Old 01-14-2020, 02:10 PM #1
axel1's Avatar
axel1 axel1 is offline
axel1 is on a distinguished road
axel1's Avatar
Used T4R Maintenance Checklist
Hi all!
I've had my '14 SR5 for a full year now and it's been doing great. Other than needing new rotors & pads and a new battery, I've had zero mechanical issues.
I've started thinking about maintenance a little more and I'm realizing I don't know exactly what fluids and maintenance items have and haven't been changed in the truck's 55k mile life. Since I've owned the thing I've put on roughly 10k to the odo and changed the engine oil twice. Other than that, none of the fluids have been touched since I took ownership and I have no clue if things like the transfer case or diffs have ever been touched. Wondering what would be a good plan of attack & inspection for the spring when things get warmer.
Right now since I'll be close to 60k by spring, I'm planning on tackling both diffs, the transfer case, and obviously the engine. I'll probably do the diff breather mod while I'm at it as well.
Just curious if there are any other areas I should be checking to verify there's no hidden problems that could come back to bite me later on. I've already got a couple hidden rust spots (like in the driver door sill) that need to be taken care of, so those are on the list too.
'14 SR5 in Classic Silver, Wilpeak AT3Ws, miscellaneous electrical odds and ends.
axel1 is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 02:44 PM #2
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
  • Clean MAF (and replace the o-ring if you like).
  • Clean throttle body (off the truck preferably, but probably a waste of time at 60k).
  • Brake fluid flush. Check all the bleeder caps are still there.
  • Power steering flush.
  • Front diff drain and fill.
  • Transfer case drain and fill.
  • Rear diff drain and fill.
  • Coolant flush.
  • Replace radiator cap (might as well).
  • Replace gas cap gasket if you feel like.
  • PCV valve (wouldn't bother at 55k).
  • Check serpentine belt.
  • Check and adjust parking brake.
  • Grease drive shafts.
  • Lube hinges and spare tire carrier.
  • Transmission fluid replacement.
  • Replace rear diff breather.
  • Clean and grease battery terminals.
  • Replace air filter.
  • Replace cabin filter.
  • Put anti-seize the skid plate bolts.
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 03:10 PM #3
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Here’s my maintenance schedule I have written out, and have been following. Truck has 106k miles on it now and I have now done every single thing on this list but the spark plugs, some things several times now. All have been done in my garage with jack, jack stands and basic tools.
Engine oil every ~6k miles. Synthetic 0w-20, Toyota oil filter, new drain plug gasket.
Grease all driveline zerk fittings. Every 15k miles
Retorque propeller shaft bolt. Every 15k miles
Engine air filter. Every 30k miles. Pn# 17801-38051
Cabin air filter. Every 30k miles. Pn# 87139-yzz08
Brake fluid. Every 2 years. DOT 3 synthetic
Spark plugs. Denso SK16HR11. Every 120k
Coolant. Replace at 100k. Then every 50k after. Toyota Super long life coolant. 11.1 quarts
Front differential fluid- mobil1 75w-90. 1.6 quarts. Every 50k
Rear differential fluid- mobil1 75w-90. 3 quarts - every 50k
Transfer case fluid. Redline 75w85 gl5 or Toyota 75w oil. 1.1 quarts every 50k
Parts:
Transfer Case Fill Gasket 90430-18008
Transfer Case Drain Gasket 90430-18008
Front Differential Fill Gasket 12157-10010
Front Differential Drain Gasket 90430-24003
Rear Differential Fill Gasket 12157-10010
Rear Differential Drain Gasket 12157-10010
Power steering fluid- Synthetic DEX III ATF. Empty reservoir and refill with fresh fluid every other oil change.
Transmission fluid flush- every 90k miles.
11.3qt Toyota genuine ATF WS
Serpentine belt- Bando 7pk2150 Every 100k miles
PCV valve. Every 100k miles. Part #12204-31030
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 06:05 PM #4
axel1's Avatar
axel1's Avatar
  • Coolant flush.
Great list! I'll definitely take it to heart. A few of those are ones I would've never thought to do, like the MAF sensor and the parking brake. Speaking of skid plate bolts, I managed to snap off one of the two oil drain skid plate bolts the first time I did the oil which was met with much cursing. It's still holding on fine with just one but that's on the agenda to drill out. Anti-seize is now my SOP with anything that can get rusty.
It's tricky to find a good place to do all this, since I live at an apartment complex and park on a small incline. Hoping to trade some beer for an afternoon at my buddy's garage to knock all this out.
Old 08-19-2020, 12:03 AM #5
DougEFresh2 DougEFresh2 is offline
DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough DougEFresh2 is a jewel in the rough
ALL FLUIDS GUIDE: Beginner Fluid Maintenance
Hope this helps!!!
2016 SR5, electronic dial actuated, part-time 4WD
2016-2019 service manual: https://www.toyota-4runner.org/5th-g...l-rm27f0u.html
DougEFresh2 is offline   Reply With QuoteReply With Quote
Old 08-19-2020, 09:53 AM #6
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
Check/Clean the filter screens in the oil lines where they meet the oil control valves.
Replace your PCV valve every once in a while (cheap and easy)
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
engine , fluids , maintenance , spring , touched
Running 35's Checklist blonde1boarder 3rd gen T4Rs 23 12-28-2022 11:20 PM
50K maintenance checklist - free mechanic for a few days Greenlawnracing 5th gen T4Rs 8 08-18-2020 11:59 PM
2nd Gen 3VZ: Checklist before doing alternator? itgogitrev Classic T4Rs 5 09-06-2015 09:54 PM
Checklist when buying Yotta 5th gen T4Rs 9 10-25-2013 11:33 AM
Pre-timing belt maintenance checklist juggernaut 3rd gen T4Rs 5 03-11-2012 05:28 PM
