Old 12-29-2019, 03:34 PM #1
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
JBL Speaker Only Upgrade Install/Write-up
One of my wife's dash speakers went out recently and this gave me an opportunity to upgrade my Tacoma to a Morel 3-way component setup which then freed up the Kickers I had been using to upgrade the stock JBL door & dash speakers. May upgrade the HU, sub, and hatch speakers later, but this is a tremendous improvement for now and solved the blown speaker problem and my justifying an upgrade to 3-way components in the taco problem.
In doing this I found that the write-ups had a lot of missing photos and/or blurred photos lost in the Great Photobucket Purge so thought I'd post a new one. It was also difficult finding the correct info about the wiring for the JBL dash speakers since my 2014 wiring colors did not match what I saw in other posts.
Here's what I used -
Kicker DS 2 Way 3-1/2 (DSC350) - Dash
Kicker CS 3-way 6x9 (43CSC6934) - Front Door
Kicker CS 2-Way 6-3/4 (43CSC674) - Rear Door
I already had mounting and wiring adapters for the doors from my Tacoma so I just needed to figure out something for the dash.
I used the Trail4R write up for removing the dash speakers. I was surprised that the JBL speakers actually looked pretty hefty, with separate wiring for the tweeter and woofer. It also looks different from all the other photos that I came across in my previous research.
I finally found a post from @bennecc that told me how to figure out how to wire the tweeters (peel back the shrink wrap and see what goes where), even though my colors don't seem to match his. I combined the yellow + green for my positive and the black + purple wires and for negative then crimped on proper connectors.
You can see that I also trimmed the speaker grille back since the speaker is now larger than cone/director and I also trimmed the stock mounting bracket to create a custom mount.
Driver -
Driver installed -
Passenger -
Passenger installed -
Used the videos from TacoTunes for the door panels with one caveat pointed out by @rigtec
I wish I'd seen this before I did the front doors. Most door panels are removed by pulling all the clips on the lower portion out then lifting up to raise the panel out of the door channel. The 5th gen 4R is not designed this way, although it can be done with patience and care. Instead what you should do is pull the top portion away the same as the bottom portion, i.e. toward your body not upward.
You can see in these photos the top piece has a second set of clips and it's much easier to separate the two pieces.
Front door panels/speakers -
TacoTunes video - https://www.youtube.com/watch?v=0AB4l5y6Sa8
Installed -
Rear door panels/speakers -
TacoTunes video - https://www.youtube.com/watch?v=0xfjJBh_KzM
Installed -
[/url]
I was concerned about the JBL system being 2Ω and the speakers being 4Ω, but they are very clear and very loud. The only noise I hear now is when I play older compressed MP3s, tracks with low compression are crystal clear. I was also very surprised by the increase in bass response.
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 05:42 PM #2
rigtec's Avatar
rigtec rigtec is offline
Real Name: Greg
rigtec is just really nice rigtec is just really nice rigtec is just really nice rigtec is just really nice
rigtec's Avatar
Real Name: Greg
Driver -
Driver installed -
Passenger -
TacoTunes video - YouTube
Installed -
Installed -
[/url]
"GREAT JOB gaterose!!!"
...One of the best I've seen so far! I'm not sure if you're planning to add a Sub, but if so, I did a tutorial a few years back; NOT on which is the best one to install, but "What they do, how they work, the difference between a regular bass speaker/transducer, and an ACTUAL "Low frequency wavefront reproducer" cuz they're very different, and their jobs are NOT comparable!
I'm not trying to convince anyone to do what I did... but just to dispell ALL of the myths, wives-tales, marketing schemes, folklore, and the like! Here's one of my threads on the subject:
...got bass?
You've done an EXCELLENT job gatorose; I have a real bad habit of forgeting to take photos when I'm working on my truck, then when done, I'll say: "Opps" ...I should've snapped a few shots before I started the dissasembly... lol! Thanks for your post w/photos!'Best to you',
rig, Cheers!
