Old 01-07-2020, 12:13 PM #46
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Honestly this might be a good time to find someone willing to do a roof pop top conversion. It could be the first 5th gen 4Runner with one!!!
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 08:05 PM #47
uh0h50 uh0h50 is offline
uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about uh0h50 has a spectacular aura about
This has me concerned with my rack install ..
lll 2016 SR5P MGM lll OEM TRD Pro Matte Black Wheels w/ Falken Wildpeak LT255/80 17 "Pizza Cutters" l Bilstein 5100 F+R set at 1.75F + 1" Cornfed Rear Spacers l OEM TRD F+R Lower Valances l Prinsu Non-Drill Full Length Roof Rack l Shrockworks Sliders l RCI Steel Skid Plate l OEM bi-LED Headlights l DD SS3 Sport Amber Fogs l
My 3rd Row Delete Thread
uh0h50 is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 08:32 PM #48
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
All,
I really encourage you to research the use of butyl rubber instead of silicone/RTV sealant when it comes to roof rack installations and other automotive applications.
Silicone sealant isn't meant for this kind of application. It hardens and dries out, retracting away from the joints (and often pulls paint as it goes). UV exposure is a HUGE detriment to most types of silicone sealant.
When you pull off your factory roof rack, you should have noticed that the factory sealant was still tacky and pliable, regardless of how long you've owned the truck. This is the kind of seal you need- not one that hardens into a rock under the sun. Butyl rubber stays tacky and is a dynamic seal, which is what you need for a dynamic outdoor environment.
Take a look at how and why I did my own seals for my aftermarket rack installation. It's my guess that the use of silicone is the failure point in this thread.
EcoTechne Roof Rack Installation (5th Gen)
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 10:32 PM #49
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
Originally Posted by mynameistory View Post
All,
Good point about silicone sealants. And some of them, the RTVs that are Acetoxysilane-based, release acetic acid during the curing process. This will eat into and corrode bare metals.
Old 01-07-2020, 11:32 PM #50
Hydguy's Avatar
Hydguy Hydguy is offline
Hydguy will become famous soon enough Hydguy will become famous soon enough
Hydguy's Avatar
One reason I haven't pulled the trigger on a roof rack.
Some places use cheap hardware that doesn't play well with with other metals.
2018 4Runner TRDORP MGM MODS: TRD Intake, full set of ARCLight Icraus Premium lights,Precision LED interior door/exterior lights, Rago MOLLE panels, Ellis Precision shift knobs w/Custom engraving, N-Fab nerf bars, 3-1 LED DRL/Fog lights.
Hydguy is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 11:58 PM #51
Not even close to the reason for this.
-Tory
Old 01-08-2020, 11:29 AM #52
tylertenny's Avatar
tylertenny tylertenny is offline
tylertenny will become famous soon enough
tylertenny's Avatar
All,
I've been following this thread and I currently have an LFD roof rack on order. After reading everything I'm worried about leaks after installation. Since I can't follow the same installation process you used because the LFD uses different hardware, I'm thinking that I could just put some butyl rubber around the base of the tubes and then cover that with some 3M super weatherstrip and gasket adhesive. Is putting more sealant over the butyl rubber overkill or would I be better off using one or the other?
tylertenny is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 01:23 PM #53
I don't know the characteristics of those particular sealants. Can you add a few pictures of LFD mounting feet and hardware, or start your own thread for discussion? Whatever you do, do NOT use a sealant that is meant to cure and harden completely. Not only does this make for a bad seal, it makes the rack and hardware difficult to remove later (you do not want this).
Frankly, I think it's crazy that companies that sell racks just encourage you to use whatever sealant you can get your hands on. They're either ignorant to potential damage like this, or they don't care because they already have your money and 5 years will have gone by before anyone realizes the impact.
-Tory
Old 01-08-2020, 01:46 PM #54
tylertenny's Avatar
tylertenny's Avatar
I apologize in advance if I'm hijacking this thread but I feel like these questions are relevant to the topic because I'm just trying to avoid damage to my roof mounts.
