Old 01-11-2020, 03:58 PM #1
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
ANSWERED - D.I.Y. Locker install question
I bought a Harrop rear locker, new carrier bearings, and a mini installation kit. Will do this myself. Reusing the gears.
For those who have installed 5th rear gen lockers, did you need to R&R the pinion for a correct contact pattern?
I have <70,000 miles, and don't care to mess with the pinion if I don't have to.
Thanks!
delloro is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 05:36 PM #2
Jodeckm Jodeckm is offline
Jodeckm is on a distinguished road
You shouldn’t need to remove the pinion.
ARB has instructions on measurements required and calculation for side bearing shims. You take measurements of the old vs the new carrier, then make adjustment to the original side bearing shims thickness using supplied shim packs.
You need to be thorough and repeatable with your measurements. If you measure your backlash before disassembly and can reassemble with the same backlash you should be good.
I picked out a large socket of proper size to fit where the side bearing would be. The bearing seating shoulder should rest on the mouth of the socket. I bolted that socket to a metal table as a “zero” stand. I sat the carrier, minus side bearings, in the socket with ring gear mounting surface down. Using a magnetic dial indicator stuck to the table, I then zeroed a dial indicator on the ring gear mounting surface. Swap new carrier into the socket and read the difference in the dial indicator reading. This gives the difference in the new vs old shim on the gear side.
Use the same process putting the indicator on the opposite carrier bearing seating shoulder to determine the difference in the actual width of the carriers. This measurement is the difference in the opposite new vs old shim.
Do this multiple times and shoot for repeatable measurements.
Jodeckm is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 12:41 PM #3
delloro's Avatar
delloro's Avatar
Bump
Old 02-05-2020, 02:12 PM #4
delloro's Avatar
delloro's Avatar
Answered
So I installed the locker last weekend.
I did not need to address the pinion depth, the contact pattern was fine.
Backlash on teardown was 0.007", I set at 0.0065".
All day job, but I work slowly, and did the wiring too.
ANSWERED - D.I.Y. Locker install question-screenshot_20200205-101126_gallery-jpg  ANSWERED - D.I.Y. Locker install question-screenshot_20200205-101341_gallery-jpg
5th , gen , installed , locker , rear
2001 E-locker install question zwalker16 3rd gen T4Rs 16 09-03-2018 10:40 AM
PCV. The question that I've yet to be answered. Dirtyfingers 3rd gen T4Rs 22 12-08-2013 12:40 AM
noob needs question answered gas cap? zgensler31 3rd gen T4Rs 4 01-20-2012 03:58 PM
Stripped the interior, need a quick question answered imryannn 3rd gen T4Rs 12 04-09-2009 01:51 AM
i need a question answered now about oil fouled plugs shootmymime 3rd gen T4Rs 12 10-02-2008 10:52 PM
