Old 01-07-2020, 12:54 AM #1
NWsuperwhiterunner NWsuperwhiterunner is offline
NWsuperwhiterunner is on a distinguished road
Front skid plates
I knows there's a million different pages on skid plates but I'm looking for some reall world advice. I have a new 19 non kds Trd Off road that is stock but for trd pro wheels and Ko2's in the stock size. The truck is a weekend warrior and sees light trail use no dragging it through the Rubicon. I'm looking for a quality from skid that will take abuse if I miss a boulder in the snow and ideally not have to remove it to change the oil. I've already read way to horror stories about striped out bolts. What have you all had good luck with ?
NWsuperwhiterunner is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 01:06 AM #2
DannyLlama's Avatar
DannyLlama DannyLlama is offline
Real Name: Danny
DannyLlama has a spectacular aura about DannyLlama has a spectacular aura about
DannyLlama's Avatar
Real Name: Danny
You are not asking the right questions.
There aren't too many bad reviews of aftermarket skid plates.
It depends on if you are going to get a set or not, because most manufactures make full skid set that connects, otherwise you may have fitment problems.
I myself have missed a boulder and dinged my skid. Is it worth it for that one time, yes. Is it worth it to drag the extra LBS every day. Thats a question you have to ask yourself.
There are plenty of people running stock skids with lifted trucks. Beat them up and then get them replaced.
Again.. what are you really wanting to know? Good luck with what?
Edit - congrats on your purchase and welcome to the forum : )
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg ball joint UCA's Fox 2.0 Resi rear W/ Icon 2" Springs. FN Wheels BFDs, Toyo Open Country A/ II Xtreme 285/65/18. Shrockworks custom sliders LLama Tales
Dual Battery Thread
DannyLlama is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 01:44 AM #3
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R is a name known to all MAST4R is a name known to all MAST4R is a name known to all MAST4R is a name known to all MAST4R is a name known to all MAST4R is a name known to all
MAST4R's Avatar
Yes, so long as you use the stock springs, you will hit. It is inevitable with any frequent offroading. You cannot always be 100% on long days or with frequent trips and the stock suspension leaves no room for error.
My RCI 3/16 steel skid has done the job. While it leaves the alignment bolts exposed, I have had no issues with that (over 100 trails between 4x4 and dirt roads).
That said, I don't just have a dent, I completely caved half of it in. Sure, I was testing new springs and found them softer than expected...but I already had real damage to the skid from another hit, which is the kind of hit you are trying to protect yourself from.
So in the Southwest, I would not personally spend 1 cent on an aluminum skid for a 4Runner (had one on a Subaru). In a state like Montana, on the other hand, where 4x4 trails are few and far between (and where speeds are very low) and where smooth dirt roads are plentiful, aluminum might make perfect sense. Here in the desert, my worst hits come on easy trails (high-clearance trails, neither dirt roads, nor 4x4 trails). They can be very long and generally ok to drive a little faster but they always have tricky spots.
Another option is to get a better suspension and keep the stock skid plate. There is a lot of air behind it (which is why I have not replaced mine now that it is caved in) and the front skid has very nice design. The curved radiator supports carry much of the load during a hit. So I would stay away from designs that remove those supports.
Another point: skids and suspension are in the same conversation.
Lots of people including myself until recently, attribute too much to ground clearance as measured in the garage and to skid plates. The reality is that a stiff enough suspension does a better job at preventing hits offroad than a ground clearance increase that preserves the stock suspension.
In other words, you can do skids, or suspension, or both, depending on need. But a single skid upgrade is not necessarily the best answer. Consider that the three front skids necessary to slide/drag with peace of mind cost as much as a solid suspension upgrade that also yields 1.5" of lift.
(6112s/650lb at 1.3" lift, Icon 2.0 and Eibach 1" rear, Mickey Thompson ATZ P3 LTE 265 70 17 and Falken Wildpeak AT3W P265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids).
