Old 01-06-2020, 09:12 PM #16
mteolus's Avatar
mteolus mteolus is offline
mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold mteolus is a splendid one to behold
mteolus's Avatar
Get 2 rebuilt complete CV joints and swap them out. Get it done somewhere else. New will be very costly plus stealership labor. It's been a while ago but I swapped out a Jetta CV joint for $100 myself. Stealership wanted $800.
My guess is the grease was slung out of the CV boots after the rubber degraded and tore and the joint slowly wore out.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 Hankook Dynapro AT2 RF11 E-load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, LFD Hybrid bumper, LFD wind fairing, LFD Hi-lift jack mounts, Goat Armor, Blackgate Custom KDSS spacers, Ironman 2.5 awning with quick release mounts, Ironman 12,000 lb synthetic line winch.
Old 01-07-2020, 12:01 AM #17
yotantexas's Avatar
yotantexas yotantexas is offline
yotantexas is on a distinguished road
yotantexas's Avatar
Being in DFW I would contact Tandem Automotive in Haltom City. I want to say they quoted me $150 each to rebuild my stock CV axles. I would strongly recommend keeping your stock axles and having them rebuilt.
yotantexas is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 11:44 AM #18
DallasStarsFan DallasStarsFan is offline
DallasStarsFan is on a distinguished road
Thanks for the info. Gave them a call and they have a huge back log right now. He did tell me they send out the axles to be rebuilt so if I do end up having to pay for it Im probably going to oull them and take them someplace.
DallasStarsFan is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 01:05 PM #19
mteolus's Avatar
mteolus's Avatar
Seems like the place I got my CV joint at was Ft. Worth Drive Axle but this may be the same place. I think there may be a similar place in Dallas too. I just took it off and swapped it for a rebuilt one for $100. I am sure it will cost more than that like the $150 quote from Tandem. Tandem is a good place to get your vehicle serviced though. They specialize in Toyota 4x4s.
In order to get the Jetta CV joint out I had to buy a special 25 spline socket from Snap-on to get the big bolt on the outside off and then there were about 6 bolts holding the CV join on the inside. Then I had to dislodge a ball joint to be able to get it out. Wasn't too terribly hard.
One more thing, put this in a spray bottle and spray this on the CV boots before you put it on. It will make the boots last longer.
Old 01-07-2020, 03:27 PM #20
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
The axles are cheap relatively speaking. I broke my fronts. The main concern is any damage to the front differential. I had to wait almost 5 months for a new diff...all the while the undriveable truck sat on the shops lift. Toyota even confirmed the diff was in stock..still took months.
Edit to add, in my experience with snapped front axles, you hear a metallic clicking noise. The tires dont move and when snapped sag out of alignment and do not appear to be straight with the road. You wont be able to drive it and wheels look like they will fall off. Its a mess...
Grug556 is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 05:21 PM #21
mteolus's Avatar
mteolus's Avatar
I think in this case the CV joint was broken, not the axles.
Old 01-07-2020, 08:47 PM #22
yotantexas's Avatar
yotantexas's Avatar
what part of DFW are you in? Need help swapping the axle? I have been known to open my garage and lend a hand for pizza and beer.
Old 01-16-2020, 05:38 PM #23
I appreciate the offer. Up in the Lewisville area. The extended warranty company took care of it.
axles , broke , broken , case , oem
New to 4th Gen... Need parts advice... Front CV Axles & Hub.. 98Fizzy 4th Gen T4Rs 33 07-24-2021 03:30 PM
NEED ADVICE: new engine or go for broke oldskoolvws Classic T4Rs 20 07-07-2017 02:09 AM
Need advice: Timing belt broke. Fix or... ChuckFresh Problems & Warranty Issues 5 04-23-2017 06:51 PM
Valve Stem Broke, Need advice... ASTIGTOITS 4th Gen T4Rs 0 07-17-2007 12:50 AM
Broke my shocks, any advice on new ones? Gilles Classic T4Rs 3 02-28-2007 04:59 PM
