04-26-2020, 08:21 PM
#31
I had some wired to my Switch-Pros only cause the Leds were stupid bright so I would turn off depending on the occasion.
04-26-2020, 11:33 PM
#32
What’s involved with having the raptor lights attached to the amber parking lights? I can’t seem to find where people have set this up like that and provided a description of how they did it.
08-15-2020, 11:50 PM
#33
Disregard
Already Gone.
12-09-2020, 02:31 AM
#34
Originally Posted by nimby
Pardon my lack experience here, but I have a small issue I’m trying to resolve. I ordered this exact wiring harness from Amazon. I followed your direction from the previous posts and connected the raptor lights to the black and white coming out of the relay. Then ran the switch inside and connected it to my AOB switch...now I’m starring at a black and red wire that comes out of the white connector that goes to the Amazon switch. Where did you connect the red to?
I tried the red directly to the battery, but the raptor lights comes on even when the vehicle is off and no key in the ignition. Is that how it’s suppose to be?
The black is obviously ground, but I’m just so confused by the red wire.
12-09-2020, 12:14 PM
#35
Maybe watch this video: Wiring Factory Style Switch For LED Light Bars - YouTube
I am assuming you are talking about the wire that should either go to an "add a fuse", you can tap into a fuse that is "hot" when the vehicle is on. You can also just tap into the parking light wire, so the raptor lights are only on when your headlights are on. It just depends on how you want it.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
12-09-2020, 12:31 PM
#36
See if this pic helps. My blue coming from the ARB switch is the one I had connected with an add a fuse so it lights up when I turn the key. If I’m understanding you correctly then I would end up with 2 add a fuses? Thanks
12-09-2020, 01:34 PM
#37
You don't need to have 2 add a fuses, you can have both wires going into the crimp part on the same add a fuse.
2014 SR5P
12-09-2020, 02:47 PM
#38
I’m I’m gonna try that. Is it correct that the high voltage is only drawn through the relay? So there is never any chance of any short or melting in the switch harness?
12-10-2020, 10:44 AM
#40
This video breaks it down real easy and is applicable to connecting any light setup with a button. I followed this video to a T and found success in wiring my raptors to a switch. Early in the video he goes over the wiring diagram.
How to Wire an LED Light Bar Properly (Project Night Light Episode 3) - YouTube
Sent from my Pixel 3 using Tapatalk
[ Smeerun's Build Log] - 2016 4Runner Trail Premium MGM w/KDSS
Exterior: Toyo OC A/T III 265/70/17 (TE Wheels) | Dobinsons UCA's + C59-302/GS59-700 Front + C59-500/GS59-705 Rear | C4 Rock Sliders | SSO Roof Rack | Ironman 8.5" Awning | Tacoma Low-Profile Antenna | Diode Dynamics SS3 Pro Fogs | CTH Folding Mirrors + LED Sequential Blinker Mirrors
Interior: VanTrue N4 3-chan Dashcam | Husky Liners Floor Mats | Canvasback Rear Covers | Blue Ridge "Attic"
12-10-2020, 11:34 AM
#41
First: You are wiring for Raptor lights, correct? You defintely want these on a switch as opposed to being on when the vehicle is running? Maybe you can post how you ran the wire so far from the lights.
Second: AOB, not ARB. Air on Board switch, correct?
This should help as well.
Marker Lights (Raptor Lights) Mod for 5th Gen 4Runner - DIY Version
The Amazon link you posted has a diagram, you should follow that exactly. The included switch with the harness has 3 wires, your AOB has 4, because you can tap into a wire that will illuminate the switch when your headlights are on, like all the other switches in the truck (to some people that may not be important).
2014 SR5P
12-10-2020, 12:46 PM
#42
Yes these are for raptor lights, let me explain with pics of what I have so far. Because I feel like we’re going around in circles lol.
This is the where the raptor lights are connected to, (green and red)
You can see the relay and red and black to the battery
From the relay comes out a white wire
12-10-2020, 12:49 PM
#43
Next is the ARB switch connected to the Amazon harness, I connected them according to the diagrams from ARB and the Amazon switch.
Note (blue is for the backlight function, that I know about)
*****look at the white connector, and remember it for the next pic*****
12-10-2020, 12:58 PM
#44
And now it won’t let me upload the most important pic
12-10-2020, 01:04 PM
#45
I had to post a link because I couldn’t upload the pic. So this is the confusing part. After I connect the switch hardness and the relay harness via the white connector, I’m left with a red and black.
That’s what led me to believe that something is not right with my Amazon harness. One one white wire running to/from relay that connects to my switch.
IMG_1355.JPG - Google Drive
