Old 01-06-2020, 07:13 PM #1
Jeff_DML Jeff_DML is offline
Jeff_DML will become famous soon enough Jeff_DML will become famous soon enough
small lift that maintains some rake
I have been endlessly searching through different threads on this forum but still cannot determine my ideal options.
Want:
Small lift without requiring new UCA/maintenance issues.
Want to maintain some of the factory rake since I do load up the back camping.
Thinking:
2" in front and 1.5" rear
5100 struts
Having issues finding springs that maintain rake. Most seem to remove and/or have more then > 2" front travel.
So far I have only found dobinson springs as a option for me. Am I missing any other options? OME seem greater, wheelers/eibach remove rake
TIA
Jeff
My setup is stock 2018 SR5 running 285 K02 on TRD rims.
Jeff_DML is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 07:24 PM #2
chimaylxa chimaylxa is offline
chimaylxa is on a distinguished road
I would agree that Dobinson is probably your best choice for what you want. Since you want to lessen but not eliminate the rake, that makes this difficult.
16’ SR4 4WD (de-tforced) - 5100s, OME 3” Heavies front and rear, 285 KO2s, SSO Stage 2 front and Trailgator rear bumper and sliders, Comeup DV-9 winch, Prinsu 3/4 rack, RCI “Yes” steel skid plates (all but rear links and rear shock mounts which I will be adding).
chimaylxa is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 07:38 PM #3
bjs0131 bjs0131 is offline
bjs0131 is on a distinguished road
Just go with an adjustable setup on the front. I’ve quite happy with the Bilstein 6112 which can be adjusted 0 - ~3” to match whatever rear springs you end up with and dial the rake as you want.
FWIW I used 6112 at position 4 (I have KDSS) and netted ~1.75” front lift. I left the rear springs stock and I still have 3/4” rake.
bjs0131 is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 07:53 PM #4
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
I am a firm believer in maintaining some rake… it’s there for a reason.
Unfortunately I don’t know the secret sauce on the 5th gen, but I was able to get achieve it on my 4th using 6112 (one down from the highest setting) and the OME 2895 rear spring. Loaded up with a medium to heavy load and it not only levels out well, rides great on and off-road.
I think I got somewhat lucky in terms of getting right the first time, but Wheelers Offroad did guide me in the right direction. If you like Dobinson, I would talk it out with the vendor, I’m sure they can provide some guidance.
If I had to do my setup again/upgrade, I would consider picking the rear coil I wanted and getting a threaded front coilover for max performance and adjustability. I have become quite accustom to having nice shocks and most all higher end shocks are all threaded.
Old 01-06-2020, 08:16 PM #5
Ryan at Eibach's Avatar
Ryan at Eibach Ryan at Eibach is offline
official vendor
Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light Ryan at Eibach is a glorious beacon of light
official vendor
How about this:
Eibach rear shocks.
Eibach rear 1" springs.
EIbach front shocks
Factory front springs.
If you lift the rear an inch and the front only .8 (second clip) or 1.6" (third clip) you'll still have rake.
2019 TRD Off Road
2007 GT3
1982 911 SC
Ryan at Eibach is offline   Reply With QuoteReply With Quote
lift , rake , remove , small , springs
too much rake after lift jdm-v35 5th gen T4Rs 21 08-07-2020 07:12 PM
Post lift Rake stephan07 5th gen T4Rs 20 04-28-2018 11:04 AM
My lift has a rake I would like to get rid of Semper_Fi 3rd gen T4Rs 6 02-04-2014 03:01 PM
Small lift with good rake winninchoochoo 3rd gen T4Rs 4 01-02-2014 08:56 PM
Maintains light on! Ruben Maintenance/Detailing 4 11-21-2006 12:42 AM
