Old 01-06-2020, 03:47 AM #16
idHawk idHawk is offline
idHawk is on a distinguished road
It's hard to believe with that much damage there was no indication of leaking on the inside.
idHawk is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 08:40 AM #17
Brage Brage is offline
Brage is on a distinguished road
Originally Posted by maxp0wer View Post
What's the rough surface on the roof? Looks like Line-X or something? I wonder if this could have contributed.
Yikes
That is my question as well. A liner with any small imperfection can only serve to let moisture in causing it to rust from the inside.
Brage is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 08:55 AM #18
SlickTRD SlickTRD is offline
SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about SlickTRD has a spectacular aura about
This will give nightmares to anyone with an aftermarket roof rack.
Cement, RCI Skids & Sliders, Nitto Ridge Grappler, Northstar AGM, Goose Gear Plate, Dometic CFX 65W, Dometic Fridge Slide, BPF Molle Panel, Pedal Commander, Compustar, BlackVue, Diode Dynamics SS3
SlickTRD is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 09:11 AM #19
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
This..for that much rust I'd expect you had water soaking the interior whenever it rained..
'18 SR5 4WD, magnetic gray metallic, stock, RCI front skid, LFD cross bars, Pedal Commander, Accessorides Remote Start.
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 09:41 AM #20
jwscott79's Avatar
jwscott79 jwscott79 is offline
Real Name: Jason
jwscott79 will become famous soon enough
jwscott79's Avatar
Real Name: Jason
This scenario is the reason that I am not interested in installing an aftermarket roof rack. That being said, this looks like something more serious that improperly sealed mounting locations. Was this vehicle purchased new or used?
jwscott79 is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 10:30 AM #21
Mudballz's Avatar
Mudballz Mudballz is offline
Mudballz has a spectacular aura about Mudballz has a spectacular aura about Mudballz has a spectacular aura about
Mudballz's Avatar
That looks more like chemical metal rejection 2 different metals reacting
I can’t see how fast water would rust your roof unless it was salted
Mike
Mudballz is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 11:32 AM #22
Heavy_GD's Avatar
Heavy_GD Heavy_GD is offline
Real Name: GD
Heavy_GD has a spectacular aura about Heavy_GD has a spectacular aura about
Heavy_GD's Avatar
Real Name: GD
Originally Posted by craaaazzy View Post
Wow, that’s hard to imagine. Did u have any water leaking and puddling inside any where or staining onto the headliner? Need to check my rack on my LX.
Originally Posted by mcat707 View Post
Wow! Just wondering, did you park your vehicle in a garage or out doors all if its life? I’m wondering if I should seal my roof rack mounts. I do park in garage when at home and live in sunny California.
All of these things, I'll grab the
'16 SR5 Premium
Heavy_GD is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 11:36 AM #23
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
pretty jacked up that some people are saying to fix it and dump it while hiding the damage.
APhelps is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 12:00 PM #24
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Well what else can you do there, do you have any other suggestions? Cut a whole roof off of another vehicle and weld it on? Weld patches? I don't see either of those as a viable alternative so you either drive it until the rust perforations create so much mold that it's a health hazard, then scrap it (the honorable thing to do), or you dump it for cheap now. Perhaps it's fixable but it doesn't look like it to me.
I have never sold or traded in a vehicle with issues like this but I'm not sure what else can be done here. Send it to auction and the buyer that gets it cheap gets it cheap for a reason. Happens all the time. More often than I'd like to think. Probably no worse than a previously flooded vehicle.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 12:23 PM #25
Its one thing to trade it in while being up front about the damage.
One could probably bondo it, respray the section and trade it in which is highly screwed up to do.
Cutting the roof off and welding in a new roof would fix the problem but would be a pretty costly solution. Might be able to find a junkyard and weld in new roof sections as well but i'm not sure how well that would go.
Surprisingly a new roof isn't that expensive but the body shop hourly rate would be: Roof & Components for 2013 Toyota 4Runner | Camelback Toyota Parts
Old 01-06-2020, 01:33 PM #26
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Learn how to weld.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 01:56 PM #27
Would the roof skin alone like that even be enough? I'd think you would have to replace all the parts the rust is creeping into as well.
Old 01-06-2020, 02:05 PM #28
spartacus's Avatar
spartacus's Avatar
Whats done is done.If you trade it in or sell it (be upfront). you probably wont get much for it.Take it to a body shop that deals with classic restoration and ask them to evaluate it and see what it costs. If you can afford it get it fixed and make it your forever vehicle or cut your losses and move on. In either case it's going to be costly.
Old 01-06-2020, 02:19 PM #29
scionicboom scionicboom is offline
scionicboom is on a distinguished road
I really want a rack, but this got me scared as he!! now. Did you see any damage to the inside headliner at all that would indicate any issues? I would assume with that much damage that you should have started see water issues in the headliner or at the inside starting to smell all the time.
Also, is there a reason that you removed the rack multiple times in the past? I had a rack on my last 4runner for over 6 years (parked outside) and never once thought about removing the rack once it was already up there.
scionicboom is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 03:29 PM #30
tackindy tackindy is offline
tackindy is on a distinguished road
In the pictures it appears the inside of the roof is scraped away as if a grinder was used on it. The bolts and brackets also appear to be a mis-matched set. Did you have to drill new holes and such for the full length rack? If so, did you repaint the cut metal to protect it or just seal with permatex?
tackindy is offline   Reply With QuoteReply With Quote
areas , bad , hole , rust , seam
Any rust issues on Gen 5? Beach rust prevention. Fomer_FJ_owner805 5th gen T4Rs 8 09-19-2016 01:08 PM
Too much rust? jtharlow 3rd gen T4Rs 16 07-13-2015 09:55 PM
Rust?!?! DaniFami 3rd gen T4Rs 10 10-18-2012 09:50 AM
Has anyone in the rust belt had luck with a DIY rust inhibitor? MilesRacker 3rd gen T4Rs 5 10-17-2008 02:46 PM
Rust and rust prevention Thai Maintenance/Detailing 0 02-21-2007 10:58 PM
