Old 01-04-2020, 07:35 PM #1
71gs3504sp's Avatar
71gs3504sp 71gs3504sp is offline
Real Name: George
71gs3504sp is on a distinguished road
71gs3504sp's Avatar
Real Name: George
P2441, Secondary Air Injection System Switch Valve Stuck Closed (Bank 1)
In over 11 years of owning my FJ and before I sold with almost 200k miles, never had a code all those years.
Now my 18 4runner Check Engine and Track Off lights were both on at the initial start up. Checked the code and it was P2441, Secondary Air Injection System Switch Valve Stuck Closed (Bank 1).
So I used my scanner to find out what code it was and it was the same code listed 3 times P2441. I erased the code all was well when I start the 4runner but I did noticed that the code was still on the scanner and it noted as Permanent. That was the first time I every saw that on my scanner.
Anyone know what this code is for before I take it into Toyota.
2018 4Runner SR5
2002 4Runner Limited (low mileage, my dad purchased new)
2008 FJ with Off-Road Package (191k miles) Sold 6-19
71gs3504sp is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 01:31 PM #2
Friggin Idiot's Avatar
Friggin Idiot Friggin Idiot is offline
Real Name: Luke
Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice Friggin Idiot is just really nice
Real Name: Luke
The FJ didn't have it but on 14+ 4Runners there is an Air injection system as part of the emissions system. Basically it forces fresh air into the exhaust manifold during start up and shut down (that high pitch whine you hear for a second or two). It can be a very expensive system to replace, and if you're under warranty I'd let the dealer take care of it.
Some info about the system.
Air Injection pump mod validity
GX460 Mod
AIR Injection Filter Mod Write-up
"But what do I know.... I'm just a Friggin' Idiot!"
The Idiot Thread - 2014 Trail Premium w/KDSS & some mods
2018 BMW 340xi M-Performance 6MT
Friggin Idiot is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 06:14 PM #3
gainman gainman is offline
gainman will become famous soon enough
This is a big problem in second gen tacoma. There is a delete kit out there but it has mixed reviews.
Sent from my SM-N975U1 using Tapatalk
gainman is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 06:52 PM #4
headpaneer's Avatar
headpaneer headpaneer is offline
headpaneer will become famous soon enough
headpaneer's Avatar
The Air Injection System was so much of an issue on the 2007-2010 Tundra and 2008-2010 Sequoia models, Toyota extended the warranty on related parts. How many miles are on your T4R?
'16 Magnetic Grey SR5 Premium - FN 6-Shooters, 265 KO2s, TRD CAI, various other do-dads
So happy to be back in a 4Runner again! Previous Toys - '87, '89 and '93 4x2 Pick Ups, '03 4Runner, '08 Sequoia
headpaneer is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 08:26 PM #5
71gs3504sp's Avatar
Real Name: George
71gs3504sp's Avatar
Real Name: George
I haven't call Toyota yet on this issue, I only have 23k miles on it. I believe this should be covered under Emission Warrant.
2018 4Runner SR5
Old 01-08-2020, 09:44 AM #6
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
I believe to be closed it has to see no voltage, so this could be as simple as a failing sensor or a wiring issue.
Regardless the dealer should step up on this one.
'16 SR5 Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 09:15 PM #7
71gs3504sp's Avatar
Real Name: George
71gs3504sp's Avatar
Real Name: George
GX460 Mod
I removed the foam filter from the Air Injection a while ago and installed a K&N Filter. This should be covered under the Emission Warranty.
2018 4Runner SR5
Old 09-28-2020, 06:25 PM #8
westcountryrunner westcountryrunner is offline
westcountryrunner is on a distinguished road
Question
Hello all,
First time on the forum sorry if I am not in the right place or doing this wrong. Looking for some help with my 2016 SR5 4runner. CEL and A-TRAC came on, initially found P2441 code. Dug a little deeper with OBD2 and found advanced codes.
P2441- Secondary Air injection system switching valve stuck closed Bank 1
P0300 Toyota readiness Random misfire detected
P0011 Toyota readiness Intake Camshaft position – timing-over-advanced (Bank 1)
P0012 Toyota readiness Intake Camshaft position timing-over-retarded (Bank 1)
P0014 Toyota readiness Exhaust Camshaft position timing- over-advanced (Bank 1)
P0015 Toyota readiness Exhaust Camshaft Position Timing – over- retarded (Bank 1)
P0016 Toyota readiness Crankshaft Position Camshaft position Correlation – (Bank1 Sensor A)
P0017 Toyota readiness Crankshaft Position Camshaft position Correlation – (Bank1 Sensor B)
P0018 Toyota readiness Crankshaft Position Camshaft position Correlation – (Bank2 Sensor A)
P0019 Toyota readiness Crankshaft Position Camshaft position Correlation – (Bank2 Sensor B)
P0021 Toyota readiness Intake Camshaft Position Timing – over – advanced (Bank 2)
P0022 Toyota readiness Intake Camshaft Position Timing – over – retarded (Bank 2)
P0024 Toyota readiness Exhaust Camshaft Position Timing – over- advanced (Bank 2)
P0025 Toyota readiness Exhaust Camshaft Position Timing – over – retarded (Bank 2)
P0037 Toyota readiness HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0038 Toyota readiness HO2S Heater Control Circuit High (Bank1 Sensor 2)
P0101 Toyota readiness Mass or Volume Air Flow Circuit Range/Performance
Has anyone ever seen anything like this before? Any help is greatly appreciated.
Thanks in advance
westcountryrunner is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 10:55 PM #9
Dynamo's Avatar
Dynamo Dynamo is offline
Dynamo has a spectacular aura about Dynamo has a spectacular aura about Dynamo has a spectacular aura about
Dynamo's Avatar
Not true, the later model years FJs did have it. My '13 had it.
2019 TRD ORP
Dynamo is offline   Reply With QuoteReply With Quote
4runner , code , injection , p2441 , scanner
5th Gen P2443 Code/Secondary Air Injection GreenMountainOwl Problems & Warranty Issues 8 01-04-2023 04:43 PM
secondary air injection help Txjcb5002 4th Gen T4Rs 10 08-27-2020 12:21 PM
Secondary Air Injection Pump (aka - should I buy this truck?) he's gone 4th Gen T4Rs 5 09-12-2018 05:34 PM
Bad Secondary Air Injection on V8?? Soneill 4th Gen T4Rs 3 04-14-2017 01:41 PM
Code P2432, Secondary Air Injection b.miller123 Problems & Warranty Issues 4 12-11-2014 02:43 PM
