View Poll Results: Any 2015-2018 4Runner mechanical or cosmetic issues?
1-2 issues
21 |
26.92% |
2-3 issues
7 |
8.97% |
Total failure
1 |
1.28% |
Not 1 issue
49 |
62.82% |
01-12-2020, 11:04 PM
#16
Originally Posted by billiamwu
2018 TRD Pro with 25k miles
1) The steering wheel is peeling
2) Brakes needed replacing at 20k miles (granted I do have armor, front and rear bumper, larger tires and use it offroad a good amount)
3) Intermittent bluetooth issues between phone and Entune (this can probably be fixed with software updates on both Toyota and Android/iOS)
My old Ford expedition would go through brake pads every 25,000 miles. So with what you have on your truck and use it makes sense.
Sent from my SM-N960U using Tapatalk
01-13-2020, 12:18 AM
#17
2017 ORP zero issues
2018 ORP zero issues
I have had problems with the dealership oil change crew. They should be closely monitored.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
01-13-2020, 12:21 AM
#18
Real Name: Bump
Real Name: Bump
2015 TEP and only issue has been door locks actuators in front driver and front passenger.
Crossed over 112k today
2015 Magnetic Gray Trail Premium - Build Thread: https://www.toyota-4runner.org/5th-g...ight=mbumpus11 <<<--- click that to see what I've done
01-13-2020, 01:05 AM
#19
Originally Posted by bigbadpoppa
2016 4runner : passenger pillar squeaking. Never could get it silenced.
2019 4runner: passenger pillar still squeaking but less prominent. Front suspension squeak, dealer replaced control arms.
How sure are you it's the pillar?
01-13-2020, 11:12 AM
#20
33k on my 2016. Only real problem is front dif needle bearing, that I've decided to fix myself with the aftermarket bushing.
'16 TEP
'21 Model 3 LR
01-13-2020, 01:47 PM
#21
At 37,000 miles, really only one mechanical issue. The second row seat back release cable disengaged from the bracket. The fix was simple by crimping the cable bracket tighter with some high-leverage pliers.
'16 Magnetic Grey SR5 Premium - FN 6-Shooters, 265 KO2s, TRD CAI, various other do-dads
So happy to be back in a 4Runner again! Previous Toys - '87, '89 and '93 4x2 Pick Ups, '03 4Runner, '08 Sequoia
01-13-2020, 03:06 PM
#22
Real Name: Danny
Real Name: Danny
Only real "issue" is that my steering rack has been leaking for a while... A few have had it replaced at around 150K. I'm at 110 and its still OK for now.
2010 LE > TE Conversion, Fox 2.5 DSC Front W/ Camburg BJ UCA's Fox 2.5 Resi rear W/ Icons. Method 701's, Cooper S/T Maxx 285/70/17. Shrockworks sliders. LLama Tales
Dual Battery Thread
01-13-2020, 03:08 PM
#23
1 blown lift gate strut, that's pretty much it.
2015 Magnetic Gray SR5P
01-13-2020, 03:21 PM
#24
2016 TE 41k miles. All good here. One dealership visit for the airbag recall. No squeaks, no door lock actuators broken (yet), no front diff noise (yet).
01-13-2020, 03:35 PM
#25
2016 TE Premium with 89,000 miles.
1. All four door lock actuators have failed and had to be replaced.
2. AC Blower motor failed and had to be replaced. 2nd AC Blower motor is occasionally acting up (fan speeds increase or decrease with no input, clicking sounds, etc.)
3. Entune head unit is crap and cannot connect to iphone with contacts enabled. It's past time for a major software refresh.
01-13-2020, 04:17 PM
#26
Real Name: Dave
Real Name: Dave
‘18 SR5. No mechanical issues. But ...
* Seatbelts. They always twist when putting them on. Belt refuses to lay flat across my chest. Retractor is weak, I have to work with it each and every time I park and exit to get it retracted all the way. I had a ‘02 Tacoma that was the very same.
Otherwise the only issue is not the vehicle, but Toyota accessories.
* Cargo privacy cover - 6” gap front and rear. Opening and closing constantly hangs up on the 3rd row seatbelts.
* Cargo floor mat - thin plastic. Slides around. Feels crappy for the high price.
* Cargo net across rear - Rolly things fly right through it upon lifting the tailgate. Lost a 1.5 liter bottle of bourbon, several gallon jugs of water and milk, lots of cantaloupe and watermelon.
I also have a ‘12 Subaru Outback. It’s OEM privacy cover has no gaps. The OEM cargo floor liner is thick rubber and feels premium.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
01-13-2020, 05:17 PM
#27
My steering wheel is peeling slightly. Also, on the center console where the shifter is, there are some slight "chip" marks. I have 83k miles, and no mechanical failures. Both cosmetic issues were there when I bought the vehicle at 59k.
One day, Ariana Grande was walking by a school. She watched a young boy drop his books and his papers went everywhere. No one stopped to help him, and he looked very lonely and sad. Ariana stopped what she was doing, and helped him collect his things. "One day, you will grow up to do great things if you keep working hard and never quit" Ariana told him. That boy was Barack Obama.
01-13-2020, 05:26 PM
#28
Rear seat covers coming unattached twice.
Door lock actuator fail
Steering wheel peeling badly
2016 60,000 miles
I have a similar problem that turned out to be the rubber around the windshield squeaking on the glass. I use a little bit of silicon lubricant sprayed under the seal every once in awhile to quiet it down. It’s a pain to get it under there but it does work if you find the spot where it’s squeaking.
03-15-2020, 12:45 PM
#29
Good to know. I'll check out the windshield for squeaks. Drives me mad sometimes. Never thought it would be that.
03-15-2020, 12:56 PM
#30
Originally Posted by patkelly4370
I use my phone (Tapatalk) and can't see polls.
2017 SR5, 23,000 miles on it.
Zero issues, everything works properly. Absolutely no complaint.
Ok, I do have an issue.
Family doesn't want to go 4-wheeling. I have no friends to go 4-wheeling with. So I have to go solo.
Not ideal for someone new to off-roading.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