Old 01-07-2020, 01:54 AM #4
borfoo3's Avatar
borfoo3 borfoo3 is offline
borfoo3 will become famous soon enough borfoo3 will become famous soon enough
borfoo3's Avatar
A weekend warrior won't need anything more that TRD skid plates. Heavier skids = more weight = more sag = less clearance, which is not good.
More clearance, better driver, and less skid action is what you want
2015 T4R TEP-KDSS - Overland build, getting slower by the mod:
Borfoo3's '15 TEP-KDSS 'no longer' mild build
borfoo3 is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 02:56 AM #5
the_economist's Avatar
the_economist the_economist is offline
the_economist is on a distinguished road
I got a full set of 3/8 inch steel RCI skids -- plus the gas tank -- and would recommend that to you.
People complain about the weight from steel skids. But it is only around 120 lbs. -- 175 lbs. if you also add the steel gas tank skid -- which is comparable to the weight of a full tank of gas (23 gallons x 6 lbs a gallon = 138 lbs.). That's like driving around with a small-ish friend and complaining about the extra weight -- give me a break. 175 lbs. is about 3 percent of the gross weight of a 5500 lb. 4Runner, which is next to nothing for the protection you get in return.
The RCI skids have an awesome oil drain plug access hole and a hatch for the oil filter. Very easy to install (I used a floor jack to support them and installed myself) and are an excellent fit on the 4Runner.
2016 4Runner SR5 4x4. BFG A/T K02s (275/70/17 E Rated). 2-inch Icon rear springs. Bilstein 6112s front (1.2" setting), 5160s rear. RCI skid plates package + gas tank (3/8 in. steel), RCI rock sliders. Warn semi-hidden winch mount + Warn Zeon 10-S Platinum winch. Raingler cargo nets (roof and rear). TRD wheels.
the_economist is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 11:45 AM #6
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of Jetboy has much to be proud of
Jetboy's Avatar
Your stock skid is perfectly fine for what you describe. I've yet to see a single instance of anyone ever having damaged something behind the stock engine skid. I took my OEM skid through the Rubicon. Looked like a raisin by the end. But - it did it's job just fine. Nothing inside it was damaged. It actually did better than the aluminum TRD Pro skid. The OEM steel one is a better skid than the aluminum one functionally. It just doesn't look as nice.
If you are mostly concerned with function if you hit a rock - keep the oem one. If you want to drag it across rocks consistently, then it's probably a good idea to consider an upgrade.
Old 01-07-2020, 11:53 AM #7
I had a 03 Tacoma and destroyed the stock skid on a boulder hidden in the snow so I'm a looking for something that will take a hit better than stock, I like the PRO skid but don't like having to remove it to do a oil change.
Old 01-07-2020, 01:00 PM #8
mteolus's Avatar
mteolus mteolus is offline
mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all mteolus is a name known to all
mteolus's Avatar
I've got the RCI skids, although mine is KDSS. They work fine, just make sure you put anti-seize on all the bolts before you put them in. I've got aluminum which is fine for what I do especially with a 3 inch lift.
2017 Off-road Premium w KDSS, moon roof, sliding rear cargo deck,3" Toytech Boss lift, SPC upper control arms, Sonoran Steel High Articulation KDSS Trac/PanHard Bar, RCI sliders, RCI skid plates aluminum including gas tank, C4 Fab diff skid plate, SCS Ray 10 Wheels Matte Gray, 285/70R17 BFG KO2 C load RWL, Cali Raised LED 3x2 fog-light pods, Lock'r Down EXxtreme console safe with electronic lock, Auto Heat Shield all windows, Raingler rear cargo net, Canvasback rear covers, LFD Off-Road cross bars aluminum, wind fairing, and Hi-lift jack mounts, Goat Armor.
