Old 01-15-2020, 02:08 PM #16
Jivewalker's Avatar
Jivewalker Jivewalker is offline
Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all Jivewalker is a name known to all
Jivewalker's Avatar
I'm on my 3rd set of pads at 190,000. Put them on about 20k ago. No seized calipers yet. Use Silglyde on rubber and pins that contact rubber. Brake grease for metal to metal. What part was seized? Piston, pins, or pads?
2012 Trail Edition |KDSS |BLACK| 265/70R17 C KO2's @ 44psi | 250,000+ miles |>Link To Inside Fishing Rod Holder Mod
2017 LAND CRUISER URJ200 | MGM | 285/60R18 | 62,000 miles
I am fragile.
Not like a flower.
But like a bomb.
Jivewalker is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 03:15 PM #17
Blackdog99 Blackdog99 is offline
Blackdog99 is on a distinguished road
The pistons were always the culprits. everytime I do the pads/calipers, I lube the pins on new, and sand rust off, and lube if re-using on still working calipers.
Blackdog99 is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 03:23 PM #18
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Originally Posted by Blackdog99 View Post
I too have had 5 4runners now, (one of each generation) and my '05 was the worst yet for calipers! I have replaced around 9 on the front of it, and 4 on the rear. I am lucky if I get 1.5 years out of a caliper at 8-10K per year of mileage. I have used, AUtozone's reman.'s Advance auto, O'Reilly, and none are any better than others. I have heard only 2 companies reman these.
I now am in the middle of my '14 4runner needing a front cailper at 77K miles.
I am sick and tired of failing calipers and am wondering if anyone has swapped to performance calipers, (wilwood, or other) and can give feedback?
Thanks!!
TC
(4runner History:
86 SAS Swap Dual T-Cases, modded out
94 32" BFG's 1" lift.
2000 Sport Edition
'05 V8
'14 SR5 w/ 3rd row and leather seat cover swap
Don't think anyone makes them. Didn't see any on the Brembo or wilwood sites. Just some remanufactured painted ones on summit.
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 01-15-2020, 04:13 PM #19
Ventil8 Ventil8 is offline
Real Name: Armando
Ventil8 will become famous soon enough Ventil8 will become famous soon enough
Real Name: Armando
I’m still on original calipers. 15 years strong!
Original Owner- 2005 Silver Metallic Sport Edition 4WD V6
Ventil8 is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 08:35 AM #20
schwein schwein is offline
schwein is on a distinguished road
I have even done calipers 2 times on our 2003, impressive you are on 15 years! Needless to say in the end my mechanic told me when I arrived to pick up the 2014 that he was able to unstick the caliper, greased it and its moving freely again, said I should be good to go. Lucked out on this one! thanks for the comments.
2003 - 4Runner Limited V8 (Sold)
2014 - 4Runner Limited V6
2019 - GX460 Premium V8
schwein is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 02:52 PM #21
What kind of grease was used?
Old 01-17-2020, 08:02 PM #22
Argyle Edison Argyle Edison is offline
Argyle Edison will become famous soon enough
The only calipers I've used that do not fail and/or seize , aside from OEM, are NEW Raybestos. They have been great and after two years haven't even rusted in Northeast salt hell. About $100 each
Argyle Edison is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 12:49 PM #23
85GT-79FJ40 85GT-79FJ40 is offline
85GT-79FJ40 will become famous soon enough
Originally Posted by Charlievee View Post
So good quality fluid... Toyota? I have a can of old German performance fluid (don't recall the type) came in blue and red. Made changing fluid easy. Been awhile since i researched brake fluids, i'm sure there have been many changes over the past 5-6 year's.
No Brembo calipers... Sad panda.
you're probably thinking of ATE. Actually what I use. I wish I could still get my hands on the blue stuff. Made bleeding easy. Blue one time, gold the next. Was pretty much essential back when I was doing track days and had to change it a few times a year.
Toyota 4x4 #17 - 2011 4Runner Trail Edition
85GT-79FJ40 is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 07:20 PM #24
Charlievee's Avatar
Charlievee's Avatar
Not sure why i still have this laying around, doubt its any good.
5th Gen - Frozen Calipers-20200118_170428_resized-jpg
Old 01-18-2020, 09:16 PM #25
4boer2's Avatar
4boer2 4boer2 is offline
4boer2 is on a distinguished road
4boer2's Avatar
I replaced my original driver's side at 89,240 on 12/30/16, then again today at 151,145. Passenger side is still original.
4boer2 is offline   Reply With QuoteReply With Quote
Old 01-19-2020, 08:14 AM #26
t0y0ta4R's Avatar
t0y0ta4R t0y0ta4R is offline
t0y0ta4R is on a distinguished road
t0y0ta4R's Avatar
I've had similar experiences with my Tacoma and the front calipers. My first set seized after my truck sat in a parking lot for 6 months waiting on a frame to be replaced. It was frustrating as there was nothing wrong with the brakes before that and the dealer didn't exactly pony up to cover the cost. In any event, I had to install a 2nd set after they froze again( 5 years later) on the way home from the movies. The front drivers side was literally smoking on the way home. I had to pull over and let it cool only 1 mile from home in the pouring rain. I had the local shop use the cheap Chinese replacement parts as the OEM is about twice the cost. Good times!
It is a bit unfortunate that this continues to be an issue all these years later across both platforms.
I'm in the market for a 2021 4R
Preference: 4x4 Limited in Magnetic Gray Metallic
Options: Sliding rear cargo deck
Accessories: All weather Floor Liners & Cargo Tray Package, Exhaust Tip Chrome and Mudguards.
t0y0ta4R is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 09:16 PM #27
If it's never been open it's good. I worked at a German mail order parts supplier for almost 20 years. I used LOTS of that stuff. It was pretty dangerous having almost any part you might desire for your BMW a floor down though.
5th , calipers , front , gen , pads
Frozen calipers...again heiser 4th Gen T4Rs 16 09-06-2016 05:12 PM
Calipers Frozen? You bet! MidwestT4R 4th Gen T4Rs 54 03-14-2016 02:09 PM
Frozen Calipers? Ernest1863 4th Gen T4Rs 4 05-19-2013 12:43 PM
Frozen Calipers?? dbole 3rd gen T4Rs 4 01-15-2012 05:44 PM
Frozen calipers? nicolachel 4th Gen T4Rs 17 10-19-2011 09:34 PM
