03-23-2020, 01:01 PM
#16
Family drive, good to get out for some air after being cooped up in the house all weekend.
Build Thread
2015 SR5 Premium | SSO Slimline Bumper | 20" Heise LED Lightbar | 10K LB Smittybilt Winch | 285/70/17 | Shrockworks Sliders with Tread Plate | Toytec BOSS Aluma Series coilovers with 700 lb Coils | HD Superflex Rear Coils | SPC Upper Control Arms | Differential Drop | ARB Twin Compressor | CBI Ditch Light Brackets with Cheapo Amazon LED Cubes | Rola Roof Rack
03-23-2020, 02:15 PM
#17
Do you by chance happen to know the model# or model name of the Rolla rack?
2018 4Runner SR5 Premuim: Bilstein 5100's all 4 corners, 1" Cornfed spacers in the rear, Firestone Air Bags rear, Poly bushings for sway bars, Scangauge 2, Vent Visors, Pro Comp 32 wheels and Wildpeaks 26570R17 tires.
03-23-2020, 03:05 PM
#18
Fairly certain that this is the one.
https://www.rolaproducts.com/product...U0Ao2tYHHpKlwx
Build Thread
04-15-2020, 06:58 PM
#19
I ordered some cheap LED pods from Amazon a while back, and they've been sitting in my garage for a few months. Well, I figured they'd be a good little project to complete during this quarantine. I ordered the mounting brackets from CBI, which were more expensive than the lights themselves by a fair margin.
Wired up and good to go. Fairly bright too, though I have only gotten the chance to test them in my garage with the lights off. We'll see how they do out and about.
Build Thread
05-18-2020, 10:32 AM
#20
Build Thread
05-26-2020, 11:24 AM
#21
I wanted to get some lighting photos taken for comparison. The pictures below are a demonstration of output by stock headlights, my 20" light bar, and my LED pods (and combinations of these).
It's not completely dark out, the sun had just set when I took these. But it shows the performance pretty well. The pods have a lot more range than shown in the picture, but they are ditch lights and I have them angled as such.
No lights:
Stock headlights:
Just the 20" light bar:
Just the LED pods:
Light bar and pods:
Build Thread
05-26-2020, 12:58 PM
#22
1,100 lbs of flagstone in the trunk. And I thought it drove like a pig before...
Looking in my rear view mirror on the way home gave me a view straight down at the pavement.
Build Thread
05-26-2020, 01:02 PM
#23
Starting to look like a trophy truck there lol
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/IMS59-50701 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR EVO 10-S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor MORRFlate kit, and DD SS3 Sport fogs
06-22-2020, 06:57 PM
#24
Build Thread
06-23-2020, 12:40 AM
#25
Great looking build! I'm looking at the bumper/winch combo and was wondering how you like them. Specifically, if the solenoid mount allowed you to avoid bending the tubing in front of the radiator and how you manage without the access holes.
06-23-2020, 11:14 AM
#26
Thank you!
The bumper and winch have served me well, no complaints whatsoever. You are correct, I did not have to bend the coolant line to fit the winch. The winch has (I think) two mounting locations for the solenoid, which was convenient.
I honestly haven't really had a need for the access holes. When I need access, I just pop off the radiator cover in the engine bay, and it's easy to reach down there for whatever I need. Just last weekend I needed to detach my rope to give it a good cleaning, and was able to fit both arms down there and get to everything I needed to remove and reattach the rope.
I will say that if I had to do it all over again, I would go with a full steel bumper instead of the slimline design, simply for added protection. The slimline looks and performs great, but I put a lot of dings and scratches on what is remaining of my bumper cover. In most situations, it's just a stylish winch mount without a whole lot of protection offered. Though it does serve as a good lighting mount and recovery point location.
Build Thread
06-23-2020, 02:38 PM
#27
On that note, it seems you actually get yours out on the trails so I’m curious given the capabilities of the 4Runner how many times you’ve found yourself in situations that required you to pull cable. Either to continue onward through something you wouldn’t have made it through without or in a recovery capacity where you would have been FUBAR without it.
I’d like a winch/lo-pro for peace of mind. I’m curious if it would truly be my security blanky/show piece or if you actually find yourself using it.
I’ve pushed mine through some seriously deep mud/muck but thankfully with the rear locker and A-Trac/MTS I’ve never needed to be recovered.
2014 Trail Premium - Heritage Grill | TRD Wheels | TRD skid | Bilstein 5100/5160 | 275 KO2s | BD Squadron-R Pro fogs
06-23-2020, 03:11 PM
#28
I have needed to use my winch several times. It's not unlikely that just having one has pushed me to try things that I shouldn't. But it was worth every penny based on the amount of times I have had to use it, and where. I can't even imagine the amount of time and money it has saved me. Where I wheel, it could be a while before anyone comes across you in your stuck vehicle, especially in the winter.
There was a day back in January where I needed to winch myself out of a tight spot at least 4 or 5 times in that one outing. I didn't even bother respooling it, just wrapped the line around the bullbar for ease of access. Deep snow, tough trail, and overconfidence...
But yeah, like you alluded to, it's also good to have if you just need a little extra boost to make it through/over something, whether it be be a big rock or a 4 foot snow drift. It's a last resort, but keeps me moving if I want to use it.
Overall, I try to make tow straps work (if I have a buddy with me) before thinking about the winch, but that can't always be done.
I'm about to buy an extra line to carry with me in case of a failure.
Build Thread
06-23-2020, 03:20 PM
#29
This is exactly the feedback I was looking for. Thanks.
Given that I take only take solo outings because adult loner with no friends into this bs, I’m beginning to justify it more and more. My rig is capable enough now to get me stuck further out, which is problematic.
Anything you’d do different in hindsight re:winch/bumper beyond going whole-hog on a full front bumper?
06-23-2020, 03:32 PM
#30
Nope, I don't think so. People rag on Smittybilt's quality, but my experience couldn't be further from that. It has worked every time I needed it to, even though I probably don't give it the amount of care that I should. Solid machine.
The bumper has been great too. Looks cool? Check. Sturdy as hell? Check. Useful? Check. My only problem is that it doesn't have the coverage to protect against stuff like this:
FYI, that last photo... I should have used my winch there to guide me on a straight line through the snow. Instead I slid off the trail and into a tree. Lesson learned.
Build Thread
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
