Old 01-08-2020, 11:13 PM #1
aaronRR's Avatar
aaronRR aaronRR is offline
aaronRR is on a distinguished road
aaronRR's Avatar
Icon stage 2 with Icon wheels rubbing
Figured this was snow and ice, but I noticed in normal conditions I'm getting a lot of front tire rub on the rear mud flaps with 265/70/17 Wildpeaks with the Icon stage 2 extended travel lift. I wasn't getting the rubbing pre lift.
Not sure how normal that is? That it was wild for only being a 265 sized tire.
Parts installed:
- ICON 2003-UP Toyota 4Runner Adjustable Rear Track Bar
- ICON 2010-Current 4Runner Stage 2 Lift w/ Light Racing UCA's
- ICON Rebound 17" Wheel Titanium Matte Finish (0 offset 4.75 backspacing)
I was going to upgrade to 285's but if I'm rubbing at 265's it sounds like a disaster.
Any thoughts?
@offRoadxp | 2019 4Runner TRDO ⁌ RSG Rock Sliders ⁌ RCI Skid Plates ⁌ ICON Stage 2 Extended Travel w/ SPC UCAs ⁌ ICON Rebound Wheels ⁌ 285/75/17 Yokohama Geolandar G003s ⁌ Prinsu Full Roof Rack ⁌ FSR Evolution RTT ⁌ SSO Offroad Bumper w/ Smittybilt 12k Winch
aaronRR is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 11:18 PM #2
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
how's your caster?
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 11:18 PM #3
bmrplatinum bmrplatinum is offline
bmrplatinum is on a distinguished road
Sharp looking truck
bmrplatinum is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 11:21 PM #4
aaronRR's Avatar
aaronRR's Avatar
Originally Posted by daytonaviolet View Post
how's your caster?
3.4 degrees each side
Old 01-08-2020, 11:23 PM #5
idHawk idHawk is offline
idHawk is on a distinguished road
Those wheels look great on your rig. I hope you get it sorted out.
idHawk is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 12:42 AM #6
deadbeat son deadbeat son is offline
deadbeat son is on a distinguished road
Just to clarify, pre-lift were you running the ICON wheels?
deadbeat son is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 12:43 AM #7
aaronRR's Avatar
aaronRR's Avatar
I had the wheels a few days before the lift and didn't notice any rubbing, but I guess I could've missed it. I figured 0 offset would be safe?
Old 01-09-2020, 01:25 AM #8
If your rubbing front flaps during lock to lock, perhaps set caster forward to 3.5 or 3.6.
Old 01-09-2020, 01:26 AM #9
aaronRR's Avatar
aaronRR's Avatar
Yeah it's just the front mud flaps, but it's enough to feel it in the steering wheel at full lock
Old 01-09-2020, 09:47 AM #10
this is ironic (i know not your specific wheel but it's the same thing) from icon website:
"Staying true to the ICON Alloys approach, the ALPHA has been engineered to maximize caliper clearance and optimize wheel position for un-hindered suspension travel and steering function. Backspace dimensions and wheel offset have been strategically developed to reduce scrub radius, improving all-around handling and ride quality and making a set of these wheels the perfect complement to an ICON Vehicle Dynamics suspension system."
Old 01-09-2020, 11:35 AM #11
shrub1's Avatar
shrub1 shrub1 is offline
shrub1 has a spectacular aura about shrub1 has a spectacular aura about
shrub1's Avatar
You need to get that caster to 3.8- 4. Shouldn't be an issue with the SPC UCAs.
I also have Icon S2 (albeit running TRD wheels) with 285/70/17 RGs and have zero rub. My caster is at 4 with the same SPCs and drives great. I know all rigs are a little different, but you should be able to get there without removing the mud flaps. What are your coil overs set at?
shrub1 is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 12:06 PM #12
badattitude's Avatar
badattitude badattitude is offline
badattitude will become famous soon enough badattitude will become famous soon enough
I like negative camber, granted that's splitting hairs. Push the bottom of the tire out a bit.
2015 4runner Limited - URD Y-pipe
2008 V6 Sport Edition
1999 4runner
TRD Air Filter. Airaid MIT. O ring mod. TRD Exhaust. Front Discos. TrueTrac
badattitude is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 02:01 PM #13
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Remove front mudflaps, trim the corners of the bumpers inside the fender well and push the fender liners forward.
This was required for me running 265/70r17s with a 1" front level, and 1.25 wheel spacers.
Extremely easy to do.
YouTube
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 05:56 PM #14
aaronRR's Avatar
aaronRR's Avatar
The coilovers are set at stock (what Icon set them to delivered)
Just figured it wouldn't be an issue with 265's at all.
Old 01-09-2020, 05:57 PM #15
aaronRR's Avatar
aaronRR's Avatar
YouTube
Yeah I have no issues with cutting, just figured I wouldn't have to cut with zero offset and 265s.
4runner , icon , lift , rubbing , stage
Toyota 4Runner 2010+ ICON Stage 1 vs Stage 2 TotalAutomotiveLV 5th gen T4Rs 140 02-15-2022 09:39 PM
5th Gen 4runner Icon Stage 2 w/ Tubular UCA & XD Addict Wheels - FL lilsid112 For Sale: Suspension/Wheels/Tires 17 12-28-2018 07:56 PM
Icon Stage 2 & 2014/15 Trail Wheels & 285s BenSD 5th gen T4Rs 14 11-06-2014 03:32 AM
ICON Suspension for 4th Generation - Icon Stage 6 WOLVERINE Want to Buy/Trade 2 02-18-2013 01:39 PM
