Old 06-13-2021, 06:31 PM #286
clanholm clanholm is offline
clanholm is on a distinguished road
Originally Posted by Snowtrooper View Post
Prob didn’t reconnect one of the evap lines or damaged a sensor. Keep us updated.
So I took it back to the dealer and they performed a smoke leak test on the evap system and found that the o-ring on the hose from the gas tank to the canister was damaged. Supposedly they couldn't replace just the o-ring so they replaced the entire hose assembly. It's been 6 days and so far it seems to be fixed.
clanholm is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 09:54 AM #287
Snowtrooper Snowtrooper is offline
Snowtrooper will become famous soon enough Snowtrooper will become famous soon enough
Good to hear that it was an offshoot yet minor fix.
Snowtrooper is offline   Reply With QuoteReply With Quote
Old 06-14-2021, 12:37 PM #288
2021nightshade4x4 2021nightshade4x4 is offline
2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice 2021nightshade4x4 is just really nice
Originally Posted by Gaswain13 View Post
I have heard mine do that as well. My brother's 2020 tacoma does as well. I noticed mine do it when it was sitting for several hours after driving and the temp changed. Opened the gas tank and there was a lot of vapor pressure in it. Guessing something to do with Evap emissions.
I have a bad habit of refueling with the vehicle running. When I remove the cap, there’s a sound similar to a small electric pump running. No other vehicles of mine do this.
2021nightshade4x4 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 12:30 PM #289
blakjack23's Avatar
blakjack23 blakjack23 is offline
blakjack23 is on a distinguished road
blakjack23's Avatar
Am I correct in seeing that no 2016's are on the recall list?
blakjack23 is offline   Reply With QuoteReply With Quote
Old 06-16-2021, 01:15 PM #290
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
It seems there was a range of manufacturing dates where the installed fuel pumps were OK.
Between 2/15 to 5/18.
https://techinfo.toyota.com/techInfo...0TB02tofaq.pdf
Fuel Pump Recall-d2375fb8-d4e3-4dc6-9117-a4e05a2dffab-jpeg
Old 06-16-2021, 01:19 PM #291
Cheers!'s Avatar
Cheers! Cheers! is offline
Cheers! will become famous soon enough
Cheers!'s Avatar
I wonder if the fuel pump becomes a regular maintenance item. So every 5 or so years it goes bad? Does anyone know if the part that was installed is a different part number than the original part number that got recalled?
For the airbags, all the manufacturers were just installing the same fundamentally flaw design airbag. Just that the new ones are fresher and hasn't had 3-5 years to soak up moisture/humidity from the air.
Cheers! is offline   Reply With QuoteReply With Quote
Old 06-26-2021, 07:27 PM #292
a47chuck's Avatar
a47chuck a47chuck is offline
a47chuck will become famous soon enough a47chuck will become famous soon enough
a47chuck's Avatar
Does anyone know if the fuel pump recall requires an ECU re-flash?
‘19 Limited Nightshade, Midnight Black Met, front leaving kit, 265/60R20 BFG KO2’s, fronts tinted to 20%, moonroof to 5%, Magnuson Supercharger
'03 Harley Dyna Superglide Sport
a47chuck is offline   Reply With QuoteReply With Quote
Old 07-09-2021, 07:39 PM #293
Lostmanifesto Lostmanifesto is offline
Lostmanifesto will become famous soon enough
Same issue as clanholm was having with the TRAC OFF and CHECK ENGINE lights coming on after the Fuel Pump recall. Mine took a good week though before it happened.
Same problem with the O-Ring not sealing properly. Took it in and the dealer fixed it. Did not say if it was not installed properly when they did the recall or if the new fuel pump unit wasn't correct when installed. One day later and all seems to be well so far.
I dont know if clanholm or anyone else had this issue also but before my dash lights went off, I noticed a significant lag in my gas pedal at launch. Also, start up was hesitated more than usual. Just some FYI if you experience any of these issues post recall.
Good luck
Lostmanifesto is offline   Reply With QuoteReply With Quote
Old 07-15-2021, 01:14 PM #294
Peyto's Avatar
Peyto Peyto is offline
Peyto is on a distinguished road
Peyto's Avatar
Good luck
Really glad I came here as I just had a similar experience.
I had my fuel pump replaced under recall in December, and just had it fail on me this week. Hard to say if it was related, but should thankfully be covered under the parts warranty.
I got back to the vehicle after a three day backpacking trip and it started rough, had low power, with TRAC Off, CEL, Multi Terrain lights on. The acceleration was a bit rough, but it got to speed and got me home. When I went to try diagnose it the next day, it was in full limp mode. Checked on a few of the obvious things (gas cap, fuses, MAF sensor) before taking to an independent mechanic who identified it as the fuel pump. From there it was off to the dealer where it's now in their hands.