2012 Limited (in bliz) Black leather interior.
Commercial hvac diagnostics/electrical specialist (Steamfitters Journeyman Local 475)
rigtec is offline   Reply With QuoteReply With Quote
Old 12-29-2019, 10:34 PM #3
TFT4RL TFT4RL is offline
TFT4RL is on a distinguished road
Thank you for this! I just purchased a 16 Limited and hate the sound of the JBL system. It is missing so much detail. I was going to replace my dash speakers but when I pulled them out, I wasnt sure what to do with the wiring. I couldnt find much on replacing the JBL speakers. I may give this a go!
TFT4RL is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 01:52 AM #4
nglayton's Avatar
nglayton nglayton is offline
Real Name: Neal
nglayton is just really nice nglayton is just really nice nglayton is just really nice nglayton is just really nice
nglayton's Avatar
Real Name: Neal
What $$$ did this run you?
PS. the strike through txt is confusing as hell, it's completely out of context for me. Why not just delete it if you are cutting and pasting stuff from a taco post?
nglayton is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 10:32 AM #5
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
It was around $150 all in, hard to say since the door speakers came out of my Tacoma (as it says in the strike through) and were purchased 2 years ago.
ps. Sorry for the confusion but it’s definitely in the same context as the rest of the post. Strike through = “maybe I shouldn’t say this.” It’s a joke. She got these specific speakers because I wanted even better speakers in my Tacoma but already had the Kickers.
Old 12-30-2019, 11:51 AM #6
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
The 3.5" in the dash and the coaxial in the doors is an interesting choice, though since you already had those speakers I understand the choice.
Normally you wouldn't want the tweeters down by your feet for the front sound-stage in a car. Most people go with 3.5" in the dash because they're just replacing those speakers, but if replacing the door speakers as well then the component / tweeter setup would be better.
Pictures of taking the door apart are awesome; I keep reading people saying how annoying it is but the detail pics help understand why it's that way.
llDemonll is offline   Reply With QuoteReply With Quote
Old 12-30-2019, 03:36 PM #7
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
I went with these speakers because it made more sense to me than a component set. Since the crossover is built into the HU, it is only sending higher freqs to the dash location and lower freqs to the door. The stock setup is a 2-3/4 2-way in the dash and a woofer in the door. This is a 3-3/4 2-way in the dash and a woofer (with non-functional tweeters since the HU isn't sending HF to the front door) in the door. Spending extra money just to eliminate the tweeters didn't make sense to me.
A component set with the stock JBL HU would require intricate wiring and signal reintegration or relying on the integral JBL crossover and throwing out the aftermarket crossover and most important part of a component set (also the piece that makes component sets so expensive).
If we ever swap the HU, I'll prob go with a 3-way component setup like I have in the Taco.
Old 08-04-2020, 08:24 PM #8
4Person 4Person is offline
4Person is on a distinguished road
@gaterose Nice write-up - I wish I would have read that before digging into replacing the front doors and dash speakers on my 15 Limited with JBL. It would have made it a lot easier, but eventually I figured it out. These well documented tutorials are few and far between for the 5th gens with JBL.
I was curious if you noticed difference with your sub remaining at 2ohm while all your speakers switched to 4ohm? I switched out the dash with the JL Audio C2-350x that you see here in the forum alot, and then the front doors with JL Audio C2-690tx 3-ways, but after a few days I had to take them out and return them. I have the stock HU and ended up fading the signal 3/4 to the front, turning the volume up by 10 (from normal), and then the bass at minus 3. Still, as soon as a hip hop song came on the Spotify list, the stock sub and rear speakers would be booming too much for their own good and ruin the clarity that I was getting from the new front speakers. I imagine part of this problem is solved by replacing the rear door speakers with 4ohm also, but I was still curious if you had to compensate with the volume, fade, or bass in order to keep the 4ohm/2ohm working together well?
I know it's been a few months since you originally posted this - have you made any upgrades since then?
