Old 01-10-2020, 11:46 PM #1
KF4R2011 KF4R2011 is offline
KF4R2011 is on a distinguished road
Reverse lights as switched work lights
Does anyone know if it’s been done or how to make the existing reverse lights be switched so they can be on when the runner is in park or drive? One of the empty switch locations for seat heaters may get a new switch. Do not want to add lights or change existing light functionality.
KF4R2011 is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 08:20 PM #2
jp.vegas jp.vegas is offline
jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light jp.vegas is a glorious beacon of light
If you install a "tails as turns" module, the original turn signal fixture can become individually switched as there's a simple pigtail that now powers them. They have a pigtail that can be used to toggle power to that fixture from another source, like a separate switch on the dash. Put white LEDs in there, run the wiring to your new dash switch, and bam! New switchable work lights in the original tail light fixture.
'20 Army Green 4Runner TRD PRO
'16 Quicksand Tundra TRD PRO Gone
'08 Salsa Red Pearl 4x4Runner SE V6:
Gone
jp.vegas is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 11:02 PM #3
For back up lights? Didn’t see reverse lights in their write up.
Old 01-13-2020, 12:19 AM #4
No, for the turn signals you no longer need. The way it works you end up with a spare set of lights in back that can easily be switched to use whenever you want. They’re ready to accept a single spade connector with 12v from your relay or switch.
It’s rather brilliant actually. I’m using them for a second set of reverse light now but you don’t have to. My plan is also to run switched 12v back there and use them for camp lights.
Gone
Old 01-13-2020, 12:51 AM #5
Yeah I was just wanting to send 12v to the lights downstream of the transmission switch. Diode the path back to the transmission switch. Somehow regulate the voltage so the lights don’t get 24v. Switched from the center console. No change in stock functionality.
Old 01-15-2020, 11:53 PM #6
weaselbob74 weaselbob74 is offline
weaselbob74 is on a distinguished road
You wouldn't get 24V by completing the circuit as you described. I have thought about doing something similar for forcing my fogs on outside of using the factory switch.
So far this is what I came up with. I think you would just need a second diode on the stock path to the backup lights. So two power outputs to the lights with no path for the power to return. The only thing is, you might get a bulb out warning light on the dash.
2018 Limited White l TRD CAI
2016 SR5 Premium Black l Shrockworks Rock Sliders l TRD CAI l HID | General A/TX | TRD Grill | Raptor Lights
weaselbob74 is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 03:24 AM #7
If I didn’t toggle off the switch before going into reverse I think I would. Diode blocks backward flow. The computer could still “see” the reverse lights cause the flow would not be affected in that direction.
existing , lights , reverse , switch , switched
Reverse lights don't work rdswriter 5th gen T4Rs 2 11-18-2017 05:48 PM
2007 4runner lights, horn and blinkers work, but hazard will not work rki1966 4th Gen T4Rs 1 09-21-2014 02:08 PM
Installed ProComp lights, now the climate control lights don't work 94stick Classic T4Rs 1 04-21-2014 09:53 AM
Dash Lights Failed. Running Lights Work. CanadianTRD 3rd gen T4Rs 4 08-14-2012 11:10 PM
LED Tail Lights w/led turns & reverse lights 00328 4th Gen T4Rs 2 01-01-2008 11:06 PM
