01-11-2020, 03:20 AM
#61
Originally Posted by ForRun
I have to ask because I could not find anything on the net about silicone being bad for paint in regards to sealing a roof rack as example. I saw multiple web sites saying that modern paint contains silicone as it helps flow through the sprayers. Some car wax contains silicone, windshield sealant is silicone.
Do you have any links that show its actually harmful? I'm just wondering because as I've used it in many automotive sealant areas like adding grommets for exterior lighting etc. maybe I haven't kept the rigs long enough to see damage but I've never read anything bad about until now. Thanks!
Let's clarify: there are a lot of different kinds of sealants, there are a lot of different kinds of silicone, there are a lot of different kinds of silicone sealants. Some people use the words "silicone" and "sealant" interchangeably, even though not all sealants have silicone, and not all silicone products are sealants.
What I can't do is give you an exhaustive list of every kind of sealant that everyone has used to seal a roof rack, and whether or not they are compatible with paint, metal, weathering, UV exposure, etc. I caught some flak when I posted this to a Facebook group. Lots of people said "stop making blanket statements, I used XYZ sealant on my roof and it's fine". Sorry, but I would rather make blanket statements that encourage research and PREVENT accidents like this happening, even if I'm not being inclusive of exceptions.
Sure, some acetic silicone sealants appear to be corrosive to bare metal. However, my assertion isn't that the sealant corroded the metal in OP's roof. What I'm suggesting is that by using a sealant that cures and hardens (as well as removal/reinstallation of the rack without new sealing), it shrank back from the surfaces it was bonded to. This allowed moisture to creep into the joints and stagnate, causing runaway oxidation.
This is why I advise against using a sealant that cures and hardens (like most silicone sealants). Most silicone based sealants are not made for continuous exposure to the elements and sunshine (UV) that can make things very hard and brittle. Also, you have to consider that your vehicle roof goes through hugely dynamic situations like vibration, heat/cold cycles that expand and contract the sheetmetal, weight loading, etc.
Butyl rubber is what OEM applications use because it's a sealant that never cures. It can move with dynamic applications without losing its bond and seal. It's also fairly inert and easy to remove, even after years of service. Can you imagine chipping hardened silicone sealant off of your roof rack mounts in ten years?
By the way, your last example (windshield sealant): that's butyl rubber too
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
01-11-2020, 10:35 AM
#62
Thank you! The sealant I saw was permatex windshield sealant made with silicone. I did further searching rather than picking the bought and paid for Google search result and found exactly what you said with sealant. It's about halfway down the article.
Right and Wrong Ways to Replace a Windshield
01-12-2020, 03:29 PM
#63
Real Name: Cas
Real Name: Cas
Originally Posted by daytonaviolet
Just wondering if you used the Oem bolts and rubber washers ? This is what my Oem rack came with.
I did not use the factory bolts the rack had its own set, which I think could have also been an issue
Whosoever is delighted in solitude is either a wild beast or a god.
01-12-2020, 03:32 PM
#64
Real Name: Cas
Real Name: Cas
Got the areas cleaned and rust-free.
01-12-2020, 03:37 PM
#65
Real Name: Cas
Real Name: Cas
First attempt at fiberglassing the outside. It doesn't look pretty but it's sealed tight to the metal both on top of the roof and in the rail. I'll do the inside as well. Everything else will get a coat of POR-15.
01-12-2020, 11:40 PM
#66
Originally Posted by Hans Moleman
This is why I don't want to mess with my roof rack or install a new one. The factory installed one is probably the best you can get at having proper sealing.
Don't count on it.
I've had several roof racks factory installed and every one has ended up rusting like the OP's roof. They were not 4 runners.
A couple things at play here.
The truck was left outside near the ocean, same as mine, less than a mile from the ocean. Salt air comes into play. It's a real problem.
The factory should seal protrusions properly, but I would not trust it.
On my list is to remove the factory install and reinstall it to what I feel is adequate. Hate to see a good 4 runner wasted needlessly.
The reason why there was no tell tale signs of intrusion is likely because the water once inside finds its way down the inside of the framework all the way down to the sills or rockers. On one of my vans the jacking point had rusted so thin that it collapsed under a jack but looked fine on the outside.
Another area to check is the hinge mounts for the rear hatch. That can get rusted from the inside from the roof rack leaks.
I did a lot of marine work and pretty standard in the industry is to use a 3M product called 5200. It's a marine grade sealant that works well under the water line on hull protrusions and does not leak. It must be properly applied in a process called "bedding" the attached parts. It seals both the mating surfaces and the hardware threads. Galvanic corrosion is really not an issue for something like this.
Repairing the damage with fiberglass is fine but you must realize that polyester resin is not waterproof, epoxy resin is and has a much higher adhesive strength.
Similarly regular automotive bondo is also polyester, not waterproof and also has poor adhesion.
Marine fairing compound looks just like the bondo, costs more, but also can be used below the waterline, commonly on aluminum hull yachts. You can't beat it off with a sledge hammer.
Lastly, I wouldn't use POR15, it can have problems with moisture creeping unnoticed underneath it, not worth the risk.
Again, in marine, IMRON is used, or any polyurethane 2 part paint, properly prepped and applied of course. Prepping constitutes cleaning the metal with phosphoric acid along with etching primers.
Just some food for thought
Best of luck with it.
