Old 01-05-2020, 04:43 PM #1
paulndot's Avatar
paulndot paulndot is offline
paulndot is on a distinguished road
paulndot's Avatar
Radio system reboots intermittently
My radio head unit/ nav system started to reboot as if the car was turned off/on again - constantly. I found another thread on here with some very helpful information:
Radio / Nav Rebooting
The original post is pretty old, so I'm refreshing the subject in case others are having the same issue.
My head unit held out for 92K miles before having this issue (2015 4Runner Trail). It started to happen a few days ago, and intermittently... the HU turned off/ rebooted after about 10 mins of drive time. The weird thing is that it did it for a day or two, then it stopped, then started back up again. Yesterday we drove around for a few hours and nothing. This morning, it rebooted about 8 or 9 times in the course of 2 hours. As usual, the help on this forum is friggin' AWESOME! You guys and gals all rock. I went to this site:
Toyota Downloads
After a few of the usual prompt questions (year/ model) it led me to the instructions/ download page. You'll need a thumb drive with at least 2GB of free space - preferably blank (per the site instructions). The software version that downloaded for the 2015 4Runner was 0101D7, and the file name I downloaded is 13TDANNA-DA00_0215.kwi
It took maybe 10-15 minutes to upload to the 4runner, and after turning the ignition off/on again, the software was loaded and verified in the general settings tab, under software/ software history. It showed the software and the date uploaded. I'll post again tomorrow night with the results. Fingers crossed.
Seriously, someone call Kenny Loggins 'cause you're in the Danger Zone!
2015 Trail Edition W/ KDSS - The Zohan, Featuring: BFG AT T/A KO2s in 275/70/17, Trail Edition roof rail swap (next mods TBD).
paulndot is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 05:05 PM #2
el_kab0ng el_kab0ng is offline
el_kab0ng will become famous soon enough
I have found my 2016 T4R will do this sporadically, but usually because there's something plugged into the USB power slot (whether the phone is connected to it or not) or my bluetooth is trying to connect before the head has initialized.
el_kab0ng is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 06:21 PM #3
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
There is a history of Radio/Nav system issues that are mentioned in several threads over the years; including the rebooting problem. Some were fixed by software updates and others required replacement of the head unit. I'd check and see if you could get this fixed under warranty.
If that's not an option; I'd look at an aftermarket system instead of spending money on a system that was substandard to start with. There are threads with lots of info on aftermarket systems and their installation / setup you can search on.
Old 01-06-2020, 08:54 AM #4
paulndot's Avatar
paulndot's Avatar
Well, no luck this morning. After about 15 minutes, the HU rebooted. After the reboot, the BT was turned off, and it worked fine. The next thing I'm going to try is the "hard reboot" others have suggested by removing the fuse, which should theoretically reset the radio to the original factory settings.
Wow Toyota... vehicles that cost literally HALF what our 4R's cost don't have these issues.
Old 06-03-2020, 11:02 AM #5
bluecollarjock bluecollarjock is offline
bluecollarjock is on a distinguished road
What did you end up doing ? My TRD pro ‘16 with less than 40k miles started doing this yesterday
bluecollarjock is offline   Reply With QuoteReply With Quote
Old 06-23-2020, 01:56 PM #6
RCFJ RCFJ is offline
RCFJ is on a distinguished road
I have been trying to do this update but can not get the 4Runner to recognize the usb with the update on it. It recognizes my phone via usb but not my flash drive.
I did format to Fat32 and it only has this file on it
Any ideas?
RCFJ is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 05:26 PM #7
Any ideas?
Any help here? I have tried multiple flash drives from 2gb to 128gb fat16, fat32, exfat nothing works.
Old 04-26-2023, 08:35 PM #8
thistof thistof is offline
Real Name: Tof
thistof is on a distinguished road
Real Name: Tof
USB Theory
Mine started rebooting every couple minutes after playing music from the USB. I haven't had any problems with bluetooth yet, but I'd really like to be able to play my mp3 collection.
thistof is offline   Reply With QuoteReply With Quote
Old 04-27-2023, 09:37 AM #9
AMLOR AMLOR is offline
Real Name: Kirk
AMLOR has a spectacular aura about AMLOR has a spectacular aura about
Real Name: Kirk
As silly as this sounds...have your battery checked out. This was the first symptom of a low volt failure caused by a worn out battery.
happened more and more often until I took it to the parts store to check it after it would not start one morning and had to jump it.
Battery showed 10.6V on the load check. Replaced the 3 year old battery, no more rebooting...just saying.
AMLOR
REMEMBER: Birth control prevents Mini-vans...
2019 TRD PRO: Victory 4x4 Blitz bumper & sliders, Smittybilt 12K, Factor 55, Bubba Rope, Van Beest, C4 Fab, Power Tank, Xenon Depot, Cali Raised LED, ARB, SPC UCA's, Rad Rubber, REDARC, StrongBox, TRD Pro front coils, CE Auto Elect., Blue Sea, SDHQ/SP9100, Cornfed, RCI skids, BajaRack "basket", Revolution Gear 4.88's, Dobinsons 300lb over stock rear springs. DrawTight Class IV frame mounted hitch, Method Racing 703 Bead grip.
AMLOR is offline   Reply With QuoteReply With Quote
4runner , issue , radio , software , started
Navigation / radio reboots hangs problem update carrera mike 5th gen T4Rs 39 10-22-2021 01:36 PM
Replaced stock head unit, and new Kenwood HU still freezes and reboots. RustyAb 5th gen T4Rs 4 12-24-2019 06:26 PM
2017 radio randomly reboots in bluetooth. traylorr 5th gen T4Rs 2 10-15-2019 07:20 AM
ENTUNE Freezes and Reboots frequently CrazySte Problems & Warranty Issues 2 04-26-2018 08:01 AM
pc3200 hangups and reboots ran Off Topic 0 07-12-2012 04:52 PM