1:56 into the video shows the mounting hardware for this rack:
YouTube
This is the sealant I was looking at since it's made for automotive applications:
https://www.amazon.com/3M-08581-Blac...jaz10cnVl&th=1
I know this topic has been covered many times over but for someone installing a rack on their expensive vehicle for the first time it can be a little nerve-racking when there are differing opinions about the correct installation method.
Old 01-08-2020, 02:25 PM #55
YouTube
I would still hesitate to use anything that cures into place, even if it's described as flexible. It may work, but how easy is it to remove if you change your mind in a few years?
For the LFD feet/spacer install, I would personally use butyl rubber under the spacer (make sure it gets squeezed into the little gaps around the tubes). As long as the rest of the hardware surfaces are clean, flat, and installed snugly, they should be okay and resist leaking through the threads. Blue Loctite should also help (it's a mild sealant and also temporary strength, not permanent threadlock).
-Tory
Old 01-08-2020, 04:36 PM #56
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Just wondering if you used the Oem bolts and rubber washers ? This is what my Oem rack came with.
Originally Posted by OutBreak View Post
After recently selling my roof rack I've had for 5 years and maybe taking it off twice during that time. I discovered when removing it, some pretty bad rust issues. Initially, I noticed bubbles and some flaking so I started looking a little harder then ended up removing the headliner and Holy Smokes! I was not happy with what I found, I sealed the holes when I put the rack on but somewhere water got in and destroyed some areas. I have rust spots/ holes in all four of the factory mounting locations. One being so bad I have a sever hole in between the door seam and roof seam. Now I am bouncing around ideas on how to fix everything, being at the seams is making it difficult for me. I know I need to cut out the bad areas and clean, then I will use something like POR-15 for rust protection, I'm unsure how to patch up the hole right in the seam, I've seen several threads on welding pieces and not using bondo. If it was a flat spot I could do it, being at the seam I'm at an impasse. ideas or thoughts appreciated.
Honestly thinking about pulling all my mods and jumping ship.
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 05:39 PM #57
Hydguy's Avatar
Hydguy's Avatar
Obviously you are wrong, as the pics in the original post clearly indicate.
Old 01-08-2020, 07:39 PM #58
rageandlove rageandlove is offline
rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all rageandlove is a name known to all
Sherpa sells a rack that doesn't require any sealing due to the design of the mounting system. Or at least that's the claim - I haven't ordered one yet, but I have talked to a few forum members that have put them on their vehicles and they seem to hold up to plenty of rain.
Thread on Sherpa on 5th Gen 4Runners here.
If Toyota can design a system that doesn't need sealants, it makes sense that other vendors could too.
rageandlove is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 08:08 PM #59
Your post implied that this is the result of cheap hardware, of metals " that don't play well with with other metals."
I'm saying that galvanic corrosion is not the primary failure mode here. The primary reason for failure is the intrusion of water and moisture as a result of bad sealing methods. If you don't introduce moisture to the system, rampant oxidation (rust) can't occur to begin with. Also, even cheap hardware is usually coated in black oxide or zinc, which acts as a sacrificial anode, actually preserving the surrounding steel.
-Tory
Old 01-11-2020, 01:47 AM #60
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
All,
I have to ask because I could not find anything on the net about silicone being bad for paint in regards to sealing a roof rack as example. I saw multiple web sites saying that modern paint contains silicone as it helps flow through the sprayers. Some car wax contains silicone, windshield sealant is silicone.
Do you have any links that show its actually harmful? I'm just wondering because as I've used it in many automotive sealant areas like adding grommets for exterior lighting etc. maybe I haven't kept the rigs long enough to see damage but I've never read anything bad about until now. Thanks!
ForRun is offline   Reply With QuoteReply With Quote
areas , bad , hole , rust , seam
Any rust issues on Gen 5? Beach rust prevention. Fomer_FJ_owner805 5th gen T4Rs 8 09-19-2016 01:08 PM
Too much rust? jtharlow 3rd gen T4Rs 16 07-13-2015 09:55 PM
Rust?!?! DaniFami 3rd gen T4Rs 10 10-18-2012 09:50 AM
Has anyone in the rust belt had luck with a DIY rust inhibitor? MilesRacker 3rd gen T4Rs 5 10-17-2008 02:46 PM
Rust and rust prevention Thai Maintenance/Detailing 0 02-21-2007 10:58 PM