02-04-2020, 01:06 PM
#67
Sorry to see you're fixing it, I am here to present you with a better idea (not my image)
02-04-2020, 01:13 PM
#68
Real Name: Reinout
Real Name: Reinout
Oh man that stinks: Doing rack installs at a prior job we did not use RTV sealants because of the drying and hardening.
We exclusively used E6000 for everything that had to do with sealing. Albeit a little runnier.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
02-04-2020, 03:42 PM
#69
Originally Posted by Over the LINE
Just a guess but was the rack still in really good shape like not corroded at all? Was the metal of the rack directly touching the metal of the roof maybe where paint had worn off? Factory racks have a rubber or plastic spacer and I'm sure factory bolts are chosen specifically to avoid a dissimilar metals issue. Your rack I'm guessing did not have a spacer and or the hardware was a dissimilar metal. Again just guessing.
Galvanic action occurs when two electrochemically dissimilar metals are in contact and a conductive path occurs for electrons and ions to move from one metal to the other. One metal corrodes as its ions are deposited onto the other metal. ... Cathodes are noble, or stable, metals that are not prone to corrosion.
If I'm correct, your roof acted similar to a zinc anode on a boat prop shaft or the zinc outer coating of a galvanized steel beam. It sacrificed itself protecting your roof rack.
Listen to the above and the guy on page 1. Likely the main cause. I am in the coatings industry and you would not see that sort of corrosion from normal water and leakage. Not possible in that time frame.
Bad metal next to bad metal and you get what you get...
02-09-2020, 03:42 AM
#70
This is a really disquieting thread, as a person who hasn’t actually committed to purchasing his TRDP yet. I know it’s an aftermarket roof rack, but man that calls into question some of the basic fundamental structure of the vehicle itself. There could be other factors at play (metals not playing well together), but it’s worrisome nonetheless.
02-09-2020, 04:55 PM
#71
You're fine. The roof rack is sealed correctly against water intrusion from the factory. If you decide to change the roof rack, make sure to seal it correctly (i.e. don't just slather silicone everywhere hoping for the best).
Galvanic corrosion may be present in this scenario but it is not the root cause. Most commercially available hardware is designed to resist corrosion (zinc coatings actually corrode first, long before nearby steel rusts). You can't just wave your hands and say "oh it's bad metals" because you'd have to try really hard to deliberately select materials that would cause the roof to become severely anodic.
Furthermore, galvanic corrosion only occurs in the presence of an electrolyte (in this case water). That means you could have a cast iron roof with solid gold bolts and not experience sacrificial corrosion, as long as they were properly sealed and protected from water intrusion. A correctly sealed roof rack does not allow water to intrude into the cabin and mating surfaces. Runaway corrosion, like you see here, is the result of stagnant moisture in the system. And uncoated steel will oxidize very quickly in this environment with little prompting.
-Tory
02-09-2020, 07:58 PM
#72
My concern isn't much to do with this particular instance. It's more of a concern of the quality of the steel used in the truck and future rust issues maybe.
I live by the ocean, so it will constantly be exposed to salt air. On top of that, it wont always be garage-kept and it rains loads in FL. Now, the factory rack may be just fine, but I'm going to expose the entire vehicle to these sort of conditions on a daily basis. That's my concern.
My concerns are no doubt blown out of proportion.
02-09-2020, 09:18 PM
#73
Do you guys have any recommendations for shops in the east coast (VA, MD) that would do a good job at installing an aftermarket rack?
This thread has me all sorts of paranoid now.
02-10-2020, 02:46 AM
#74
Any steel (including those alloyed with nickel and chromium, stainless steels) can and will oxidize in the presence of oxygen and a corrosive environment. It has nothing to do with the "quality of steel" and everything to do with basic chemistry.
The roof (and the car/truck) will not corrode if it is properly protected against the elements. Toyota and other car manufacturers go through great pains to ensure their cars are properly protected and sealed from water getting inside. Toyota did go through a huge frame recall last decade when it was found that the frames on some Tacoma trucks were improperly rust-proofed, causing premature failure. They replaced the frames at no cost to customers. It was a VERY big deal because it was a fairly recent example of a major quality assurance failure. They don't happen often.
Take heart. Plenty of people drive 4Runners in Florida, you'll be just fine.
-Tory
05-25-2020, 01:45 PM
#75
This might be a stupid idea (I've done it so it's probably stupid), but you could just replace the roof? To make it cheaper, go without a sunroof if you have one.
I replaced the roof on my 95 4runner when I was restoring it -the a-pillars were rusted out from either rock chips or inattentive windshield installers (the rust didn't look bad from the outside, but inside was completed rotted). It had a sunroof, but I found a donor vehicle with no sunroof at the pick n pull that I had delivered to a shop to line up the cuts.
Not exactly cheap, but at least you'd have almost factory clean mount points again. For me, it was a decision between headache (and constantly worry) vs cost vs time. I could try and tackle it myself or i can pay to have to replaced and have a solid roof again with 0 structural issues.
_____________________
2018 Super White SR5 Premium aka Ben Affleck: Procharged (D1SC), Bilstein 5100s w/ 2" Toytech Superflex, 285/70/18 duratracs (E), 18x9 Volk TE37, OEM Audio+ Ref500, RA Motorsports rack, TRD hood + skid // 2003 Black Limited (2UZFE) aka Blacky Chan: Bilstein 5100 w/ Icon 2.5" springs, BMC, air bag delete, 17x9 SCS Ray10, 285/70/18 Yokos
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