Old 01-07-2020, 01:41 PM #9
SpeedyKevin's Avatar
SpeedyKevin SpeedyKevin is offline
SpeedyKevin is just really nice SpeedyKevin is just really nice SpeedyKevin is just really nice SpeedyKevin is just really nice SpeedyKevin is just really nice
Tbh the stock steel skid was fine for me (i also have steel diff, tcase and trans plus alloy fuel tank) but wanted easy access to the filter so I got the rci alloy front skid. Does the job well and i can hammer out the dents (doing that right now)
2019 ORP - KDSS, Dobinsons C59-302/GS59-700 front and C59-725/GS59-705 rear, Dobinsons UCA, DuroBump/Daystar bumpstops, Sonoran Steel High Articulation tracbar, Marlin Crawler LCA frame brace, OGS Lo-Key Bumper w/ Warn VR-10S, RCI Sliders, fully armored with RCI/C4/Outgear Solutions skids, Falken Wildpeak M/T 285/70/17, LFD SS-Crossbars, ARB breather kit (Rear Diff and Locker), ScanGaugeII, Anytime Front/Backup Camera, onboard ARB Twin compressor and MORRFlate kit
SpeedyKevin is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 05:39 PM #10
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 will become famous soon enough shrub1 will become famous soon enough
shrub1's Avatar
Another vote here for the aluminum RCI.
Mine has had a few hits and it holding up just fine.
shrub1 is offline   Reply With QuoteReply With Quote
Old 01-07-2020, 05:45 PM #11
JAXJeremy's Avatar
JAXJeremy JAXJeremy is offline
Real Name: Jeremy
JAXJeremy has a spectacular aura about JAXJeremy has a spectacular aura about
JAXJeremy's Avatar
Real Name: Jeremy
Primarily bought the RCI skid for easy oil drain access..haven't been offroad with it yet, but I like the looks and have no doubt it will hold up well to whatever I throw at it..
'18 SR5 4WD, magnetic gray metallic, stock
JAXJeremy is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 02:13 PM #12
chimaylxa chimaylxa is offline
chimaylxa is on a distinguished road
Granted, I did not have the fancy factory skid plates, just SR5 4WD model, but I banged my front skid plate pretty good fairly quickly to the point that it had to get notched and beat to put it back on after an oil change. The next skid plate that took a beating was the gas tank skid plate and I wish I had a rear diff skid plate shortly after that as I partially destroyed the drain bolt.
I went with RCI Steel, partially because I was going with what my guy carries, and Id seen good reviews and feedback on both the aluminum and steel. I went with steel because I do get on rocks and things like that.
Steel may be overkill for what you need especially if stock suspension (as alluded to above).But armor is better to get before you need it. Ive learned that one and you can learn from me.
16 SR4 4WD (de-tforced) - 5100s, OME 3 Heavies front and rear, 285 KO2s, SSO Stage 2 front and Trailgator rear bumper and sliders, Comeup DV-9 winch, Prinsu 3/4 rack, RCI Yes steel skid plates (all but rear links and rear shock mounts which I will be adding).
chimaylxa is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 02:30 PM #13
Check these beefy plates out!
Metal Works Fabrication on Instagram: Had a chance to install some Marlin Crawler HD LCA frame brace on 5th gen 4runner. The braces are heavy duty and reinforces the oe
Old 01-09-2020, 02:33 PM #14
Alum has been holding up well. You can see the dent on the right side. Will likely replace it with steel later in the year as my wheeling habits have changed lol
boulder , plates , skid , stock , trd
WTB: 1996-02 OEM front skid plates Thebeastmode3 For Sale: T4R Items 11 02-28-2018 08:43 PM
Skid row 3 front skid plates cheap! spitvenom For Sale: T4R Items 13 08-21-2012 09:47 AM
Front Axle Rattle, No Skid Plates zerowkul98 4th Gen T4Rs 7 08-10-2010 09:32 PM
Queston about area in front of skid plates howieb 4th Gen T4Rs 7 04-04-2010 09:38 AM
Front skid plates? cjm5027 Off-Roading 15 04-11-2007 11:25 AM
