Closed Thread
Old 01-06-2020, 06:39 PM #1
mailbox mailbox is offline
mailbox is on a distinguished road
Mounting Options - KC Pro6 Gravity 8-LED
Got a nice deal on one of these but now I have to figure out how to mount it to my Gobi lol. Anyone seen anything or have any ideas for mounting these?
Sucks that the tacomas have a bracket design from KC but not the 4runners (because the 4runner fit is integrated with the rack presumably).
From very loose measurements my first problem looks to be that the bar is wider than the gobi rack by atleast 5 inches.
mailbox is offline
Old 01-07-2020, 06:15 PM #2
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
Take some pictures of the front fairing area, as well as the mounting feet for the KC bar. Without looking at either one, I'm guessing that some sort of tube clamps would be your best bet unless the Gobi already has mounts.
Race Ready Products > Vision X Tube Clamp Mounts
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
Old 09-13-2020, 06:03 PM #3
Figured I'd update this thread-- I finally got them mounted although not with the full 8 that I would have wanted.
Ended up contacting GOBI customs department for some ideas and they mentioned they had a kit already so I ordered it:
The cost was $180 and it took 1.5 months to arrive.
I used this product from KC to hide the wires along the windshield rather than mess with the weatherstripping on the edge.
Universal Wire Hider
The dash wires to the switch in the cabin I used the same hole everyone uses to shove the raptor lights through-- mine barely fit since I have amp power wire running down it too.
Mounted:
Video showing radius config:
https://i.imgur.com/iaiDJLs.mp4
mailbox is offline
Old 09-15-2020, 12:24 AM #4
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Mounted:
Time for a Switch-Pro, sPOD or at least a fuse box.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline
Old 09-15-2020, 08:57 AM #5
everything direct connected has a fuse
mailbox is offline
Old 09-15-2020, 09:22 AM #6
Sundy Sundy is offline
Sundy has a spectacular aura about Sundy has a spectacular aura about Sundy has a spectacular aura about
I think @sn_85 was getting at you could clean up your wiring/make future taps a bit easier with some sort of fuse block?
I think the lights look great! How are they at night, any photos? I do like the modern/retro combo look you get with them, a nice change up from the typical light bars!
2019 TRD ORP w/KDSS: Dobinsons IMS Lift (front C302 - 3" / rear C725 - 2.5"), Freedom Offroad UCA's, Falken Wildpeak AT3W 255/80R17, RSG Angled Kickout Sliders & Skid Plate, C4 Lo Pro, Warn Evo 10S, Agency 6 Flatlink, Diode Dynamics SS3 Fogs, Desert Does It Seat Jackers, Sherpa Crestone Rack, Outer Tents RTT
Sundy is offline
Old 09-15-2020, 09:30 AM #7
Definitely lots of room for improvement
With six lights the radius doesnt look impressive but from the cockpit it perfectly illuminated ahead of you and even to the sides. The lighting is so much better than stock
mailbox is offline
Old 09-15-2020, 01:12 PM #8
sn_85's Avatar
sn_85's Avatar
I'm referring to the rats nest of unnecessarily long runs of wire just balled up in your engine compartment. Messy wiring will lead to electrical problems and worse, sparks and fires. Proper length wires with good crimps hooked up to some sort of management system will avoid a lot of head aches and electrical gremlins.
sn_85 is offline
Old 09-15-2020, 02:55 PM #9
I get you, but I don't want to undo the factory KC harness and rewire it all just to shorten the length, it's all secured to something else out of the way for now via zipties and it hasn't moved around much while i've been driving
mailbox is offline
Old 09-15-2020, 08:19 PM #10
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
Cable salad.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline
Closed Thread
fit , gobi , integrated , mounting , rack
RTT mounting options Brique 3rd gen T4Rs 11 07-23-2019 01:17 PM
KC HiLites Gravity PRO6 LED Light Bar - Game Changer Desgin! what do you think? TotalAutomotiveLV General Discussions 21 05-16-2019 01:11 PM
GPS Mounting Options jbirk 5th gen T4Rs 21 05-04-2018 03:12 PM
phone mounting options Zackadeez 3rd gen T4Rs 8 05-07-2013 02:41 PM
Phone Mounting Options dgwood12 4th Gen T4Rs 13 02-01-2013 02:54 PM
