Old 03-25-2020, 05:14 PM #1
supratt's Avatar
supratt supratt is offline
supratt will become famous soon enough
supratt's Avatar
Front rotors, not looking good...right?
Just changing the front pads on my 14 limited. The outer diameter of the rotor is pure rust and you can see the pad obviously doesnt contact the whole surface of the rotor. Is this normal?
Thanks
Front rotors, not looking good...right?-15851707863551152290430508937574-jpg
2014 Limited
supratt is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 05:28 PM #2
spartacus's Avatar
spartacus's Avatar
Thanks
Those rotors are toast they are passed the resurfacing period in my opinion. Get new oem rotors my preference or research after market and get what you like.
Old 03-25-2020, 05:40 PM #3
Captsolo Captsolo is offline
Captsolo will become famous soon enough
Agree with sparticus. I put cheap AM rotors on all 4 wheels when I had my brake job two years ago by a professional brake mechanic/shop - and they worked great. I think mine came from China.
My old 12 year old OEM rotors looked like in the picture above
150,000 miles 2005 SR5 4runner
Amazon.com: Bosch 50011237 QuietCast Premium Disc Brake Rotor For Lexus: 2003-2009 GX470; Toyota: 2003-2009 4Runner, 2007-2009 FJ Cruiser, 2001-2007 Sequoia; Rear: Automotive
brake rotors are cheap. Don't think you have to have OEM Toyota brand for brake rotors IMO.
Captsolo is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 05:40 PM #4
adrtoy adrtoy is offline
adrtoy is on a distinguished road
It's kind of a normal thing for it to happen. You should replace them.
adrtoy is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 06:02 PM #5
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
Rotors are a consumable item, so, yeah, replace them. They nasty.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 06:32 PM #6
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
The wear pattern is normal. But given the massive rust, and the relative cheap price of good replacement rotors, I'd replace them.
08TxRunner is offline   Reply With QuoteReply With Quote
Old 03-25-2020, 06:35 PM #7
supratt's Avatar
supratt's Avatar
Ya definitely replacing them, but I was more interested in the wear pattern as confirmed by 08TxRunner. Thanks folks
2014 Limited
Old 03-25-2020, 08:32 PM #8
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Every spring I go and clean my rotors of rust similar to yours. I take a tapered piece of wood that will fit down into the vents ( or a small rat-tail file) and run it back and forth several times in each vent and then take a piece of wood to the surface of the vent around the circumference to remove all the loose stuff(and there is usually plenty!)
Then I take a file and go around the edge where the pad misses the surface and clean it up some too.
Makes me feel better!! Obviously making a pad inspection at same time.
Bleeding each caliper enough to empty the reservoir once is a good idea too.
My brakes love me!
front , normal , rotor , rust , surface
Front rotors rodsrunner 4th Gen T4Rs 10 01-18-2020 09:24 PM
Front rotors... Majindan 3rd gen T4Rs 4 02-03-2014 02:58 PM
Front Rotors 319 mm or 338 mm??s h7009 Maintenance/Detailing 6 03-09-2011 02:49 PM
Possible to "downgrade" the front 13.3 rotors on '06 ltd to the 12.6 rotors flippedman 4th Gen T4Rs 0 05-08-2009 11:33 AM
Finally found good rotors online! Border411 Maintenance/Detailing 6 12-20-2007 05:25 PM
