Old 01-06-2020, 09:33 AM #1
amir_gh's Avatar
amir_gh amir_gh is offline
amir_gh will become famous soon enough
amir_gh's Avatar
What is this connector on 2016 4Runner Limited ?
Hello guys,
Does anyone have any idea what does this connector/sensor do on 2016 4runner limited? I took my rear bumper out to repair it and I noticed that connection. I looked at the wiring harness diagram, but I can't find anything. The wiring is damaged and I need to replace it.
Thanks in advance
Sent from my SM-N975U using Tapatalk
amir_gh is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 11:14 AM #2
Old Red Old Red is offline
Real Name: I no longer post or contribute to site that doesn't value members or their contributions.
Old Red is just really nice Old Red is just really nice Old Red is just really nice Old Red is just really nice Old Red is just really nice
@amir_gh that is the electrical connection for the outside luggage compartment smart key antenna. This is the antenna that detects the presence of the smart key for when you push the buttons on the rear hatch to open and close the window on the limited only. Hope this helps.
Old Red is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 11:45 AM #3
amir_gh's Avatar
amir_gh's Avatar
Thanks very much
Old 01-06-2020, 12:37 PM #4
amir_gh's Avatar
amir_gh's Avatar
Two wires are stripped. Do I need the entire wire harness or I can just fix those two?
Thanks
Old 01-06-2020, 01:23 PM #5
[email protected] Evan@B.I.B is offline
Evan@B.I.B has a spectacular aura about Evan@B.I.B has a spectacular aura about
If the plug is good, just repair/reconnect the wire.
2014 4Runner TE w/KDSS. Fox 2.5 FRS/2.0 w/ Toytec Superflex. 285 WILDPEAK M/T. SSO Slimline w/ Stage 2. Smittybilt X20 10K. Shrockworks Sliders. SP-9100. VIAIR 444C On-Board Air. Sprint Booster. DD SS3. BD LP4. Rigid Ditch.
Evan@B.I.B is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 12:23 AM #6
Thanks
If it were me, I would repair the two wires and call it a day. Those two wires running to the key antenna run the entire length of the passenger side of the Limited, and are part of the right hand floor wiring harness (P/N 82161-35F50 for Limited and P/N 82161-35F60 for Limited with the auto steps is between $980-1050 for the wiring harness just looking online). Replacing the entire wire harness for that much money for two wires is overkill.
Order the two repair terminals for the connector and splice them in. If you need to order another connector, do so. Repairing the two wires should run you less than $40 at the dealership. I don't know the connector number off the top of my head, but on the wiring diagram it is listed as connector "N21". The parts counter should be able to figure it out from there.
Good Luck!
-Old Red
Old 01-09-2020, 01:13 PM #7
amir_gh's Avatar
amir_gh's Avatar
Good Luck!
-Old Red
Thanks very much. This information helps me a lot
Old 01-09-2020, 02:49 PM #8
flyrv9's Avatar
flyrv9 flyrv9 is offline
flyrv9's Avatar
Agreed, it looks like a simple repair. You can either reconnect or use a splice if you need length to make the connection. Also, I'd wrap that connector to prevent future damage. A thin piece of rubber and a couple ty-wraps should do it. It's hard to see from those pictures just how much wire you have to work with there.
Old 01-09-2020, 03:42 PM #9
amir_gh's Avatar
amir_gh's Avatar
Thanks, I got these from dealer. They were relatively cheap.
  • Housing Connector F 90980-12416
  • Toyota Terminal Repair W W 82998-24250
Old 01-21-2020, 03:28 PM #10
amir_gh's Avatar
amir_gh's Avatar
Good Luck!
-Old Red
Hello again,
I can't find the that male terminal that connects to keyless Antenna. I went to dealer and they couldn't figure it out. Here is the connector picture. I can't find any thing in wire harness diagram. Do you know by any chance?
Thanks again.
Old 01-21-2020, 09:15 PM #11
Hello again,
Thanks again.
@amir_gh , here you go. Terminal number 82998-24360. Sounds like your local dealer is not too motivated lol. Given the project you are doing, you might want to pay the $20 for 48 hours of Toyota TIS access so you can view the OEM repair manuals, and info and download what you need so that you have it on hand. I have found it more useful than my local parts counter at times.
Old 01-21-2020, 10:07 PM #12
amir_gh's Avatar
amir_gh's Avatar
Your so awesome! Thank you. Found the connector and repair terminals. I cant believe that little thing was delaying my project car LOL. I cant wait to finish it.
Housing Connector M
Part Number: 90980-12519
Part Number: 82998-24360
4runner , diagram , guys , limited , wiring
2016 4Runner limited luvmylittleboy2003 5th gen T4Rs 0 05-13-2019 02:14 PM
Questions about the use of 4runner 2016 limited in Europe (Bulgaria) evgeniml 5th gen T4Rs 34 08-17-2017 05:49 PM
Full Grill Guard for 2016 4Runner Limited sayerlg 5th gen T4Rs 7 01-26-2017 04:24 PM
2016 4Runner Limited RWBlue01 General Discussions 22 05-23-2016 02:25 PM
2016 4Runner Limited ECBMCC 5th gen T4Rs 15 07-30-2015 09:41 PM
