Old 01-03-2020, 01:32 PM #1
PosterT's Avatar
PosterT PosterT is offline
PosterT is on a distinguished road
PosterT's Avatar
1.5in or 2in rear lift
I am planning to get my King lift in the next few months, but wanted to know which would be better.
My plan right now is to have a 2.5in front Kings and 2in rear Icon coils, but should I go with 1.5in instead and if I do 1.5in what would be a good set of coils to get?
2018 Toyota 4Runner TRD Off Road Premium W/KDSS | SCS F5 17x8.5 | PRINSU 3/4 Roof Rack | AFE Air Filter | Ellis Precision Shift Knobs | 5100 Bilstein all around with 1.75in front lift | Cornfed 1in rear spacers | Pedal Commander | RCI Front/Tranny/Transfer/Lower Control Arm/ Rear Diff/ Gas Tank/ Rear Shock/ Lower Link Skid Plate | RCI Rock Sliders | Canvas Back Rear Cargo Covers | Baja Squadron Sport | Xenon Depot Xtreme HID | OEDRO Floor Mats |
PosterT is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 02:06 PM #2
Tonyl11 Tonyl11 is offline
Tonyl11 is on a distinguished road
I just did a Bilstein 6112 front and 5100 rear combos. I did 2.5 upfront with the 6112 coils and got Wheeler T12 rear coils for the 1.5" in the rear. This still nets me a 1" higher (wheel well to wheel well) in the rear. I really like the way the T12 feels as a DD and off-road, very comfortable. I don't normally throw a lot of weight in the back (yet). I'm slightly concerned that the T12's are not sprung for any real weight in the back. So if you are going to load the back or tow, I would look at their T13 or something sprung heavier. On average, I have maybe 50lbs-75lbs of gear (and maybe a bike rack with an mtn bike) So far, it seems good.
Part of it might be I'm so used to the stock rake, that now, It looks weird level. I don't think I've got a "negative" rake now( With gear). Just voicing my opinion of my ride. Overall, I like the T12's, perfect balance of on-road daily driver and pair with an aftermarket shock, good for average offroad compliance (All I've done so far.)
Tonyl11 is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 02:15 PM #3
Danthefitman Danthefitman is offline
Danthefitman is on a distinguished road
I am running the exact setup that you are considering. Kings w/ resis and adjusters and icon 2" rear springs. Love the setup. When the rear is not loaded up you do have a rake and the rear feels a little stiffer than the front but once it is loaded with all my gear its perfect. I am also running the 600lb springs up front.
2020 SW ORP - King 2.5" suspension w/ adjusters | JBA Uca | Icon 2" rear springs | Diode Dynamics SL1 Led low beam | Baja Designs Squadron Sport Ditch lights | SCS F5 17x8.5 -10 | Nitto Ridge Grapplers 285/70/17 | Victory 4x4 full length rack
Danthefitman is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 02:26 PM #4
PosterT's Avatar
PosterT's Avatar
Are those King 600lb front springs or a different brand?
Old 01-03-2020, 02:49 PM #5
Yes they are the King 600lb springs.
Old 01-03-2020, 03:53 PM #6
PosterT's Avatar
PosterT's Avatar
Thanks.
they normally come with the 550lb, correct?
Old 01-03-2020, 03:56 PM #7
Dillusion Dillusion is offline
Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice
Just my opinion but 2" rear = level.
But it is only 1/2" difference.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 01-03-2020, 04:05 PM #8
Thanks.
That is correct. I wanted 600lbs because I plan to add weight up front at some point this year.
Old 01-06-2020, 02:04 PM #9
PosterT's Avatar
PosterT's Avatar
Oh okay.
Yeah, I most likely won't be adding much to the front, so I think 550 should do me good.
Old 01-06-2020, 02:05 PM #10
PosterT's Avatar
PosterT's Avatar
Oh okay.
I am actually planning to have the same set up as you with 2.5 in the front and 2 in the back, but also be running F5 17x8.5.
I wanted to know how much modification did you have to do to get those 285s to fit without rubbing?
Old 01-06-2020, 02:20 PM #11
I had to remove the front mud flaps, and do the fender liner mod. I need to go back and push the fender liner a little more as I still rub a little at full lock on reverse if at an incline.
Old 01-06-2020, 03:49 PM #12
PosterT's Avatar
PosterT's Avatar
Did you need to do a BMC to fit those 285s or does it clear without having to BMC?
1.5in , 2in , coils , lift , rear
One more Bilstein 5100 front lift, 0 rear lift question. Hugo Stiglitz 5th gen T4Rs 29 11-08-2019 04:56 PM
F/S New 3rdGen Daystar 2.5" Front Lift/30mm Rear Lift-NJ thaemcee2 For Sale: Suspension/Wheels/Tires 3 10-07-2015 07:16 PM
Toytec Ultimate lift kit with superflex rear coils - not enough rear lift.... aleks77 3rd gen T4Rs 8 04-22-2015 08:23 AM
Rear lift options with toytec/eibach front lift cma1188 3rd gen T4Rs 3 10-06-2013 01:40 PM
mixing daystar front lift with rear lift spring??? hdoggie24 3rd gen T4Rs 2 04-27-2010 01:52 PM
Copyright © 2019
