Old 04-26-2020, 08:21 PM #31
pookguy pookguy is offline
pookguy will become famous soon enough
I had some wired to my Switch-Pros only cause the Leds were stupid bright so I would turn off depending on the occasion.
pookguy is offline   Reply With QuoteReply With Quote
Old 04-26-2020, 11:33 PM #32
BlueEyedDevil's Avatar
BlueEyedDevil BlueEyedDevil is offline
BlueEyedDevil will become famous soon enough
What’s involved with having the raptor lights attached to the amber parking lights? I can’t seem to find where people have set this up like that and provided a description of how they did it.
BlueEyedDevil is offline   Reply With QuoteReply With Quote
Old 08-15-2020, 11:50 PM #33
Moving Chicane's Avatar
Moving Chicane Moving Chicane is offline
Moving Chicane is on a distinguished road
Disregard
Already Gone.
Moving Chicane is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 02:31 AM #34
firegod33r's Avatar
firegod33r firegod33r is offline
firegod33r is on a distinguished road
firegod33r's Avatar
Originally Posted by nimby View Post
I initially wired my raptor lights up like you. Then I added a switch by doing the following:
Get this wiring harness:
Amazon.com: Zmoon LED Light Bar Wiring Harness, Off Road On Off 12V 40A with 3 Fuse Power Switch Relay for LED Work Lights Driving Fog Light: Automotive
I cut the switch off this harness and added my own OEM style switch. The colors of wire coming from the switch will not match up exactly with the colors from the wiring harness, so you might have to play around with it in order to get it to work. There is a youtube video of some kid adding an OEM style switch to this wiring harness on his Tacoma. It's a helpful reference.
Pardon my lack experience here, but I have a small issue I’m trying to resolve. I ordered this exact wiring harness from Amazon. I followed your direction from the previous posts and connected the raptor lights to the black and white coming out of the relay. Then ran the switch inside and connected it to my AOB switch...now I’m starring at a black and red wire that comes out of the white connector that goes to the Amazon switch. Where did you connect the red to?
I tried the red directly to the battery, but the raptor lights comes on even when the vehicle is off and no key in the ignition. Is that how it’s suppose to be?
The black is obviously ground, but I’m just so confused by the red wire.
firegod33r is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 12:14 PM #35
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Maybe watch this video: Wiring Factory Style Switch For LED Light Bars - YouTube
I am assuming you are talking about the wire that should either go to an "add a fuse", you can tap into a fuse that is "hot" when the vehicle is on. You can also just tap into the parking light wire, so the raptor lights are only on when your headlights are on. It just depends on how you want it.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 12:31 PM #36
firegod33r's Avatar
firegod33r's Avatar
See if this pic helps. My blue coming from the ARB switch is the one I had connected with an add a fuse so it lights up when I turn the key. If I’m understanding you correctly then I would end up with 2 add a fuses? Thanks
Wiring raptor lights to button?-image0-jpg
Old 12-09-2020, 01:34 PM #37
pDubs's Avatar
pDubs's Avatar
You don't need to have 2 add a fuses, you can have both wires going into the crimp part on the same add a fuse.
2014 SR5P
Old 12-09-2020, 02:47 PM #38
firegod33r's Avatar
firegod33r's Avatar
I’m I’m gonna try that. Is it correct that the high voltage is only drawn through the relay? So there is never any chance of any short or melting in the switch harness?
Old 12-10-2020, 09:27 AM #39
firegod33r's Avatar
firegod33r's Avatar
Tried and didn’t work. It appears that even though I bought the same harness as mentioned earlier, it’s not correct for my application. I only have 1 single white wire going from the relay towards the ARB switch. And just before the switch it splits into 3.
Old 12-10-2020, 10:44 AM #40
smeerun's Avatar
smeerun smeerun is offline
smeerun has a spectacular aura about smeerun has a spectacular aura about smeerun has a spectacular aura about
smeerun's Avatar
This video breaks it down real easy and is applicable to connecting any light setup with a button. I followed this video to a T and found success in wiring my raptors to a switch. Early in the video he goes over the wiring diagram.
How to Wire an LED Light Bar Properly (Project Night Light Episode 3) - YouTube
Sent from my Pixel 3 using Tapatalk
[Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
smeerun is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 11:34 AM #41
pDubs's Avatar
pDubs's Avatar
First: You are wiring for Raptor lights, correct? You defintely want these on a switch as opposed to being on when the vehicle is running? Maybe you can post how you ran the wire so far from the lights.
Second: AOB, not ARB. Air on Board switch, correct?
This should help as well.
Marker Lights (Raptor Lights) Mod for 5th Gen 4Runner - DIY Version
The Amazon link you posted has a diagram, you should follow that exactly. The included switch with the harness has 3 wires, your AOB has 4, because you can tap into a wire that will illuminate the switch when your headlights are on, like all the other switches in the truck (to some people that may not be important).
2014 SR5P
Old 12-10-2020, 12:46 PM #42
firegod33r's Avatar
firegod33r's Avatar
Yes these are for raptor lights, let me explain with pics of what I have so far. Because I feel like we’re going around in circles lol.
This is the where the raptor lights are connected to, (green and red)
You can see the relay and red and black to the battery
From the relay comes out a white wire
Wiring raptor lights to button?-73e36ded-660e-47cb-9dd8-fb420eeb4a04-jpg
Old 12-10-2020, 12:49 PM #43
firegod33r's Avatar
firegod33r's Avatar
Next is the ARB switch connected to the Amazon harness, I connected them according to the diagrams from ARB and the Amazon switch.
Note (blue is for the backlight function, that I know about)
*****look at the white connector, and remember it for the next pic*****
Wiring raptor lights to button?-1965048c-097f-46a3-a68e-42fef7f4a62b-jpg
Old 12-10-2020, 12:58 PM #44
firegod33r's Avatar
firegod33r's Avatar
And now it won’t let me upload the most important pic
Old 12-10-2020, 01:04 PM #45
firegod33r's Avatar
firegod33r's Avatar
I had to post a link because I couldn’t upload the pic. So this is the confusing part. After I connect the switch hardness and the relay harness via the white connector, I’m left with a red and black.
That’s what led me to believe that something is not right with my Amazon harness. One one white wire running to/from relay that connects to my switch.
IMG_1355.JPG - Google Drive
button , lights , link , raptor , wiring
Wiring for raptor headlights Kyngfish 3rd gen T4Rs 7 09-21-2021 11:36 AM
Has Anyone Tried These Raptor Lights? zw470 5th gen T4Rs 120 11-13-2020 11:52 PM
Raptor lights!! Lets see them! Zeke588 4th Gen T4Rs 5 03-08-2019 02:34 PM
Grill/raptor LED light wiring w/pictures Logan6 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 12-15-2017 11:19 PM
