Old 01-05-2020, 06:21 PM #1
OutBreak's Avatar
OutBreak OutBreak is offline
Real Name: Cas
OutBreak will become famous soon enough
OutBreak's Avatar
Real Name: Cas
Destroyed Factory Roof Mounting Locations
After recently selling my roof rack I've had for 5 years and maybe taking it off twice during that time. I discovered when removing it, some pretty bad rust issues. Initially, I noticed bubbles and some flaking so I started looking a little harder then ended up removing the headliner and Holy Smokes! I was not happy with what I found, I sealed the holes when I put the rack on but somewhere water got in and destroyed some areas. I have rust spots/ holes in all four of the factory mounting locations. One being so bad I have a sever hole in between the door seam and roof seam. Now I am bouncing around ideas on how to fix everything, being at the seams is making it difficult for me. I know I need to cut out the bad areas and clean, then I will use something like POR-15 for rust protection, I'm unsure how to patch up the hole right in the seam, I've seen several threads on welding pieces and not using bondo. If it was a flat spot I could do it, being at the seam I'm at an impasse. ideas or thoughts appreciated.
Honestly thinking about pulling all my mods and jumping ship.
Destroyed Factory Roof Mounting Locations-20200105_155511-jpg  Destroyed Factory Roof Mounting Locations-20200105_155612-jpg  Destroyed Factory Roof Mounting Locations-20200105_155522-jpg  Destroyed Factory Roof Mounting Locations-20200105_163315-jpg  Destroyed Factory Roof Mounting Locations-20200105_155717-jpg  Destroyed Factory Roof Mounting Locations-20200105_155729-jpg
Whosoever is delighted in solitude is either a wild beast or a god.
OutBreak is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 06:40 PM #2
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Thats insane for a six year old car. Makes me want to dump mine before these issues pop up. My old truck didn't have rust issues like i see these things developing and it was a 96 in the rust belt most its life. Sad. Aside from welding in patch panels, i don't think there's a better way. Maybe hit a junkyard and cut out the sections you need.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 06:55 PM #3
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Terminal rust cancer.
Start over.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 06:56 PM #4
ForRun's Avatar
ForRun ForRun is offline
ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all ForRun is a name known to all
ForRun's Avatar
I would use Flex seal and trade it!
ForRun is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 08:24 PM #5
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
What roof rack was it?
Old Tanker is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 08:47 PM #6
OutBreak's Avatar
Real Name: Cas
OutBreak's Avatar
Real Name: Cas
The rack was the full-length camelback metal gear. I don't think the rack had so much to do with it, as it is a 60/40 self-induced and a little bit of crappy Toyota manufacturing. I only sealed it one time at initial install with Permatex sealant and never refreshed it or really checked it (my fault). The other issue after inspecting, the factory white inserts that I assume helped seal the location inside the mounting points were virtually nonexistent. Some had them but were brittle and breaking apart others spot had nothing(Toyota manufacturing). Most of this was self-induced not inspecting like I should have been.
Old 01-05-2020, 09:05 PM #7
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
Wow! Just wondering, did you park your vehicle in a garage or out doors all if its life? I’m wondering if I should seal my roof rack mounts. I do park in garage when at home and live in sunny California.
mcat707 is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 09:08 PM #8
craaaazzy craaaazzy is offline
craaaazzy is on a distinguished road
Wow, that’s hard to imagine. Did u have any water leaking and puddling inside any where or staining onto the headliner? Need to check my rack on my LX.
craaaazzy is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 10:34 PM #9
RustyAb's Avatar
RustyAb RustyAb is offline
RustyAb has a spectacular aura about RustyAb has a spectacular aura about
RustyAb's Avatar
Holy crap!! I am sorry to hear this. I guess I will be taking my Prinsu off soon to dbl check and re-seal.
RustyAb is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 10:49 PM #10
jmf_tracy jmf_tracy is offline
jmf_tracy is on a distinguished road
WOW, that's horrible.
Sorry to see that, but you can't really fix that.
I would contact toyota and see if there is anything they can do, it should not rust out like that.
jmf_tracy is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 11:09 PM #11
kenwilliams0803 kenwilliams0803 is offline
kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about kenwilliams0803 has a spectacular aura about
Yikes. Put it back together, trade it in. Sorry to the next dude who gets it....not my usual way but this is unusual destruction.
There ain't much more to be done with that to fix it. I can't really see a way to make it right without thousands of dollars, and even then it won't be 100%.
kenwilliams0803 is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 11:26 PM #12
llDemonll llDemonll is offline
llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light llDemonll is a glorious beacon of light
why would toyota do anything? it's an aftermarket rack.
llDemonll is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 12:38 AM #13
CF_Machete's Avatar
CF_Machete CF_Machete is offline
CF_Machete has a spectacular aura about CF_Machete has a spectacular aura about
CF_Machete's Avatar
ugh... looks like I better pull m liner and check my mounts.
Troner envy... the struggle is real!
CF_Machete is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 01:11 AM #14
maxp0wer maxp0wer is offline
maxp0wer will become famous soon enough
What's the rough surface on the roof? Looks like Line-X or something? I wonder if this could have contributed.
maxp0wer is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 03:12 AM #15
anomalous's Avatar
anomalous anomalous is offline
anomalous will become famous soon enough anomalous will become famous soon enough
anomalous's Avatar
Damn, this shit got me paranoid. Just checked on mine, and although I don't have racks, I did remove mine to install the delete kit. From what I can see up top, things look ok. No obvious signs of rust from on top. With your rack on, you couldn't see any early signs of rust damage from the exterior? I would imagine that with this much rust under the headliner that there must've be just as much damage on the exterior?
∙ Toyota Racing Development ∙ Magnuson Superchargers ∙ Underdog Racing Development ∙ Baja Designs ∙ King Off-Road Racing Shocks ∙ Dirt King Fabrication ∙ Eibach ∙ Victory4x4 ∙ Hefty Fabworks ∙ Lil B Fabrication ∙ FN Wheels ∙ DuroBumps ∙ Toyo Tires ∙ Jomax Customs ∙ FJToyman ∙ UpTop Overland ∙
anomalous is offline   Reply With QuoteReply With Quote
areas , bad , hole , rust , seam
Any rust issues on Gen 5? Beach rust prevention. Fomer_FJ_owner805 5th gen T4Rs 8 09-19-2016 01:08 PM
Too much rust? jtharlow 3rd gen T4Rs 16 07-13-2015 09:55 PM
Rust?!?! DaniFami 3rd gen T4Rs 10 10-18-2012 09:50 AM
Has anyone in the rust belt had luck with a DIY rust inhibitor? MilesRacker 3rd gen T4Rs 5 10-17-2008 02:46 PM
Rust and rust prevention Thai Maintenance/Detailing 0 02-21-2007 10:58 PM