4Person is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 09:58 AM #9
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
I was curious if you noticed difference with your sub remaining at 2ohm while all your speakers switched to 4ohm? ... I was still curious if you had to compensate with the volume, fade, or bass in order to keep the 4ohm/2ohm working together well?
Thanks! I agree, I had a very hard time finding a good writeup for the JBL system and it looked like my speakers were not the same as some of the threads.
I think that replacing the rear at the same time may have helped me a lot over you, since I'm not having noise issues with the rear. We hadn't noticed anything different with the sub either, the bass seems heavier since we now have better woofers in the doors but nothing distorts or sounds like it's being pushed too hard.
I honestly don't remember making any changes to the settings. I remember being afraid the 2/4ohm thing could be a problem but I was happy with the sound on the first drive. No updates to the audio since this post.
Old 08-05-2020, 12:17 PM #10
TheNicestGuy24 TheNicestGuy24 is offline
TheNicestGuy24 is on a distinguished road
This write up only refers to the 4R's with the JBL system? Is it the same for non-JBL equipped 4R's?
2011 SR5, no nav no JBL
2011 SR5
2011 Camry
TheNicestGuy24 is offline   Reply With QuoteReply With Quote
Old 08-05-2020, 12:20 PM #11
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
The dash speaker wiring would be the biggest difference between JBL and non-JBL. There are a ton of other good write-ups for non-JBL 4runners if you google or search the forum though.
I swapped all of these speakers from my non-JBL Tacoma and the only real difference was the dash wiring.
Old 08-05-2020, 12:38 PM #12
Great, thanks!
2011 SR5
2011 Camry
Old 09-10-2021, 10:08 AM #13
2019TRDPRO 2019TRDPRO is offline
2019TRDPRO is on a distinguished road
Im so confused i have a 2019 TRD PRO 4RUNNER WITH THE JBL STEREO, and I read a few places it says I need capacitors for the tweeters is there a reason you didn't use that?
Thank you in advance for your help...
Driver -
Driver installed -
Passenger -
TacoTunes video - Toyota 4Runner How to remove front door panels - YouTube
Installed -
TacoTunes video - Toyota 4Runner How to remove rear door panels - YouTube
Installed -
[/url]
2019TRDPRO is offline   Reply With QuoteReply With Quote
Old 09-10-2021, 10:27 AM #14
gaterose's Avatar
Real Name: Matt
gaterose's Avatar
Real Name: Matt
I had not read that, I read that there was already a capacitor in there for the JBL system since it had 3.5s in that so I didn't think it was necessary. It sounds GREAT so
Old 12-03-2021, 02:59 PM #15
4RLTD16 4RLTD16 is offline
4RLTD16 is on a distinguished road
I cannot tell you how excited I was to stumble across this write up after sifting through far too many non-JBL upgrades. I used your method to wire a new pair of 3.5" Infinity Reference 3032cfx tweeters in the dash and it work perfectly.
Question: On my 2016 4R Limited there was a cap inline on one of the wires, the green wire to be specific. Did you have this cap and did you leave in place when you reused the wiring for your new speaker connection?
JBL Speaker Only Upgrade Install/Write-up-74529413-8b15-4742-8a1f-148197fe6662-jpg
4RLTD16 is offline   Reply With QuoteReply With Quote
dash , door , jbl , speakers , wiring
3rzrunner's 4cylinder (3rz-fe) CS144 Alternator Upgrade 'WRITE UP' 3rzrunner 3rd gen T4Rs 21 02-15-2019 04:36 PM
Write up: 2nd Gen OME install RedApe Classic T4Rs 5 11-24-2017 10:29 PM
5th gen speaker upgrade help axxman Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-14-2012 01:18 AM
Speaker Upgrade Runner4Runner 3rd gen T4Rs 21 07-01-2011 11:41 AM
Best Amp Install Write-Up I've Seen Mason Fresh Engines / Suspension / Wheels / Tires / Audio / Accessories 2 12-24-2009 10:11 PM