UPDATE: Dealer just called and confirmed it was the o-ring seal that others have mentioned.
2014 Canadian TE Alpine White, Cooper AT3 / Michelin X-Ice XI2, Shrockworks Step Sliders, Compustar 2-way Remote Start, Side-Exit Exhaust, Morimoto XB LED Fogs, Interior LEDs, 3M Clear Bra.
Peyto is offline   Reply With QuoteReply With Quote
Old 07-15-2021, 05:17 PM #295
Do you not have a good relationship with your Toyota dealer? I am curious why you take your vehicle to a private mechanic when it comes to a warranty/recall issue?
Old 07-15-2021, 09:15 PM #296
Peyto's Avatar
Peyto's Avatar
Had I known it was the fuel pump that had failed I certainly would have taken it to the dealer first given it would have been warrantied. No issues with my dealer, but generally for diagnostics and troubleshooting I use a different mechanic who can do it for a fraction of the cost and has earned my trust when things hit the fan. It also helps that he's also a Toyota Master tech.
Old 07-16-2021, 11:06 AM #297
rickl rickl is offline
rickl is on a distinguished road
In the 7 years I've had my 4Runner, it's never needed anything but routine maintenance (and body repair from running into rocks). Then I had the fuel pump recall/replacement and it failed coming into Great Basin National Park, 200 miles from the nearest dealership. Got the tow to Orem, Utah (along with our travel trailer) and they discovered that some retaining clips had been broken during the install, provided us with pictures. Dealership there was great, even let us camp in their lot while the part was ordered and the work done.
The dealership that performed the recall was very good about reimbursing all expenses, but it did cause some lost days from our vacation.
rickl is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 10:03 AM #298
mnofpeace's Avatar
mnofpeace mnofpeace is offline
Real Name: Patrick
mnofpeace has a spectacular aura about mnofpeace has a spectacular aura about
mnofpeace's Avatar
Real Name: Patrick
2014 SR5 owner here, bought slightly used (10k miles) in Dec 2014...
I hadnt had any issues at all with my rig in 7yrs of ownership...scheduled maintenance done front to back as time and/or mileage dictated...still loving the ownership experience.
I took it into the dealership yesterday, got them to perform an oil change and tire rotation along with the recall work...they replaced my fuel pump as well.
now lets see how this goes...
Patrick L
Ft. Washington, Md.
2014 SR5 w/ 3rd row
My TRD-Pro-Lite
mnofpeace is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 12:01 PM #299
Leveler Leveler is offline
Leveler is on a distinguished road
Just had ours in for routine inspection and fuel pump recall all good so far.
Also picked up the 2014 used back in mid July of 2019. It had 7'800 on it.
We currently have 44'00 a couple of lengthy trips cross country with trailer, rtt and gear. From hot to mountains, to interstate speed, never a hint of a problem.
Due for some brakes in the future.
Leveler is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 06:12 PM #300
tHeRVIcO tHeRVIcO is offline
tHeRVIcO is on a distinguished road
We had the fuel pump recall replacement performed on our 2018 SR5 about a month ago. Never had any issues with the stalling noted in the recall notice but decided to have it replaced anyway for peace of mind. However, since we got the truck back we have been having issues with the truck taking several seconds (5-8 seconds) to turn over now. Battery is brand new. Most of the time we have to let it turn over once for a second, pause, then turn it over again which still results in a long delay before it starts. When we first noticed this the day after picking it up we took it back to the dealership to have it looked at again and big surprise, they could not find any “codes”. I got some BS line from the tech that the 4Runners do this in hot weather (we live in Las Vegas) and that we would just have to deal with it. We never had this issues in the previous 3 years of ownership with the old fuel pump ( including equally hot summers) and I am furious with the response from Toyota. We even switched from 91 to 87 octane fuel to see if that would help and it did a bit, but the problem remains. Has anyone else had this issue?
tHeRVIcO is offline   Reply With QuoteReply With Quote
affected , recall , toyota , vehicle , year
Replace Fuel Pump - Drop Fuel Tank? Rock_Rat 3rd gen T4Rs 11 12-17-2023 05:33 PM
No Fuel? Bad Fuel Pump? Bad Fuel? Aliens? Gremlins? 007Tacoma 5th gen T4Rs 12 05-04-2018 09:08 AM
Repeated fuel filter clog, failing fuel pump, or ? hour 3rd gen T4Rs 74 10-09-2016 12:58 PM
Water Pump Recall for 4Runners? ice2000 4th Gen T4Rs 2 11-14-2012 01:43 PM
Fuel pump whining. Clogged fuel filter or bad pump? Shawn5800 3rd gen T4Rs 3 04-18-2011 02:08 AM
