, 1992 4Runner SR5 3.slow, 1998 4Runner SR5 5VZ-FE
MossJenks is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 08:33 PM #6
Thanks. I found the blown fuse and replaced it several times but it seems to be a short circuit problem that I couldn't figure out.
Old 12-28-2019, 09:43 PM #7
Unfortunately it could be anywhere behind the dash between the light in question and the fuse. have you had the dash apart for any reason lately? Any work done? Head unit installed? Something else? That's where I'd start but if none of those things happened then you're in for some fun I'm afraid.
Gone
Old 12-29-2019, 12:15 AM #8
Nothing done before. Just noticed the problem recently. Sounds like I have to go to stealers and be ready to pay $$$ ...
Old 12-29-2019, 01:45 PM #9
Yeah, that kind of exploratory surgery is going to take time and $$$.
Gone
Old 12-30-2019, 10:28 PM #10
Anyone has a step-by-step instruction or video for removing the trim around the dimmer switch? I removed the center console and didn't see anything wrong for the wires. thinking maybe there were something wrong near the dimmer switch. Dimmer works for the instrument cluster lights. I assume the other non-woking lights are controlled by the dimmer too. There must be a short circuit in that group.
Old 12-30-2019, 10:43 PM #11
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
Just for diagnoses purposes to keep you from going to the stealership, are you sure that your the light adjuster knob on the left side of the steering wheel isn't turned all the way down?
EDIT: Just saw your post regarding the dimmer switch. Sorry
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 10:49 PM #12
Real Name: Doug
Real Name: Doug
This is to install a switch panel but step 1 should help with removal of that panel and everything else.
https://cdn.shopify.com/s/files/1/24...ions.pdf?17365
Old 12-31-2019, 08:52 AM #13
Thanks. Very helpful!
Old 12-31-2019, 09:44 PM #14
So I removed the center console trim and visually checked the connections. Haven’t seen any burned parts yet. Actually all the electrical functions work, except the back lights. Can a blew out bulb cause short circuit and burnt the fuse? How to check the bulbs behind the buttons? They do not seem to be easily reached. Sorry about the upside down of picture 2. I uploaded from my cellphone. The brown 7.5 mini fuse on the first row in picture 3 is the one keeps blown out.
Radio/GPS area illumination lights-ddc96d6f-ec5c-4614-a5e4-59c13852ff9a-jpg  Radio/GPS area illumination lights-af9c273c-01f8-49ab-a73f-55c01d1be086-jpg  Radio/GPS area illumination lights-e1113833-5a75-4416-a4f9-4ba1925cc5b4-jpg
Old 12-31-2019, 09:49 PM #15
There’s a link for the electrical wiring but I was not able to figure them out.
Electrical Wiring Diagram
area , fine , lights , radio , radio/gps
Let's see your phone background dgirouard39 Off Topic 24 12-06-2016 10:22 PM
Yellowstone background wanderMT Off Topic 3 05-16-2016 07:13 PM
anyone with a background in this? jmbcary44 Off Topic 4 12-01-2014 10:49 AM
desktop background Mtechnick 3rd gen T4Rs 3 06-15-2014 12:17 PM
New From Cen Cal with Drifting Background! Chewbacca New Members 10 08-22-2013 12:07 AM
